nAN-29 - no project file for ble_app_hrs
I'm following nAN-29 and when I go to import the Eclipse project file for ble_app_hrs I get a message "No projects are found to import". I've pretty much followed nAN-29 to the letter and tried multiple times at this step. Is the Eclipse project file no longer bundled with this example?
image description
Thanks, John
  • Project files for Eclipse are currently available in the hrs example for board nrf6310. It's easily ported to PCA10001 by changing the board definition in the pre-processor symbols and remove LED_7 usage in main.c.
    You can also check out the blog post "Development with Eclipse and GCC" for more details on how to import other SDK examples.
  • You can also get full Eclipse based project (not makefile) for Blinky and Blinky over BLE with custom service from this blog page embeddedsoftdev.blogspot.ca/.../h.html. The blog site also contains Eclipse page for setting up Eclipse working environment for ARM development.
  • Maybe I'm missing something here but all I see are 3 Makefiles for ble_app_hrs under the nrf6310 directory. And when I follow the instructions as per nAN-29 I get the same result as above.
    I will say, however, that the blog post worked for me. I got hung up on a couple things on the last step: where the supported device name comes from (I got it from Segger's website) and jlink path (after trial and error I set a path to JLinkGDBServerCL.exe and it seems to work OK). Perhaps this blog post can be merged with nAN-29 (or at least a reference made to it from nAN-29) as that would have saved me a ton of time.
  • Thanks for the feedback. I’ll take your suggestions into considerations and see if we can do some official changes to the app note, but I cannot promise anything yet.
