using ADC and SD Streaming
I've set up a streaming solution that is easily streaming 4+kBytes/s to an iPhone. I've also set up an ADC service that is sampling at 2,083 Hz 10 bit mode, using a PPI channel from timer2->compare[0] event to ADC->TASKS_START event. I've kept the ADC ISR very tight. The problem is when I combine the two and try to stream RT data. I get good reproduction of the input waveform except that every 0.027 sec, or so, it drops 6-7 samples. I've kept the ISR short enough that I am able to run the ADC interrupt in _HIGH mode without impacting the BLE (although if the SD is suppressing the PPI channel during the transmission then I'm not really testing that assertion).
I checked that the ADC ISR routine is NOT being called for the dropped samples.
Questions
  1. Has anyone run into this - and if so is there a solution? (I searched the data base to no avail)
  2. Does the SD suppress the PPI channels during radio use? I thought it would not.
I'm using 5.2 and SD 6.0 as I haven't had time to accommodate the changes in the new release yet.
Any help appreciated.
Scott
