0> <t: 0>, main.c, 696, ----- BLE Mesh Light Switch Client Demo ----- 0> <t: 0>, mesh_softdevice_init.c, 112, Initializing SoftDevice... 0> <t: 0>, mesh_softdevice_init.c, 77, Enabling BLE... 0> <t: 2>, mesh_softdevice_init.c, 88, Ram base: 0x200032C8 0> <t: 18>, main.c, 642, Initializing mesh stack 0> <t: 549>, access.c, 100, i : 0 0> <t: 551>, access.c, 100, i : 1 0> <t: 554>, main.c, 614, Initializing and adding models 0> <t: 557>, access.c, 100, i : 2 0> <t: 559>, access.c, 100, i : 3 0> <t: 561>, access.c, 100, i : 4 0> <t: 564>, access.c, 100, i : 5 0> <t: 566>, access.c, 100, i : 6 0> <t: 569>, access.c, 100, i : 7 0> <t: 581>, main.c, 674, Setup defaults: Adding keys, addresses, and bindings 0> <t: 725>, provisioner_helper.c, 329, netkey_handle: 0 0> <t: 737>, main.c, 715, <start> 0> <t: 739>, main.c, 732, Device UUID : 0059ABCDEFABCDEFACCDEFABCDEFABCD 0> <t: 27096>, main.c, 426, Flash write complete 0> <t: 27393>, main.c, 426, Flash write complete 0> <t: 27395>, main.c, 415, Starting application ... 0> <t: 27397>, main.c, 417, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100 0> <t: 27401>, main.c, 418, Dev key : AADF3826CAF5929384E288DFBF558AC8 0> <t: 27404>, main.c, 419, Net key : 5C2E9CFF56B943CF10962AC6205B4505 0> <t: 27407>, main.c, 420, App key : BC41EA6020DD802B991D3E37E53B86D3 0> <t: 27410>, main.c, 421, Press Button 1 to start provisioning and configuration process. 0> <t: 377514>, main.c, 291, Button 0 pressed 0> <t: 377516>, main.c, 259, Waiting for Server node to be provisioned ... 0> <t: 382283>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices 0> <t: 413732>, provisioner_helper.c, 144, UUID seen: 0059FFFF00000000556CC097C1477C90 0> <t: 413735>, provisioner_helper.c, 95, UUID filter matched 0> <t: 413738>, app_error_weak.c, 105, Mesh error 6 at 0x00028599 (F:\document\mesh\nrf_mesh_v2.0.1\nrf5_SDK_for_Mesh_v2.0.1_src\examples\light_switch\client\src\provisioner_helper.c:114)
static void check_network_state(void)
if (!m_node_prov_setup_started)
/* If previously provisioned device is not configured, start node setup procedure. */
if (m_nw_state.configured_devices < m_nw_state.provisioned_devices)
/* Execute configuration */
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Waiting for provisioned node to be configured ...\n");
node_setup_start(m_nw_state.last_device_address, PROVISIONER_RETRY_COUNT,
m_nw_state.appkey, APPKEY_INDEX);
hal_led_pin_set(APP_CONFIGURATION_LED, 1);
#if 0
else if (m_nw_state.provisioned_devices == 0)
/* Start provisioning - First provision the client with known UUID */
m_exp_uuid.p_uuid = m_client_node_uuid;
m_exp_uuid.length = NRF_MESH_UUID_SIZE;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Waiting for Client node to be provisioned ...\n");
prov_helper_provision_next_device(PROVISIONER_RETRY_COUNT, m_nw_state.next_device_address, &m_exp_uuid);
prov_helper_scan_start();
hal_led_pin_set(APP_PROVISIONING_LED, 1);
else if (m_nw_state.provisioned_devices < SERVER_NODE_COUNT)
/* Start provisioning - rest of the devices */
m_exp_uuid.p_uuid = m_server_uuid_filter;
m_exp_uuid.length = SERVER_NODE_UUID_PREFIX_SIZE;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Waiting for Server node to be provisioned ...\n");
m_node_prov_setup_started = true;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Waiting for previous procedure to finish ...\n");
As showed in the code, I masked " else if (m_nw_state.provisioned_devices == 0) ", then it reported "NRF_ERROR_NOT_SUPPORTED".
Can you tell me how should I do, thank you.
