I have been working with the NRF52832, and trying to capture raw ADC data with the help of TWI bus. I have imported the necessary libraries (i'll attach the code below in order to make it more clear) and i'm stuck on the last part inside the int main(). Every other command is getting executed, apart from the last one where it says NRF_LOG_INFO("data received"). I have done some debugging and i found out, that the code above this part works well. It shows a fatal error,at the point of the "Data received" command.
So, any help i get regarding the code will be helpful.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define TWI_INSTANCE 0
#define BNO_055 0x28 //the BNO_055 has two modes, one for read and one for write, i.e. 0x28 and 0x29//
#define QUA_Data_w_LSB 0x23 //this is the register data, which we are trying to send out//
#define PWR_MODE 0x3E // this specifies the mode in which the BNO_055 operates, i.e. Normal mode//
static volatile bool m_xfer_done = false;
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE);
/* bufer for samples to read*/
static uint8_t m_data = 90; //random data, which will be overwritten with the data in the QUA_Data_w_LSB data//
static uint8_t OPERATION_MODE_ADD[1] = {0x3D};
static uint8_t NDOF_MODE[1] = {0x0C};
void BNO_handler(nrf_drv_twi_evt_t const *p_event, void *p_context )
switch (p_event->type) //all the events, which could possobly take place//
case NRF_DRV_TWI_EVT_DONE:
NRF_LOG_INFO("EVT DONE");
m_xfer_done = true;
case NRF_DRV_TWI_EVT_ADDRESS_NACK:
NRF_LOG_INFO("ADDRESS NACK");
NRF_LOG_FLUSH();
case NRF_DRV_TWI_EVT_DATA_NACK:
NRF_LOG_INFO("DATA NACK");
NRF_LOG_FLUSH();
void BNO_init()
const nrf_drv_twi_config_t twi_config =
.scl = 26,
.sda = 25,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = TWI_DEFAULT_CONFIG_IRQ_PRIORITY,
.clear_bus_init = TWI_DEFAULT_CONFIG_CLR_BUS_INIT,
.hold_bus_uninit = TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT
APP_ERROR_CHECK(nrf_drv_twi_init(&m_twi, &twi_config, BNO_handler, NULL));
nrf_drv_twi_enable(&m_twi);
//APP_ERROR_CHECK(nrf_drv_twi_rx(&m_twi,BNO_055, PWR_MODE, 1));
APP_ERROR_CHECK(nrf_drv_twi_tx(&m_twi, BNO_055, OPERATION_MODE_ADD, 1, false));
NRF_LOG_INFO("the data is being written into the BNO_055, into the operation mode register");
NRF_LOG_FLUSH();
while(!m_xfer_done);
APP_ERROR_CHECK(nrf_drv_twi_tx(&m_twi, BNO_055, NDOF_MODE, 1, false));
NRF_LOG_INFO("The data will now be sent with NDOF mode and all the sensors are activated");
NRF_LOG_INFO("IMU data started");
NRF_LOG_FLUSH();
int main()
NRF_LOG_INFO("TWI test started.");
NRF_LOG_FLUSH();
BNO_init();
uint8_t accRegister[1] = {QUA_Data_w_LSB};
//Read byte from bno
APP_ERROR_CHECK(nrf_drv_twi_tx(&m_twi, BNO_055, accRegister, 1, false));
NRF_LOG_INFO("Data received test");
APP_ERROR_CHECK(nrf_drv_twi_rx(&m_twi, BNO_055, &m_data, 8));
nrf_delay_ms(1000);
NRF_LOG_INFO("data received: %X", &m_data);
NRF_LOG_FLUSH();
while (true);
