NRFX PWM driver timing
I'm working on some LED sequences using the NRFX PWM driver and I can't get the durations I want right.
Let's say that I want a semi-blinking LED (100% - 50% - 100%...) with a period of 500 ms on each state and I initialize the PWM driver as follows:
nrfx_pwm_config_t const pwm_config =
	.output_pins =
		led.red | led.polarity,     // Channel 0
		led.green | led.polarity,   // Channel 1
		led.blue | led.polarity,    // Channel 2
		NRFX_PWM_PIN_NOT_USED       // Channel 3
	.irq_priority = APP_IRQ_PRIORITY_LOW,
	.base_clock   = NRF_PWM_CLK_16MHz,						// NRF_PWM_CLK_125kHz,
	.count_mode   = NRF_PWM_MODE_UP_AND_DOWN,				// For symmetric color mixing
	.top_value    = 255,
	.load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
	.step_mode    = NRF_PWM_STEP_AUTO
err_code = nrfx_pwm_init(&m_pwm0, &pwm_config, pwm_event_handler);
As far as I understand I could do this to get my timing right:
void setup_single_color_sequence(nrf_pwm_sequence_t * sequence, color_t color, uint32_t duration_in_us) {
	uint32_t top = 255;
	uint32_t pwm_period = top / 16; 						// In µs (top / clock_frequency in MHz)
	uint16_t pwm_pulses_for_duration = duration_in_us / (pwm_period * NRF_PWM_VALUES_LENGTH(pwm_values_single_color));
	for (uint8_t i = 0; i < 2; i++) {
		pwm_values_single_color[i].channel_0 = color.r;
		pwm_values_single_color[i].channel_1 = color.g;
		pwm_values_single_color[i].channel_2 = color.b;
		pwm_values_single_color[i].channel_3 = 0;
	sequence->values.p_individual		= pwm_values_single_color;
	sequence->length					= NRF_PWM_VALUES_LENGTH(pwm_values_single_color);
	sequence->repeats					= pwm_pulses_for_duration;
	sequence->end_delay					= 0;
That is using the .repeats field to make each duty cycle repeat in order to get my desired timing. That however doesn't really work, I get shorter periods.
My logic is: The PWM counts up to 255. If I'm running the PWM at 16 MHz, then each duty cycle has a duration of 255/16 MHz = ~16 us. If I want the PWM to stay at that level for 500 ms, then I divide that duration (in us) by the duration of the duty cycle and I get the number of times that I need to repeat each duty cycle in order to get my target duration.
Is that logic wrong?
  • I'm not sure if I follow your logic. Can you show me how  you would use this function to generate a signal of "(100% - 50% - 100%...) with a period of 500 ms on each state "?
    How much shorter than expected are the periods?
  • If I understand correctly I have two options:
    Create a sequence with both values, i.e. [100%, 50%] and call the function with a duration of 1 second. This probably wouldn't work because of the size of repeats (uint16), but I could do [100%, 100%, 50%, 50%] and maybe then it'd work. The code then would look like this maybe:
    for (uint8_t i = 0; i < 4; i++) {
        // Make the second half at 50%
        uint8_t divide = (i >= 2) ? 2 : 1;
    	pwm_values_single_color[i].channel_0 = color.r / divide;
    	pwm_values_single_color[i].channel_1 = color.g / divide;
    	pwm_values_single_color[i].channel_2 = color.b / divide;
    This is not what I'm doing.
    What I'm doing is the second choice which would be to create two sequences and then playing them one after the other like this:
    nrfx_pwm_complex_playback(&m_pwm0, &pwm_sequence_1, &pwm_sequence_2, 1, NRFX_PWM_FLAG_LOOP);
    I am doing this because I'm not using just a static full lit LED, but rather I'm playing back a fade in/out sequence with a sine sequence. I want to use a single color at 0% or 50% as sequence #2 to space the waveform. So I would then call setup_single_color_sequence() to generate this pause with a specific duration.
    I hope that makes sense.
  • And the periods are maybe half as long as they should be maybe. So it's noticeable.
    Maybe you can try something like this:
    nrfx_pwm_t m_pwm0 = NRFX_PWM_INSTANCE(0);
    #define PWM_TOP_VALUE 100
    static void pwm_init(void)
    	    .output_pins =
    		    LED_1,     // Channel 0
    		    NRFX_PWM_PIN_NOT_USED,   // Channel 1
    		    NRFX_PWM_PIN_NOT_USED,    // Channel 2
    	    .top_value    = PWM_TOP_VALUE,
        uint32_t err_code = nrfx_pwm_init(&m_pwm0, &pwm_config, NULL);
    static nrf_pwm_values_individual_t pwm_values[2];
    nrf_pwm_sequence_t static pwm_sequence =
        .values.p_individual = pwm_values,
        .length          = NRF_PWM_VALUES_LENGTH(pwm_values),
        .repeats         = 1,
        .end_delay       = 0
    void make_sequence(uint32_t duration_us)
        uint32_t pwm_period = 2 * PWM_TOP_VALUE / 16; // In µs (top / clock_frequency in MHz). Multiply by 2 if using NRF_PWM_MODE_UP_AND_DOWN
        uint32_t repeats = duration_us / pwm_period;
        pwm_sequence.repeats = repeats;
        pwm_values[0].channel_0 = 100;
        pwm_values[1].channel_0 = 5;
        LEDS_CONFIGURE(LEDS_MASK);
        LEDS_OFF(LEDS_MASK);
        pwm_init();
        make_sequence(500000);
        nrfx_pwm_simple_playback(&m_pwm0, &pwm_sequence, 1, NRFX_PWM_FLAG_LOOP);
        for (;;)
    This code will blink LED_1 with a frequency of 1 Hz.
  • Hi Martin, just to let you know that I still haven't been able to make it work, but it looks like there's something else wrong with my implementation. I'll update here when I figure it out
