I am developing a code in which, among other things, when a button is pressed, a led turns on. In the same button handler, a timer is started to turn the led off a bit later.
It works perfectly well in the beginning, but after pushing the button some times (between 3 and 10) it responds no more. The rest of the application will continue acting normally, even its timers.
I've already checked that APP_TIMER_CONFIG_OP_QUEUE_SIZE is big enough, and also changing the button handler for a flag and handle the event in the main loop. It solved nothing. The only way it works is by changing the timer by a delay, but it is useless if I want the led to be on for some seconds.
Button initialization and handler:
void button_handler(nrf_drv_gpiote_pin_t pin_no, nrf_gpiote_polarity_t button_action)
app_timer_stop(led_off_timer);
nrf_gpio_pin_clear(LED_G);
nrf_gpio_pin_clear(LED_B);
uint32_t err_code = app_timer_start(led_off_timer, APP_TIMER_TICKS(1000), NULL);
static void init_button(void)
uint32_t err_code;
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
in_config.pull = NRF_GPIO_PIN_NOPULL;
err_code = nrf_drv_gpiote_in_init(BUTTON1, &in_config, button_handler);
nrf_drv_gpiote_in_event_enable(BUTTON1, true);
Timer handler:
void led_off_handler(void * p_context)
nrf_gpio_pin_set(LED_G);
nrf_gpio_pin_set(LED_B);
I am using a nrf52832 with SDK 14.2.0 and softdevice s132 v5.1.
Any clue of why it is happening or how can be solved will be very welcome. Thanks.
