Hello everyone,
I'm new to embedded system and I'm working with the NRF52 and more precisely with the DW1001 (NRF52 + DW1000).
The Decawave device (DW1000) is already configure to receive data from the NRF52 through the SPI
I'm trying to receive the exact same data on a second DW1000 which I cabled (to the DW1001) :
Then I followed the Nordic infocenter SPI Master tutorial :http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk52.v0.9.1%2Fhardware_driver_spi_master.html&cp=4_0_0_2_7
However, I got an issue when I'm using NRF_DRV_SPI_DEFAULT_CONFIG(0)
What I have done so far :
1- Switch SPI0_ENABLED to 1.
/* SPI */ #define SPI0_ENABLED 1 #if (SPI0_ENABLED == 1) #define SPI0_USE_EASY_DMA 0 #define SPI0_CONFIG_SCK_PIN 2 #define SPI0_CONFIG_MOSI_PIN 3 #define SPI0_CONFIG_MISO_PIN 4 #define SPI0_CONFIG_IRQ_PRIORITY APP_IRQ_PRIORITY_LOW
2- Create a master Instance
#define SPI0_INSTANCE 0 /**< First SPI instance index. */ static const nrf_drv_spi_t m_spi_master_0 = NRF_DRV_SPI_INSTANCE(0); /**< First SPI instance. */ static volatile bool spi0_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
3- Event handler to test
void spi0_event_handler(nrf_drv_spi_evt_t const * p_event)
spi0_xfer_done=true;
if(spi0_xfer_done==true){printf("ok");}
4- In main function :
nrf_drv_spi_config_t config = NRF_DRV_SPI_DEFAULT_CONFIG(0);
And this is my problem. When i'm checking the error, it expect NRF_DRV_SPI_DEFAULT_CONFIG without parameters. Then I have looked into the lib and I see that it's different from the SPI master example available. My function has no id :
#define NRF_DRV_SPI_DEFAULT_CONFIG \
.sck_pin = NRF_DRV_SPI_PIN_NOT_USED, \
.mosi_pin = NRF_DRV_SPI_PIN_NOT_USED, \
.miso_pin = NRF_DRV_SPI_PIN_NOT_USED, \
.ss_pin = NRF_DRV_SPI_PIN_NOT_USED, \
.irq_priority = SPI_DEFAULT_CONFIG_IRQ_PRIORITY, \
.orc = 0xFF, \
.frequency = NRF_DRV_SPI_FREQ_4M, \
.mode = NRF_DRV_SPI_MODE_0, \
.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST, \
Instead of :
* @brief SPI master instance default configuration.
#define NRF_DRV_SPI_DEFAULT_CONFIG(id) \
.sck_pin = CONCAT_3(SPI, id, _CONFIG_SCK_PIN), \
.mosi_pin = CONCAT_3(SPI, id, _CONFIG_MOSI_PIN), \
.miso_pin = CONCAT_3(SPI, id, _CONFIG_MISO_PIN), \
.irq_priority = CONCAT_3(SPI, id, _CONFIG_IRQ_PRIORITY), \
.orc = 0xFF, \
You can find more here : http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk51.v10.0.0%2Fhardware_driver_spi_master.html&cp=4_0_2_2_7
The exemple SPI master use :
.orc = 0xFF, \
This is probably the issue but I have no clue how to fix it. Any help appreciate on this (Maybe I'm going the wrong way too)
