How to correctly configure LF clock source in SDK 15
I Have a custom PCB with Fanstel BT832 module soldered. Because that module does not have a 32 KHz quartz I need to set use the internal RC source instead. The problem is that I have 3 different places to set it and I don't know which one I should use.
My sdk_config.h (copied from the hrs example) has those three:
CLOCK_CONFIG_LF_SRC
NRFX_CLOCK_CONFIG_LF_SRC
NRF_SDH_CLOCK_LF_SRC
Which one of them I need to change?
And are there other settings i need to configure to make the internal RC work?
