How to use Static Passkey for a no-display-no-output peripheral
I'm looking to implement the following security schema:
  • The peripheral does not have a display nor input capabilities
  • A smartphone will connect to the device
  • The peripheral will pair (but not bond) with the smartphone
  • Pairing will require the smartphone user to enter a 6-digit passkey
  • Upon successful pairing, the passkey can be changed via the mobile application
  • A physical button on the peripheral will enable resetting the passkey to a default
Some questions:
  • Is it possible to implement this schema in nRF52840, s140, SDK15? If so, what are the required steps.
  • Does this schema provide MITM protection (assuming I change the passkey often)?
I know there are a lot of security and passkey relate questions out there, but I couldn't quite find the answers I needed. Thanks!
    Yes, but it will not provide 100% MITM protection(opens up for passive eavesdropping). See this post. A starting point would be to take a look at the Glucose Application example in the SDK, it shows you how to implement passkey. By default it will use a random passkey, printed over UART, and you will need to input the passkey on the phone.
    If you want a static prepreogrammed passkey instead of generaring a randome one, you can do it like this:
    #define STATIC_PASSKEY    "123455"
    static void set_static_passkey()
        static ble_opt_t    m_static_pin_option;
        uint8_t passkey[] = STATIC_PASSKEY;
        m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
        uint32_t err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
    Call the set_static_passkey() function after you have called ble_stack_init() in main()
    Snippet:
    ble_stack_init();
    set_static_passkey();
    Then make sure that you have this:
    #define SEC_PARAM_BOND                  0                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
    #define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    and that in peer_manager_init(), this is commented out:
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    Also see this link.
    The passkey method is generally considered to be secure from MITM attacks, but it's not 100% secure, and it opens up for passive eavesdropping. Please see this, this and this post.
    Also read this document by Bluetooth SIG. Also this wiki-site provide some good information.
    Note that what type of security you need will depend on what type of application you have.
    (PS: bonding is generally recommended, so that the end-user don't have to enter the passkey every time he need to connect to the device.)
  • Hi Sigurd.
    I have tried to implement the process u mentioned.but I haven't achieved static passkey method.
    Please help me out
  • Hi Sigurd,
    I implemented and working fine. Later I saw your post. Now I got confidence.
    Hi Rana,
    I am not sure which example you are using. I am using nRF52832, SDK_15.3.0, S132 SoftDevice and Segger for flashing the image. I am using ‘ble_app_blinky’.
    One more change to be done
    1) In ble_evt_handler() You need to comment below case as it replies with "Pairing not supported".
        // Pairing not supported
        err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                               BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                               NULL,
                                               NULL);
    Thanks & Regards
    Vishnu Beema
  • Hi ,
    thanks for your steps, they are really clear as compared to other threads but it is not working in my case (I am a beginner).
    I am using the nRF52832(PCA10040), SDK 15.3 and I tried to modify the ble_app_gls_pca10040_s132 using SEGGER.
    The original project works and I can see the random passkey in the UART (I use the Arduino serial monitor).
    I followed your steps for making a statin passkey but when I build the code this error occurs:
    "'ble_gap_opt_t' {aka 'union <anonymous>'} has no member named 'passkey'"
    So, I tried to understand and find in the devzone how to fix the "has no member named" error but I did find nothing clear.
    can you explain to me which is and how to fix this type of error?
    Can you help me, please? I attached an image of error and the mail.c file.
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_gls_main main.c
     * @ingroup ble_sdk_app_gls
     * @brief Glucose Meter service Sample Application
     * This file contains the source code for a sample application using the Glucose Meter service
     * (and also Battery and Device Information services). This application uses the
     * @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_dis.h"
    #include "ble_bas.h"
    #include "ble_gls.h"
    #include "ble_racp.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_lesc.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "Nordic_Glucose"                            /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
    #define MODEL_NUMBER                    "nRF51"                                     /**< Model Number string. Will be passed to Device Information Service. */
    #define MANUFACTURER_ID                 0x55AA55AA55                                /**< DUMMY Manufacturer ID. Will be passed to Device Information Service. You shall use the ID for your Company*/
    #define ORG_UNIQUE_ID                   0xEEBBEE                                    /**< DUMMY Organisation Unique ID. Will be passed to Device Information Service. You shall use the Organisation Unique ID relevant for your Company */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                40                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(10000)                      /**< Battery level measurement interval (ticks). */
    #define MIN_BATTERY_LEVEL               81                                          /**< Minimum battery level as returned by the simulated measurement function. */
    #define MAX_BATTERY_LEVEL               100                                         /**< Maximum battery level as returned by the simulated measurement function. */
    #define BATTERY_LEVEL_INCREMENT         1                                           /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(10, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (10 ms). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (100 ms) */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAM_UPDATE_COUNT     3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define LESC_DEBUG_MODE                 0                                           /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
    //#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    //#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
    //#define SEC_PARAM_LESC                  1                                           /**< LE Secure Connections enabled. */
    //#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    //#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
    //#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    //#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    //#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    #define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
    #define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
    #define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    ////////// STATIC PASSKEY
    BLE_BAS_DEF(m_bas);        /**< Structure used to identify the battery service. */
    BLE_GLS_DEF(m_gls);        /**< Structure used to identify the glucose service. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_battery_timer_id);                                                  /**< Battery timer. */
    static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    static uint16_t     m_conn_handle        = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static ble_uuid_t   m_adv_uuids[] =                                                 /**< Universally unique service identifiers. */
        {BLE_UUID_GLUCOSE_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static sensorsim_cfg_t   m_battery_sim_cfg;                                         /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state;                                       /**< Battery Level sensor simulator state. */
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
            case PM_EVT_CONN_SEC_SUCCEEDED:
                pm_conn_sec_status_t conn_sec_status;
                // Check if the link is authenticated (meaning at least MITM).
                err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
                if (conn_sec_status.mitm_protected)
                    NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                                 ble_conn_state_role(p_evt->conn_handle),
                                 p_evt->conn_handle,
                                 p_evt->params.conn_sec_succeeded.procedure);
                    // The peer did not use MITM, disconnect.
                    NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                    err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                    err_code = sd_ble_gap_disconnect(m_conn_handle,
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                advertising_start(false);
    /**@brief Function for handling Service errors.
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        uint8_t  battery_level;
        battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        battery_level_update();
    /**@brief Function for updating glucose measurement and updating glucose characteristic in Glucose.
              Service.
    static void read_glucose_measurement(void)
        ble_gls_rec_t rec;
        uint32_t      err_code;
        static int16_t s_mantissa = 550;
        static int16_t s_exponent = -3;
        static uint8_t s_secs     = 5;
        // simulate the reading of a glucose measurement.
        rec.meas.flags = BLE_GLS_MEAS_FLAG_TIME_OFFSET |
                         BLE_GLS_MEAS_FLAG_CONC_TYPE_LOC |
                         BLE_GLS_MEAS_FLAG_UNITS_MOL_L;
        rec.meas.base_time.year                 = 2012;
        rec.meas.base_time.month                = 1;
        rec.meas.base_time.day                  = 1;
        rec.meas.base_time.hours                = 12;
        rec.meas.base_time.minutes              = 30;
        rec.meas.base_time.seconds              = s_secs;
        rec.meas.glucose_concentration.exponent = s_exponent;
        rec.meas.glucose_concentration.mantissa = s_mantissa;
        rec.meas.time_offset                    = 0;
        rec.meas.type                           = BLE_GLS_MEAS_TYPE_CAP_BLOOD;
        rec.meas.sample_location                = BLE_GLS_MEAS_LOC_FINGER;
        rec.meas.sensor_status_annunciation     = 0;
        // change values for next read.
        s_mantissa += 23;
        if (s_mantissa > 939)
            s_mantissa -= 434;
        s_secs += 3;
        if (s_secs > 59)
            s_secs = 0;
        err_code = ble_gls_glucose_new_meas(&m_gls, &rec);
        if (err_code != NRF_SUCCESS)
            // Do nothing.
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        err_code = app_timer_init();
        // Create timers.
        err_code = app_timer_create(&m_battery_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    battery_level_meas_timeout_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_GLUCOSE_METER);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Initialize the Glucose, Battery and Device Information services.
        ble_gls_init_t     gls_init;
        ble_dis_init_t     dis_init;
        ble_bas_init_t     bas_init;
        // Initialize Glucose Service - sample selection of feature bits.
        memset(&gls_init, 0, sizeof(gls_init));
        gls_init.evt_handler          = NULL;
        gls_init.error_handler        = service_error_handler;
        gls_init.feature              = 0;
        gls_init.feature             |= BLE_GLS_FEATURE_LOW_BATT;
        gls_init.feature             |= BLE_GLS_FEATURE_TEMP_HIGH_LOW;
        gls_init.feature             |= BLE_GLS_FEATURE_GENERAL_FAULT;
        gls_init.is_context_supported = false;
        // Here the sec level for the Glucose Service can be changed/increased.
        gls_init.gl_meas_cccd_wr_sec = SEC_JUST_WORKS;
        gls_init.gl_feature_rd_sec   = SEC_JUST_WORKS;
        gls_init.racp_cccd_wr_sec    = SEC_JUST_WORKS;
        gls_init.racp_wr_sec         = SEC_JUST_WORKS;
        err_code = ble_gls_init(&m_gls, &gls_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
        ble_srv_ascii_to_utf8(&dis_init.serial_num_str, MODEL_NUMBER);
        ble_dis_sys_id_t system_id;
        system_id.manufacturer_id            = MANUFACTURER_ID;
        system_id.organizationally_unique_id = ORG_UNIQUE_ID;
        dis_init.p_sys_id                    = &system_id;
        dis_init.dis_char_rd_sec = SEC_OPEN;
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators.
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    /**@brief Function for starting application timers.
    static void application_timers_start(void)
        // Start application timers.
        err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    /**@brief Function for handling the Connection Parameter events.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail configuration parameter, but instead we use the
     *                event handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        cp_init.max_conn_params_update_count   = MAX_CONN_PARAM_UPDATE_COUNT;
        ret_code_t err_code;;
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising");
                break; // BLE_ADV_EVT_FAST
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
                break; // BLE_ADV_EVT_IDLE
        pm_handler_secure_on_connection(p_ble_evt);
                NRF_LOG_INFO("Disconnected");
                // Check if the last connected peer had not used MITM, if so, delete its bond information.
                if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                    err_code = pm_peer_delete(m_peer_to_be_deleted);
                    NRF_LOG_DEBUG("Collector's bond deleted");
            } break;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                // Start Security Request timer.
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
            case BLE_GAP_EVT_PASSKEY_DISPLAY:
                char passkey[PASSKEY_LENGTH + 1];
                memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
                passkey[PASSKEY_LENGTH] = 0;
                NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
            } break;
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
            case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
             case BLE_GAP_EVT_AUTH_STATUS:
                 NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                              p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                              p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                              p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_WHITELIST_OFF
            case BSP_EVENT_KEY_1:
                read_glucose_measurement();
                break; // BSP_EVENT_KEY_1
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        err_code = nrf_ble_lesc_request_handler();
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /////////// STATIC PASSKEY
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        sensor_simulator_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Glucose example started.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • Hi beemavishnu
    I was able to achieve paring with static passkey .
    The thing is u need to build the static passkey function before connection and paring function
    As for bonding u can change its parameter to no bond or bond once
