Minimum value of the timeout_ticks parameter
SDK 14.2
This question pertains to the app_timer library.
I am using the app_timer library for creating/starting timeouts.I had a question about the APP_TIMER_MIN_TIMEOUT_TICKS parameter defined in the app_timer.h fie. My question is why is this parameter defined as 5. Can it be defined as 1? or 2? If so, what would happen if it was defined as a lower number? Timing issues?
The reason I ask is if I use a prescaler of 255, the minimum timeout length that I can request is then around 35 ms. Unless I choose a lower prescaler, I cannot request a lower timeout length, because the minimum tics it can support is 5 and each tic is 7812.5 us when the prescaler is 255.
