Changes required to infrastructure file ble_glc.c attached
The issue is that I fixed some of your bugs in the attached file, as follows:
  1. Changed to handle larger number of records greater than 256 records, we need 500 records capability, was 8-bit record counter, now is 16 bit records counter.
  2. Fixed an endless loop issue in RACP code. The “first/last” RACP sending logic had an endless loop.
  3. Changed m_next_seq_num to global variable to be global to access from other parts of the codebase. This is the record sequence number.
  4. fix logic in glucose_meas_send call that never completes sending char notification, see lines 716-721
  • One more fix, see attached updated file.
    fixed resending too many records when RACP sends ALL records and gets error: BLE_ERROR_NO_TX_PACKETS.
     fixed by incrementing record counter called: m_racp_proc_record_ndx, see line 971
    * File   :	ble_gls.c
    * Revision History:
    *  Date:	By:		Description:
    *  4/19/16	dlc		initial, chg m_next_seq_num to global
    * 12/09/16  dlc     added printf, support for it
    * 07/11/17  dlc     removed printf's not needed
    * 07/13/17  dlc     reinserted seqnum cmtd out earlier, future: replace with seqnum from db !
    * 08/10/17  dlc     chg m_racp_proc_record data point from 8bit to 16bit to retrieve more than 255 records.
    * 02/23/18  dlc     fix first/last RACP sending logic endless loop
    * 06/22/18  dlc     fix logic after sd_ble_gatts_hvx calls that never completes sending char notification, see lines 716-721 and 729-732
    * 06/25/18  dlc     fixed resending too many records when RACP sends ALL records and gets error: BLE_ERROR_NO_TX_PACKETS.
    *                   fixed by incrementing record counter called: m_racp_proc_record_ndx, see line 971
    /* Copyright (c) 2012 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    /* Attention!
    *  To maintain compliance with Nordic Semiconductor ASA�s Bluetooth profile
    *  qualification listings, this section of source code must not be modified.
    #include "sdk_config.h" //dlc added
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(BLE_GLS)
    #include "ble_gls.h"
    #include <string.h>
    #include "ble_racp.h"
    #include "ble_srv_common.h"
    #include "ble_gls_db.h"
    #include "nrf_log.h"
    #include "../../../examples/ble_peripheral/ble_app_gls/Common_definitions.h"
    #define OPERAND_FILTER_TYPE_SEQ_NUM     0x01                                     /**< Filter data using Sequence Number criteria. */
    #define OPERAND_FILTER_TYPE_FACING_TIME 0x02                                     /**< Filter data using User Facing Time criteria. */
    #define OPERAND_FILTER_TYPE_RFU_START   0x07                                     /**< Start of filter types reserved For Future Use range */
    #define OPERAND_FILTER_TYPE_RFU_END     0xFF                                     /**< End of filter types reserved For Future Use range */
    #define OPCODE_LENGTH 1                                                          /**< Length of opcode inside Glucose Measurement packet. */
    #define HANDLE_LENGTH 2                                                          /**< Length of handle inside Glucose Measurement packet. */
    #define MAX_GLM_LEN   (BLE_L2CAP_MTU_DEF - OPCODE_LENGTH - HANDLE_LENGTH)        /**< Maximum size of a transmitted Glucose Measurement. */
    //#define BLE_GATT_ATT_MTU_DEFAULT          23																		 /**< Length of handle inside Glucose Measurement packet. */
    //#define MAX_GLM_LEN   (BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH) /**< Maximum size of a transmitted Glucose Measurement. */
    #define GLS_NACK_PROC_ALREADY_IN_PROGRESS   BLE_GATT_STATUS_ATTERR_APP_BEGIN + 0 /**< Reply when a requested procedure is already in progress. */
    #define GLS_NACK_CCCD_IMPROPERLY_CONFIGURED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 1 /**< Reply when the a s CCCD is improperly configured. */
    /**@brief Glucose Service communication state. */
    typedef enum
        STATE_NO_COMM,                                                     /**< The service is not in a communicating state. */
        STATE_RACP_PROC_ACTIVE,                                            /**< Processing requested data. */
        STATE_RACP_RESPONSE_PENDING,                                       /**< There is a RACP indication waiting to be sent. */
        STATE_RACP_RESPONSE_IND_VERIF                                      /**< Waiting for a verification of a RACP indication. */
    } gls_state_t;
    static gls_state_t      m_gls_state;                                   /**< Current communication state. */
    //was: static uint16_t         m_next_seq_num;                                /**< Sequence number of the next database record. */
    static uint8_t          m_racp_proc_operator;                          /**< Operator of current request. */
    static uint16_t         m_racp_proc_seq_num;                           /**< Sequence number of current request. */
    static uint16_t          m_racp_proc_record_ndx;                        /**< Current record index. */
    static uint16_t          m_racp_proc_records_reported;                  /**< Number of reported records. */
    static uint16_t          m_racp_proc_records_reported_since_txcomplete; /**< Number of reported records since last TX_COMPLETE event. */
    static ble_racp_value_t m_pending_racp_response;                       /**< RACP response to be sent. */
    static uint8_t          m_pending_racp_response_operand[2];            /**< Operand of RACP response to be sent. */
    /**@brief Function for setting the GLS communication state.
     * @param[in] new_state  New communication state.
    static void state_set(gls_state_t new_state)
        m_gls_state = new_state;
    /**@brief Function for setting the next sequence number by reading the last record in the data base.
     * @return NRF_SUCCESS on successful initialization of service, otherwise an error code.
    //static uint32_t next_sequence_number_set(void)
    //    uint16_t      num_records;
    //    ble_gls_rec_t rec;
    //    num_records = ble_gls_db_num_records_get();
    //    if (num_records > 0)
    //        // Get last record
    //        uint32_t err_code = ble_gls_db_record_get(num_records - 1, &rec);
    //        if (err_code != NRF_SUCCESS)
    //            return err_code;
    //        m_next_seq_num = rec.meas.sequence_number + 1;
    //    else
    //        m_next_seq_num = 0;
    //    return NRF_SUCCESS;
    /**@brief Function for encoding a Glucose measurement.
     * @param[in]  p_meas            Measurement to be encoded.
     * @param[out] p_encoded_buffer  Pointer to buffer where the encoded measurement is to be stored.
     * @return Size of encoded measurement.
    static uint8_t gls_meas_encode(const ble_gls_meas_t * p_meas, uint8_t * p_encoded_buffer)
        uint8_t len = 0;
        p_encoded_buffer[len++] = p_meas->flags;
        len += uint16_encode(p_meas->sequence_number, &p_encoded_buffer[len]);
        len += ble_date_time_encode(&p_meas->base_time, &p_encoded_buffer[len]);
        if (p_meas->flags & BLE_GLS_MEAS_FLAG_TIME_OFFSET)
            len += uint16_encode(p_meas->time_offset, &p_encoded_buffer[len]);
        if (p_meas->flags & BLE_GLS_MEAS_FLAG_CONC_TYPE_LOC)
            uint16_t encoded_concentration;
            encoded_concentration = ((p_meas->glucose_concentration.exponent << 12) & 0xF000) |
                                    ((p_meas->glucose_concentration.mantissa <<  0) & 0x0FFF);
            p_encoded_buffer[len++] = (uint8_t)(encoded_concentration);
            p_encoded_buffer[len++] = (uint8_t)(encoded_concentration >> 8);
            p_encoded_buffer[len++] = (p_meas->sample_location << 4) | (p_meas->type & 0x0F);
        if (p_meas->flags & BLE_GLS_MEAS_FLAG_SENSOR_STATUS)
            len += uint16_encode(p_meas->sensor_status_annunciation, &p_encoded_buffer[len]);
        return len;
     * @param[in]  p_meas_ctx        Context to be encoded.
     * @param[out] p_encoded_buffer  Pointer to buffer where the encoded context is to be stored.
    static uint8_t gls_ctx_encode(const ble_gls_meas_context_t * p_meas_ctx, uint8_t * p_encoded_buffer)
        uint8_t len = 0;
        p_encoded_buffer[len++] = p_meas_ctx->flags;
        len += uint16_encode(p_meas_ctx->sequence_number, &p_encoded_buffer[len]);
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_EXT)
            p_encoded_buffer[len++] = p_meas_ctx->extended_flags;
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_CARB)
            p_encoded_buffer[len++] = p_meas_ctx->carbohydrate_id;
            uint16_t encoded_carbohydrate_id;
            encoded_carbohydrate_id = ((p_meas_ctx->carbohydrate.exponent << 12) & 0xF000) |
                                    ((p_meas_ctx->carbohydrate.mantissa <<  0) & 0x0FFF);
            p_encoded_buffer[len++] = (uint8_t)(encoded_carbohydrate_id);
            p_encoded_buffer[len++] = (uint8_t)(encoded_carbohydrate_id >> 8);
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_MEAL)
            p_encoded_buffer[len++] = p_meas_ctx->meal;
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_TESTER)
            p_encoded_buffer[len++] = p_meas_ctx->tester_and_health;
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_EXERCISE)
            len += uint16_encode(p_meas_ctx->exercise_duration , &p_encoded_buffer[len]);
            p_encoded_buffer[len++] = p_meas_ctx->exercise_intensity;
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_MED)
            p_encoded_buffer[len++] = p_meas_ctx->medication_id;
            if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_MED_KG)
                uint16_t encoded_medication;
                encoded_medication = ((p_meas_ctx->carbohydrate.exponent << 12) & 0xF000) |
                p_encoded_buffer[len++] = (uint8_t)(encoded_medication);
                p_encoded_buffer[len++] = (uint8_t)(encoded_medication >> 8);
            if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_MED_L)
                encoded_concentration = ((p_meas_ctx->carbohydrate.exponent << 12) & 0xF000) |
        if (p_meas_ctx->flags & BLE_GLS_CONTEXT_FLAG_HBA1C)
            uint16_t encoded_hba1c;
            encoded_hba1c = ((p_meas_ctx->carbohydrate.exponent << 12) & 0xF000) |
            p_encoded_buffer[len++] = (uint8_t)(encoded_hba1c);
            p_encoded_buffer[len++] = (uint8_t)(encoded_hba1c >> 8);
        return len;
    /**@brief Function for adding the characteristic for a glucose measurement.
     * @param[in] p_gls  Service instance.
     * @return NRF_SUCCESS if characteristic was successfully added, otherwise an error code.
    static uint32_t glucose_measurement_char_add(ble_gls_t * p_gls)
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        //ble_gatts_attr_t    attr_char_value2;
        ble_uuid_t          ble_uuid;
        //ble_uuid_t          ble_uuid2;
        ble_gatts_attr_md_t attr_md;
        ble_gls_rec_t       initial_gls_rec_value;
        uint8_t             encoded_gls_meas[MAX_GLM_LEN];
        //uint8_t             encoded_gls_measContext[MAX_GLM_LEN];
        uint8_t             num_recs;
        memset(&cccd_md, 0, sizeof(cccd_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&cccd_md.write_perm);
        cccd_md.vloc = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.notify = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_GLUCOSE_MEASUREMENT_CHAR);
        //BLE_UUID_BLE_ASSIGN(ble_uuid2, BLE_UUID_GLUCOSE_MEASUREMENT_CONTEXT_CHAR);
        memset(&attr_md, 0, sizeof(attr_md));
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
        attr_md.vloc    = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth = 0;
        attr_md.wr_auth = 0;
        attr_md.vlen    = 1;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
       // memset(&attr_char_value2, 0, sizeof(attr_char_value2));
        memset(&initial_gls_rec_value, 0, sizeof(initial_gls_rec_value));
        num_recs = ble_gls_db_num_records_get();
        if (num_recs > 0)
            uint32_t err_code = ble_gls_db_record_get(num_recs - 1, &initial_gls_rec_value);
                return err_code;
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = gls_meas_encode(&initial_gls_rec_value.meas, encoded_gls_meas);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = MAX_GLM_LEN;
        attr_char_value.p_value   = encoded_gls_meas;
        return sd_ble_gatts_characteristic_add(p_gls->service_handle,
                                               &char_md,
                                               &attr_char_value,
                                               &p_gls->glm_handles);
    //    attr_char_value2.p_uuid    = &ble_uuid2;
    //    attr_char_value2.p_attr_md = &attr_md;
    //    //attr_char_value2.init_len  = gls_meas_encode(&initial_gls_rec_value.context, encoded_gls_measContext);
    //    attr_char_value2.init_len  = 0;
    //    attr_char_value2.init_offs = 0;
    //    attr_char_value2.max_len   = MAX_GLM_LEN;
    //    attr_char_value2.p_value   = encoded_gls_measContext;
    //    return sd_ble_gatts_characteristic_add(p_gls->service_handle,
    //                                           &char_md,
    //                                           &attr_char_value2,
    //                                           &p_gls->glm_context_handles);
    static uint32_t glucose_context_char_add(ble_gls_t * p_gls)
        uint8_t             num_recs;
        BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_GLUCOSE_MEASUREMENT_CONTEXT_CHAR);
        attr_md.vlen    = 1;
        if (num_recs > 0)
                return err_code;
                                               &char_md,
                                               &attr_char_value,
    /**@brief Function for adding the characteristic for a glucose feature.
    static uint32_t glucose_feature_char_add(ble_gls_t * p_gls)
        uint8_t             encoded_initial_feature[2];
        char_md.char_props.read  = 1;
        char_md.p_cccd_md        = NULL;
        BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_GLUCOSE_FEATURE_CHAR);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&attr_md.read_perm);
        attr_md.vlen    = 0;
        encoded_initial_feature[0] = (uint8_t)(p_gls->feature);
        encoded_initial_feature[1] = (uint8_t)((p_gls->feature) >> 8);
        attr_char_value.init_len  = sizeof (uint16_t);
        attr_char_value.max_len   = sizeof (uint16_t);
        attr_char_value.p_value   = encoded_initial_feature;
                                               &char_md,
                                               &attr_char_value,
                                               &p_gls->glf_handles);
    /**@brief Function for adding the characteristic for a record access control point.
    static uint32_t record_access_control_point_char_add(ble_gls_t * p_gls)
        char_md.char_props.indicate = 1;
        char_md.char_props.write    = 1;
        BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_RECORD_ACCESS_CONTROL_POINT_CHAR);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&attr_md.write_perm);
        attr_md.wr_auth = 1;
        attr_md.vlen    = 1;
        attr_char_value.init_len  = 0;
        attr_char_value.max_len   = BLE_L2CAP_MTU_DEF;
        //attr_char_value.max_len   = BLE_GATT_ATT_MTU_DEFAULT; //Scott
        attr_char_value.p_value   = 0;
                                               &char_md,
                                               &attr_char_value,
                                               &p_gls->racp_handles);
    uint32_t ble_gls_init(ble_gls_t * p_gls, const ble_gls_init_t * p_gls_init)
        uint32_t   err_code;
        // Initialize data base
        err_code = ble_gls_db_init();
            return err_code;
        //was managed, now PL managd
    //    err_code = next_sequence_number_set();
    //        return err_code;
        // Initialize service structure
        p_gls->evt_handler          = p_gls_init->evt_handler;
        p_gls->error_handler        = p_gls_init->error_handler;
        p_gls->feature              = p_gls_init->feature;
        p_gls->is_context_supported = p_gls_init->is_context_supported;
        p_gls->conn_handle          = BLE_CONN_HANDLE_INVALID;
        // Initialize global variables
        state_set(STATE_NO_COMM);
        m_racp_proc_records_reported_since_txcomplete = 0;
        // Add service
        BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_GLUCOSE_SERVICE);
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_gls->service_handle);
            return err_code;
        // Add glucose measurement characteristic
        err_code = glucose_measurement_char_add(p_gls);
            return err_code;
        err_code = glucose_context_char_add(p_gls);
            return err_code;
        // Add glucose measurement feature characteristic
        err_code = glucose_feature_char_add(p_gls);
            return err_code;
        // Add record control access point characteristic
        err_code = record_access_control_point_char_add(p_gls);
            return err_code;
        return NRF_SUCCESS;
    /**@brief Function for sending a response from the Record Access Control Point.
     * @param[in] p_racp_val  RACP value to be sent.
    static void racp_send(ble_gls_t * p_gls, ble_racp_value_t * p_racp_val)
        uint8_t                encoded_resp[25];
        uint8_t                len;
        uint16_t               hvx_len;
        ble_gatts_hvx_params_t hvx_params;
        if (
            (m_gls_state != STATE_RACP_RESPONSE_PENDING)
            (m_racp_proc_records_reported_since_txcomplete > 0)
            state_set(STATE_RACP_RESPONSE_PENDING);
            return;
        // Send indication
        len     = ble_racp_encode(p_racp_val, encoded_resp);
        hvx_len = len;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_gls->racp_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_INDICATION;
        hvx_params.offset = 0;
        hvx_params.p_len  = &hvx_len;
        hvx_params.p_data = encoded_resp;
        err_code = sd_ble_gatts_hvx(p_gls->conn_handle, &hvx_params);
        // Error handling
        if ((err_code == NRF_SUCCESS) && (hvx_len != len))
            err_code = NRF_ERROR_DATA_SIZE;
        switch (err_code)
            case NRF_SUCCESS:
                // Wait for HVC event
                state_set(STATE_RACP_RESPONSE_IND_VERIF);
        	    //NRF_LOG_INFO("racp_send-NRF_SUCCESS.\r\n");
            case BLE_ERROR_NO_TX_PACKETS:
            case NRF_ERROR_RESOURCES:
                // Wait for TX_COMPLETE event to retry transmission
            case NRF_ERROR_INVALID_STATE:
                // Make sure state machine returns to the default state
                // Report error to application
                if (p_gls->error_handler != NULL)
                    p_gls->error_handler(err_code);
    /**@brief Function for sending a RACP response containing a Response Code Op Code and a Response Code Value.
     * @param[in] opcode  RACP Op Code.
     * @param[in] value   RACP Response Code Value.
    static void racp_response_code_send(ble_gls_t * p_gls, uint8_t opcode, uint8_t value)
        m_pending_racp_response.opcode      = RACP_OPCODE_RESPONSE_CODE;
        m_pending_racp_response.operator    = RACP_OPERATOR_NULL;
        m_pending_racp_response.operand_len = 2;
        m_pending_racp_response.p_operand   = m_pending_racp_response_operand;
        m_pending_racp_response_operand[0] = opcode;
        m_pending_racp_response_operand[1] = value;
        racp_send(p_gls, &m_pending_racp_response);
    /**@brief Function for sending a glucose measurement/context.
     * @param[in] p_rec  Measurement to be sent.
     * @return NRF_SUCCESS on success, otherwise an error code.
    static uint32_t glucose_meas_send(ble_gls_t * p_gls, ble_gls_rec_t * p_rec)
        uint8_t                encoded_glm[MAX_GLM_LEN];
        uint16_t               len;
        uint16_t               hvx_len;
        //NRF_LOG_INFO("glucose_meas_send start.\r\n");
        len     = gls_meas_encode(&p_rec->meas, encoded_glm);
        hvx_len = len;
        memset(&hvx_params, 0, sizeof (hvx_params));
        hvx_params.handle = p_gls->glm_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.p_data = encoded_glm;
        if (err_code == NRF_SUCCESS)
            if (hvx_len != len)
                NRF_LOG_INFO("glucose_meas_send err code= NRF_ERROR_DATA_SIZE send1.\r\n");
                return err_code; //moved to here
    //        else
    //            return err_code; //move to above, exit on error ! Otherwise continue and send notif
            p_rec->context.sequence_number = p_rec->meas.sequence_number;
            len     = gls_ctx_encode(&p_rec->context, encoded_glm);
            hvx_len = len;
            hvx_params.handle = p_gls->glm_context_handles.value_handle;
                if (hvx_len != len)
                    NRF_LOG_INFO("glucose_meas_send err code= NRF_ERROR_DATA_SIZE send2.\r\n");
                    return NRF_ERROR_DATA_SIZE;
    //            else
    //            	return err_code; //bad, removed, returns when no error !
                // Measurement successfully sent
                m_racp_proc_records_reported++;
                m_racp_proc_records_reported_since_txcomplete++;
            return err_code;
    /**@brief Function for responding to the ALL operation.
    static uint32_t racp_report_records_all(ble_gls_t * p_gls)
        uint16_t total_records = ble_gls_db_num_records_get();
        if (m_racp_proc_record_ndx >= total_records)
            uint32_t      err_code;
            ble_gls_rec_t rec;
            err_code = ble_gls_db_record_get(m_racp_proc_record_ndx, &rec);
            	NRF_LOG_INFO("ble_gls_db_record_get error:%d\r\n",err_code);
                return err_code;
            err_code = glucose_meas_send(p_gls, &rec);
            	NRF_LOG_INFO("glucose_meas_send error:%d\r\n",err_code);
                return err_code;
        //NRF_LOG_INFO("ALL send OK.\r\n");
        return NRF_SUCCESS;
    /**@brief Function for responding to the FIRST or the LAST operation.
    static uint32_t racp_report_records_first_last(ble_gls_t * p_gls)
        uint32_t      err_code;
        ble_gls_rec_t rec;
        uint16_t      total_records;
        if ((m_racp_proc_records_reported != 0) || (total_records == 0))
            //NRF_LOG_INFO("got 1st/last rec already, set state.\r\n");
            if (m_racp_proc_operator == RACP_OPERATOR_FIRST)
                err_code = ble_gls_db_record_get(0, &rec);
                    return err_code;
            else if (m_racp_proc_operator == RACP_OPERATOR_LAST)
                err_code = ble_gls_db_record_get(total_records - 1, &rec);
                    return err_code;
                return err_code;
        //NRF_LOG_INFO("First/Last send OK.\r\n");
        return NRF_SUCCESS;
    /**@brief Function for responding to the GREATER_OR_EQUAL operation.
    static uint32_t racp_report_records_greater_or_equal(ble_gls_t * p_gls)
        while (m_racp_proc_record_ndx < total_records)
            uint32_t      err_code;
            ble_gls_rec_t rec;
                return err_code;
            if (rec.meas.sequence_number >= m_racp_proc_seq_num)
                    return err_code;
                    return err_code;
            m_racp_proc_record_ndx++;
        if (m_racp_proc_record_ndx == total_records)
        return NRF_SUCCESS;
    /**@brief Function for informing that the REPORT RECORDS procedure is completed.
    static void racp_report_records_completed(ble_gls_t * p_gls)
        uint8_t resp_code_value;
        if (m_racp_proc_records_reported > 0)
            resp_code_value = RACP_RESPONSE_SUCCESS;
            resp_code_value = RACP_RESPONSE_NO_RECORDS_FOUND;
        racp_response_code_send(p_gls, RACP_OPCODE_REPORT_RECS, resp_code_value);
    /**@brief Function for the RACP report records procedure.
    static void racp_report_records_procedure(ble_gls_t * p_gls)
        uint32_t err_code;
        uint8_t firstlast = 0;
        while (m_gls_state == STATE_RACP_PROC_ACTIVE)
            // Execute requested procedure
            switch (m_racp_proc_operator)
                case RACP_OPERATOR_ALL:
                    err_code = racp_report_records_all(p_gls);
                case RACP_OPERATOR_FIRST:
                case RACP_OPERATOR_LAST:
                	firstlast = 1;
                    err_code = racp_report_records_first_last(p_gls);
                case RACP_OPERATOR_GREATER_OR_EQUAL:
                    err_code = racp_report_records_greater_or_equal(p_gls);
                        p_gls->error_handler(NRF_ERROR_INTERNAL);
                    return;
            // Error handling
            switch (err_code)
                case NRF_SUCCESS:
                    if (m_gls_state == STATE_RACP_PROC_ACTIVE)
                    	if (firstlast == 1)
                            racp_report_records_completed(p_gls);
                    		return;
                            NRF_LOG_INFO("m_racp_proc_record_ndx = %d.\r\n", m_racp_proc_record_ndx);
            		m_racp_proc_record_ndx++; //added to fix retries not needed
                    NRF_LOG_INFO("BLE_ERROR_NO_TX_PACKETS: m_racp_proc_record_ndx = %d.\r\n", m_racp_proc_record_ndx);
                    return;
                    // Wait for TX_COMPLETE event to resume transmission
                    return;
                    // Notification is probably not enabled. Ignore request.
                    return;
                    return;
    /**@brief Function for testing if the received request is to be executed.
     * @param[in]  p_racp_request   Request to be checked.
     * @param[out] p_response_code  Response code to be sent in case the request is rejected.
     *                              RACP_RESPONSE_RESERVED is returned if the received message is
     *                              to be rejected without sending a response.
     * @return TRUE if the request is to be executed, FALSE if it is to be rejected.
     *         If it is to be rejected, p_response_code will contain the response code to be
     *         returned to the central.
    static bool is_request_to_be_executed(const ble_racp_value_t * p_racp_request,
                                          uint8_t                * p_response_code)
        *p_response_code = RACP_RESPONSE_RESERVED;
        if (p_racp_request->opcode == RACP_OPCODE_ABORT_OPERATION)
                if (p_racp_request->operator != RACP_OPERATOR_NULL)
                    *p_response_code = RACP_RESPONSE_INVALID_OPERATOR;
                else if (p_racp_request->operand_len != 0)
                    *p_response_code = RACP_RESPONSE_INVALID_OPERAND;
                    *p_response_code = RACP_RESPONSE_SUCCESS;
                *p_response_code = RACP_RESPONSE_ABORT_FAILED;
        else if (m_gls_state != STATE_NO_COMM)
            return false;
        // Supported opcodes.
        else if ((p_racp_request->opcode == RACP_OPCODE_REPORT_RECS) ||
                 (p_racp_request->opcode == RACP_OPCODE_REPORT_NUM_RECS))
            switch (p_racp_request->operator)
                // Operators WITHOUT a filter.
                // Operators WITH a filter.
                    if (p_racp_request->p_operand[0] == OPERAND_FILTER_TYPE_SEQ_NUM)
                        if (p_racp_request->operand_len != 3)
                    else if (p_racp_request->p_operand[0] == OPERAND_FILTER_TYPE_FACING_TIME)
                        *p_response_code = RACP_RESPONSE_OPERAND_UNSUPPORTED;
                    else if (p_racp_request->p_operand[0] >= OPERAND_FILTER_TYPE_RFU_START)
                // Unsupported operators.
                case RACP_OPERATOR_LESS_OR_EQUAL:
                case RACP_OPERATOR_RANGE:
                    *p_response_code = RACP_RESPONSE_OPERATOR_UNSUPPORTED;
                // Invalid operators.
                case RACP_OPERATOR_NULL:
                    if (p_racp_request->operator >= RACP_OPERATOR_RFU_START)
        // Unsupported opcodes,
        else if (p_racp_request->opcode == RACP_OPCODE_DELETE_RECS)
            *p_response_code = RACP_RESPONSE_OPCODE_UNSUPPORTED;
        // Unknown opcodes.
        // NOTE: The computation of the return value will change slightly when deferred write has been
        //       implemented in the stack.
        return (*p_response_code == RACP_RESPONSE_RESERVED);
    /**@brief Function for processing a REPORT RECORDS request.
     * @param[in] p_racp_request  Request to be executed.
    static void report_records_request_execute(ble_gls_t * p_gls, ble_racp_value_t * p_racp_request)
        uint16_t seq_num = (p_racp_request->p_operand[2] << 8) | p_racp_request->p_operand[1];
        state_set(STATE_RACP_PROC_ACTIVE);
        m_racp_proc_record_ndx       = 0;
        m_racp_proc_operator         = p_racp_request->operator;
        m_racp_proc_records_reported = 0;
        m_racp_proc_seq_num          = seq_num;
        racp_report_records_procedure(p_gls);
    /**@brief Function for processing a REPORT NUM RECORDS request.
    static void report_num_records_request_execute(ble_gls_t * p_gls, ble_racp_value_t * p_racp_request)
        num_records   = 0;
        if (p_racp_request->operator == RACP_OPERATOR_ALL)
            num_records = total_records;
        else if (p_racp_request->operator == RACP_OPERATOR_GREATER_OR_EQUAL)
            uint16_t seq_num;
            uint16_t i;
            for (i = 0; i < total_records; i++)
                uint32_t      err_code;
                ble_gls_rec_t rec;
                err_code = ble_gls_db_record_get(i, &rec);
                    return;
                if (rec.meas.sequence_number >= seq_num)
                    num_records++;
        else if ((p_racp_request->operator == RACP_OPERATOR_FIRST) ||
                 (p_racp_request->operator == RACP_OPERATOR_LAST))
            if (total_records > 0)
                num_records = 1;
        m_pending_racp_response.opcode      = RACP_OPCODE_NUM_RECS_RESPONSE;
        m_pending_racp_response.operand_len = sizeof(uint16_t);
        m_pending_racp_response_operand[0] = num_records & 0xFF;
        m_pending_racp_response_operand[1] = num_records >> 8;
    /**@brief Function for checking if the CCCDs are configured.
     * @param[in] p_are_cccd_configured  boolean indicating if both cccds are configured
    uint32_t ble_gls_are_cccd_configured(ble_gls_t * p_gls, bool * p_are_cccd_configured)
        uint32_t err_code;
        uint8_t  cccd_value_buf[BLE_CCCD_VALUE_LEN];
        bool     is_glm_notif_enabled  = false;
        bool     is_racp_indic_enabled = false;
        ble_gatts_value_t gatts_value;
        // Initialize value struct.
        memset(&gatts_value, 0, sizeof(gatts_value));
        gatts_value.len     = BLE_CCCD_VALUE_LEN;
        gatts_value.offset  = 0;
        gatts_value.p_value = cccd_value_buf;
        err_code = sd_ble_gatts_value_get(p_gls->conn_handle,
                p_gls->glm_handles.cccd_handle,
                &gatts_value);
    return err_code;
    is_glm_notif_enabled = ble_srv_is_notification_enabled(cccd_value_buf);
                                          p_gls->glm_context_handles.cccd_handle,
                                          &gatts_value);
            return err_code;
                                          p_gls->racp_handles.cccd_handle,
                                          &gatts_value);
            return err_code;
        is_racp_indic_enabled = ble_srv_is_indication_enabled(cccd_value_buf);
        if (is_racp_indic_enabled & is_glm_notif_enabled)
            *p_are_cccd_configured = true;
            *p_are_cccd_configured = false;
        return NRF_SUCCESS;
    /**@brief Function for handling a write event to the Record Access Control Point.
     * @param[in] p_evt_write  WRITE event to be handled.
    static void on_racp_value_write(ble_gls_t * p_gls, ble_gatts_evt_write_t * p_evt_write)
        ble_racp_value_t                      racp_request;
        uint8_t                               response_code;
        ble_gatts_rw_authorize_reply_params_t auth_reply;
        bool                                  are_cccd_configured;
        uint32_t                              err_code;
        auth_reply.type                = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
        auth_reply.params.write.offset = 0;
        auth_reply.params.write.len    = 0;
        auth_reply.params.write.p_data = NULL;
        err_code = ble_gls_are_cccd_configured(p_gls, &are_cccd_configured);
            return;
        if (!are_cccd_configured)
            auth_reply.params.write.gatt_status = GLS_NACK_CCCD_IMPROPERLY_CONFIGURED;
            err_code                            = sd_ble_gatts_rw_authorize_reply(p_gls->conn_handle,
        &auth_reply);
            return;
        // Decode request.
        ble_racp_decode(p_evt_write->len, p_evt_write->data, &racp_request);
        // Check if request is to be executed.
        if (is_request_to_be_executed(&racp_request, &response_code))
            auth_reply.params.write.gatt_status = BLE_GATT_STATUS_SUCCESS;
            auth_reply.params.write.update      = 1;
                                                       &auth_reply);
                return;
            // Execute request.
            if (racp_request.opcode == RACP_OPCODE_REPORT_RECS)
                report_records_request_execute(p_gls, &racp_request);
            else if (racp_request.opcode == RACP_OPCODE_REPORT_NUM_RECS)
                report_num_records_request_execute(p_gls, &racp_request);
        else if (response_code != RACP_RESPONSE_RESERVED)
        &auth_reply);
                return;
            // Abort any running procedure.
            // Respond with error code.
            racp_response_code_send(p_gls, racp_request.opcode, response_code);
            auth_reply.params.write.gatt_status = GLS_NACK_PROC_ALREADY_IN_PROGRESS;
        &auth_reply);
                return;
    /**@brief Function for handling the Glucose measurement CCCD write event.
    static void on_glm_cccd_write(ble_gls_t * p_gls, ble_gatts_evt_write_t * p_evt_write)
        if (p_evt_write->len == 2)
            // CCCD written, update notification state
            ble_gls_evt_t evt;
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                evt.evt_type = BLE_GLS_EVT_NOTIFICATION_ENABLED;
                evt.evt_type = BLE_GLS_EVT_NOTIFICATION_DISABLED;
            if (p_gls->evt_handler != NULL)
                p_gls->evt_handler(p_gls, &evt);
    /**@brief Function for handling the WRITE event.
     * @details Handles WRITE events from the BLE stack.
     * @param[in] p_gls      Glucose Service structure.
     * @param[in] p_ble_evt  Event received from the BLE stack.
    static void on_write(ble_gls_t * p_gls, ble_evt_t * p_ble_evt)
        ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        if (p_evt_write->handle == p_gls->glm_handles.cccd_handle)
            on_glm_cccd_write(p_gls, p_evt_write);
        else if (p_evt_write->handle == p_gls->racp_handles.value_handle)
            on_racp_value_write(p_gls, p_evt_write);
    /**@brief Function for handling the TX_COMPLETE event.
     * @details Handles TX_COMPLETE events from the BLE stack.
    static void on_tx_complete(ble_gls_t * p_gls, ble_evt_t * p_ble_evt)
        if (m_gls_state == STATE_RACP_RESPONSE_PENDING)
        else if (m_gls_state == STATE_RACP_PROC_ACTIVE)
    /**@brief Function for handling the HVC event.
     * @details Handles HVC events from the BLE stack.
    static void on_hvc(ble_gls_t * p_gls, ble_evt_t * p_ble_evt)
        ble_gatts_evt_hvc_t * p_hvc = &p_ble_evt->evt.gatts_evt.params.hvc;
        if (p_hvc->handle == p_gls->racp_handles.value_handle)
            if (m_gls_state == STATE_RACP_RESPONSE_IND_VERIF)
                // Indication has been acknowledged. Return to default state.
                // We did not expect this event in this state. Report error to application.
                    p_gls->error_handler(NRF_ERROR_INVALID_STATE);
    static void on_rw_authorize_request(ble_gls_t * p_gls, ble_gatts_evt_t * p_gatts_evt)
        ble_gatts_evt_rw_authorize_request_t * p_auth_req = &p_gatts_evt->params.authorize_request;
        if (p_auth_req->type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
            if (   (p_gatts_evt->params.authorize_request.request.write.op
                    != BLE_GATTS_OP_PREP_WRITE_REQ)
                && (p_gatts_evt->params.authorize_request.request.write.op
                    != BLE_GATTS_OP_EXEC_WRITE_REQ_NOW)
                    != BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL)
                if (p_auth_req->request.write.handle == p_gls->racp_handles.value_handle)
                    on_racp_value_write(p_gls, &p_auth_req->request.write);
    void ble_gls_on_ble_evt(ble_gls_t * p_gls, ble_evt_t * p_ble_evt)
            case BLE_GAP_EVT_CONNECTED:
                //NRF_LOG_INFO("event recd: BLE_GAP_EVT_CONNECTED");
                p_gls->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
                //NRF_LOG_INFO("event recd: BLE_GAP_EVT_DISCONNECTED");
            case BLE_GATTS_EVT_WRITE:
                //NRF_LOG_INFO("event recd: BLE_GATTS_EVT_WRITE");
                on_write(p_gls, p_ble_evt);
            case BLE_EVT_TX_COMPLETE:
                NRF_LOG_INFO("BLE_GLS event recd: BLE_EVT_TX_COMPLETE");
                on_tx_complete(p_gls, p_ble_evt);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                NRF_LOG_INFO("event recd: BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST");
                on_rw_authorize_request(p_gls, &p_ble_evt->evt.gatts_evt);
            case BLE_GATTS_EVT_HVC:
                //NRF_LOG_INFO("event recd: BLE_GATTS_EVT_HVC");
                on_hvc(p_gls, p_ble_evt);
                // No implementation needed.
    uint32_t ble_gls_glucose_new_meas(ble_gls_t * p_gls, ble_gls_rec_t * p_rec)
    	p_rec->meas.sequence_number = m_next_seq_num++;//7/13/17, todo: replace with call to get seqnum from future db !
        return ble_gls_db_record_add(p_rec);
    #endif // NRF_MODULE_ENABLED(BLE_GLS)
  • There is still an issue when TX error requires a resend, the last fix revealed this.
    I have another fix where a simple 20ms nrf_delay sleep is all that is required, which prevents the issue to begin with, negating the need to increment the counter when error TX bffer.
    Perhaps Nordic can fix this the correct way, else on request I can inform where to put this fix to replace the latest fix:
                    nrf_delay_ms(20); //pause to avoid tx buffer wait for TX complete, which causes issues, since good sends are called errors, causing resends
  • Attaching 3rd fix file to use a sleep to prevent issues, with prior fix commented out that prevents retries 99% not needed, but a few are needed.
    See line 972 commented out, and added 20ms sleep.
    Just ignore all else, and use the 3rd file to see what is needed. I hope a better fix can be done instead of the sleep which hides the issue. Maybe this was why this code was never completed to send meas contexts !
    Latest code here:
    * File   :	ble_gls.c
    * Revision History:
     * the file.
    /* Attention!
    #include <string.h>
    #include "nrf_delay.h"
    #include "nrf_gpio.h"
    typedef enum
    } gls_state_t;
    //            return err_code;
    //    else
        uint8_t len = 0;
        return len;
        uint8_t len = 0;
        return len;
        uint8_t             num_recs;
        attr_md.vlen    = 1;
        if (num_recs > 0)
                return err_code;
                                               &char_md,
                                               &attr_char_value,
    //                                           &char_md,
        uint8_t             num_recs;
        attr_md.vlen    = 1;
        if (num_recs > 0)
                return err_code;
                                               &char_md,
                                               &attr_char_value,
        attr_md.vlen    = 0;
                                               &char_md,
                                               &attr_char_value,
        attr_md.vlen    = 1;
                                               &char_md,
                                               &attr_char_value,
        uint32_t   err_code;
            return err_code;
    //        return err_code;
        // Add service
            return err_code;
            return err_code;
            return err_code;
            return err_code;
            return err_code;
        return NRF_SUCCESS;
        uint8_t                len;
        uint16_t               hvx_len;
        if (
            return;
        // Send indication
        hvx_len = len;
        // Error handling
        switch (err_code)
            case NRF_SUCCESS:
        uint16_t               len;
        uint16_t               hvx_len;
        hvx_len = len;
            if (hvx_len != len)
    //        else
            hvx_len = len;
                if (hvx_len != len)
    //            else
            return err_code;
            uint32_t      err_code;
            ble_gls_rec_t rec;
                return err_code;
                return err_code;
        return NRF_SUCCESS;
        uint32_t      err_code;
        ble_gls_rec_t rec;
                    return err_code;
                    return err_code;
                return err_code;
        return NRF_SUCCESS;
            uint32_t      err_code;
            ble_gls_rec_t rec;
                return err_code;
                    return err_code;
                    return err_code;
        return NRF_SUCCESS;
        uint32_t err_code;
                	firstlast = 1;
                    return;
            // Error handling
            switch (err_code)
                case NRF_SUCCESS:
                    	if (firstlast == 1)
                    		return;
            		//this fix stops all retries, but some may be needed, use sleep instead:
                	//m_racp_proc_record_ndx++; //added to fix retries not needed
                    return;
                    return;
                    return;
                    return;
            return false;
        // Unknown opcodes.
        num_records   = 0;
            uint16_t seq_num;
            uint16_t i;
                uint32_t      err_code;
                ble_gls_rec_t rec;
                    return;
                    num_records++;
                num_records = 1;
        uint32_t err_code;
                &gatts_value);
    return err_code;
                                          &gatts_value);
            return err_code;
                                          &gatts_value);
            return err_code;
        return NRF_SUCCESS;
        uint32_t                              err_code;
            return;
        &auth_reply);
            return;
        // Decode request.
                                                       &auth_reply);
                return;
            // Execute request.
        &auth_reply);
                return;
        &auth_reply);
                return;
            ble_gls_evt_t evt;
                NRF_LOG_INFO("\r\nSetting sustain to off 3.\r\n");
            	nrf_gpio_pin_write(PIO_SUSTAIN, false); 	//turning off sustain powers down GMA3
  • Attaching an updated fixed file.
    fixed missing records when RACP sends ALL records and gets error: BLE_ERROR_NO_TX_PACKETS, by adding return after each send  and then continuing after BLE_EVT_TX_COMPLETE event received, and added a 50ms sleep. Updated to only send context when context present.
    * File   :	ble_gls.c
    * Revision History:
    * 06/26/18  dlc     fixed missing records when RACP sends ALL records and gets error: BLE_ERROR_NO_TX_PACKETS, by adding return after each send
    *                   and then continuing after BLE_EVT_TX_COMPLETE event received, and added a 50ms sleep.
    * 06/27/18  dlc     using BLE_GLS_MEAS_FLAG_CONTEXT_INFO flag, don't send context notification if not present in p_rec->.meas.flags
     * the file.
    /* Attention!
    #include <string.h>
    typedef enum
    } gls_state_t;
    //            return err_code;
    //    else
        uint8_t len = 0;
        return len;
        uint8_t len = 0;
        return len;
        uint8_t             num_recs;
        attr_md.vlen    = 1;
        if (num_recs > 0)
                return err_code;
                                               &char_md,
                                               &attr_char_value,
    //                                           &char_md,
        uint8_t             num_recs;
        attr_md.vlen    = 1;
        if (num_recs > 0)
                return err_code;
                                               &char_md,
                                               &attr_char_value,
        attr_md.vlen    = 0;
                                               &char_md,
                                               &attr_char_value,
        attr_md.vlen    = 1;
                                               &char_md,
                                               &attr_char_value,
        uint32_t   err_code;
            return err_code;
    //        return err_code;
        // Add service
            return err_code;
            return err_code;
            return err_code;
            return err_code;
            return err_code;
        return NRF_SUCCESS;
        uint8_t                len;
        uint16_t               hvx_len;
        if (
            return;
        // Send indication
        hvx_len = len;
        // Error handling
        switch (err_code)
            case NRF_SUCCESS:
        uint16_t               len;
        uint16_t               hvx_len;
        hvx_len = len;
            if (hvx_len != len)
    //        else
            //test if context flag present, else bail
            if ((p_rec->meas.flags & BLE_GLS_MEAS_FLAG_CONTEXT_INFO) != 0x10)
            	return NRF_SUCCESS;
            hvx_len = len;
                if (hvx_len != len)
    //            else
            return err_code;
            uint32_t      err_code;
            ble_gls_rec_t rec;
                return err_code;
                return err_code;
        return NRF_SUCCESS;
        uint32_t      err_code;
        ble_gls_rec_t rec;
                    return err_code;
                    return err_code;
                return err_code;
        return NRF_SUCCESS;
            uint32_t      err_code;
            ble_gls_rec_t rec;
                return err_code;
                    return err_code;
                    return err_code;
        return NRF_SUCCESS;
        uint32_t err_code;
                	nrf_delay_ms(50); //sleep to avoid tx buffer wait for TX complete, which causes issues, since good sends are called errors, causing resends
                	firstlast = 1;
                    return;
            // Error handling
            switch (err_code)
                case NRF_SUCCESS:
                    	if (firstlast == 1)
                    		return;
                            return; //wait for BLE_EVT_TX_COMPLETE event to proceed
            		//this fix stops all retries, but some may be needed ? test:
                    return;
                    return;
                    return;
                    return;
            return false;
        // Unknown opcodes.
        num_records   = 0;
            uint16_t seq_num;
            uint16_t i;
                uint32_t      err_code;
                ble_gls_rec_t rec;
                    return;
                    num_records++;
                num_records = 1;
        uint32_t err_code;
                &gatts_value);
    return err_code;
                                          &gatts_value);
            return err_code;
                                          &gatts_value);
            return err_code;
        return NRF_SUCCESS;
        uint32_t                              err_code;
            return;
        &auth_reply);
            return;
        // Decode request.
                                                       &auth_reply);
                return;
            // Execute request.
        &auth_reply);
                return;
        &auth_reply);
                return;
            ble_gls_evt_t evt;
                //NRF_LOG_INFO("BLE_GLS event recd: BLE_EVT_TX_COMPLETE");
                //NRF_LOG_INFO("event recd: BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST");
