I am trying to make a beacon start advertising on a long press of a button. Using this as a reference, I implemented a timer as follows:
this is the flag to keep track of advertising status-
static bool advflag = false;
this is the handler and timer creation/start-
Note that, I am using m_timer_id which is a repeated timer for some other purpose. The timer used for the button is m_timer_b which is a single shot timer.
static void timer_b_handler(void * p_context)
uint32_t err_code;
if(nrf_gpio_pin_read(BSP_BUTTON_0)==0){
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
nrf_gpio_pin_toggle(BSP_LED_2);
// Create timers
static void create_timers()
uint32_t err_code;
// Create timers
err_code = app_timer_create(&m_timer_id,
APP_TIMER_MODE_REPEATED,
timer_a_handler);
err_code = app_timer_create(&m_timer_id_b,
APP_TIMER_MODE_SINGLE_SHOT,
timer_b_handler);
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
err_code = ble_advertising_restart_without_whitelist();
case BSP_EVENT_KEY_0:
//mark(first);
if(advflag==false){
err_code = app_timer_start(m_timer_id_b, APP_TIMER_TICKS(2000, APP_TIMER_PRESCALER),NULL);
I even made changes in the softdevice event handler-
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
advflag=true;
scan_start();
advflag=false;
scan_start();
// Pairing not supported
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(p_ble_evt);
case BLE_GAP_EVT_TIMEOUT:
if (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISING)
advflag = false; // If advertising times out
// No implementation needed.
What I have observed is that, when i press and hold the button, both LED! and LED3 flash once and the board does not do anything
(I'm assuming the device reset?.If so, i dont understand why, i assumed using the flag fixes the advertising while already advertising problem ).
But when i hold the button even after those 2 LEDs have flashed, the device works as required while i keep the button pressed.
I am using the nRF52832 development board, nRF5 SDK11.0 and keil uvision5
Any solutions to this would be appreciated.
Thank you.
