low power in advertising
About example BLE_uart,
My device must always remain in advertising, I'm using a 1280 ms between two advertisng event.
I have to minimize the consumption during advertining, and I need wake up the micro only with a bluetooth connection.
I do not need to keep the RAM / RTC on and the I / O ports must remain low.
Is BLE_uart an exaple of  best configuration regards the power consuption ?
Or I can improve switching off others peripherals ?
Marco
  • Hi Marco,
    the ble_app_uart example is a good starting point, but note that it enables the UART peripheral and the nRF Logging module.
    I assume that your using SDK 15, so in order to reduce the current consumption of the ble_app_uart example you will have to disable these, i.e. set the following defines in sdk_config.h
    NRF_LOG_ENABLED 0
    NRF_LOG_BACKEND_RTT_ENABLED 0
    and comment out
    uart_init();
    in main().
    A better choice might be to use the ble_app_template example which that does not enable logging or use any of the HW peripherals in the application code. It only advertises at a given interval and goes to low power mode in between advertisement events.
    Best regards
    Bjørn
