Issues programming my nRF51822 for the first time
Hello All,
I'm trying to program a NRF51822 module for the first time.Using Keil, Soft device s110_nrf51_8.0.0,soft device kit nRF51_SDK_9.0.0_2e23562 when I try to program  I get an success  message  but no blinking of the LED
Please see below. Any clues?
  • Hi Barus,
    I can still see that you are not using the SDK version I recommended.
    --> Please Download SDK v12.3.
     There should not be a problem for you using Keil.
    --> Since you are using the PCA20006 board you have to enable support for that board as shown here. (define 'BOARD_PCA20006' in C/C++, ASM)
    - And you don't need to flash the Softdevice if you are not using a BLE application. (which the regular blinky example is not)
  • OK thank you again
    and i have a new problem how can field it
    const uint8_t leds_list[LEDS_NUMBER] = LEDS_LIST;
  • What do you mean?
    When you define the PCA20006 you will see in "boards.h." that "pca20006.h" is included.
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    #ifndef PCA20006_H
    #define PCA20006_H
    #ifdef __cplusplus
    extern "C" {
    #include "nrf_gpio.h"
    // LEDs and buttons definition for PCA20006 board (beacon)
    #define LEDS_NUMBER    3
    #define LED_RGB_RED    16
    #define LED_RGB_GREEN  12
    #define LED_RGB_BLUE   15
    #define LEDS_ACTIVE_STATE 0
    #define BSP_LED_0 LED_RGB_RED
    #define BSP_LED_1 LED_RGB_GREEN
    #define BSP_LED_2 LED_RGB_BLUE
    #define LEDS_LIST { LED_RGB_RED, LED_RGB_GREEN, LED_RGB_BLUE}
    #define LEDS_INV_MASK  LEDS_MASK
    #define BUTTON_0       8
    #define BUTTON_1       18
    #define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
    #define BUTTONS_ACTIVE_STATE 0
    #define BSP_BUTTON_0   BUTTON_0
    #define BSP_BUTTON_1   BUTTON_1
    #define BUTTONS_NUMBER 2
    #define BUTTONS_LIST { BUTTON_0, BUTTON_1 }
    #define RX_PIN_NUMBER  24
    #define TX_PIN_NUMBER  9
    #define CTS_PIN_NUMBER 21
    #define RTS_PIN_NUMBER 11
    #define HWFC           true
    // Low frequency clock source to be used by the SoftDevice
    #ifdef S210
    #define NRF_CLOCK_LFCLKSRC      NRF_CLOCK_LFCLKSRC_XTAL_20_PPM
    #else
    #define NRF_CLOCK_LFCLKSRC      {.source = NRF_CLOCK_LF_SRC_XTAL, .rc_ctiv = 0, .rc_temp_ctiv = 0, .xtal_accuracy=NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM}
    #ifdef __cplusplus
