Issue sending data from UART over mesh
I've been working on a project where I need to send data from UART over mesh, I managed to create custom model for sending string data over mesh, I did merge UART example with mesh SDK, I started with light switch demo from mesh SDK v2.0.1 and with nRF5 SDK v15, now I'm trying to get the data received on UART to send it over mesh, but I didn't do it correctly, the send_my_message function kept sending the same random data, Any idea on how to make that work, it would be greatly appreciated.
Here is a snippet of my code:
//function to send data over mesh
void send_my_message (char s[])
    uint32_t status=0;
    uint8_t buffer[5];
    strcpy(buffer, (uint8_t) s);
    uint8_t length;
    uint16_t address;
    access_message_tx_t msg;
    length= sizeof(buffer);
               if (length)
                  msg.opcode.opcode = simple_message_OPCODE_SEND;
                  msg.opcode.company_id = 0x0059; // Nordic's company ID
                  msg.p_buffer = (const uint8_t *) &buffer[0];
                  msg.length =length;
                 status= simple_message_client_set_unreliable(&m_clients[0], buffer, length);
                 __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Status : %u \n", status);
                  if (status == NRF_ERROR_INVALID_STATE ||
                  status == NRF_ERROR_BUSY||status == NRF_ERROR_NO_MEM)
                     __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send. Device is busy.\n");
                      hal_led_blink_ms(LEDS_MASK, 50, 4);
                         ERROR_CHECK(status);
//function for receiving and sending data over UART
void uart_putstring(char s[])
       uint8_t len = strlen(s);
       for (uint8_t i = 0; i < len; i++)
       while (app_uart_put(s[i]) != NRF_SUCCESS);
void uart_getstring(char s[])
       while (app_uart_get(&s[i]) != NRF_SUCCESS);
//how I send the data over mesh from UART
printf("\r\nUART example started.\r\n");
    for (;;)
        (void)sd_app_evt_wait();
       // uint8_t cr;
        char s[5];
       uint32_t status = NRF_SUCCESS;
      // while (app_uart_get(&cr) != NRF_SUCCESS);
      // while (app_uart_put(cr) != NRF_SUCCESS);
      uart_getstring(s);
      uart_putstring(s);
       send_my_message(s); // failed to send data from UART
here is my log
Thank you,
A.
  • Hi Arji,
    Please try testing with sending an array of bytes. Don't play with string first.
    You can try to send something like
    uint8_t data_array = {1,2,3,4,5}
    And check on the other side if you receive 1 2 3 4 5 array or not. To print an array out , you can use a loop and print each element out.
    Main different between a string and byte array is the terminate character. In C it's the NULL character (0). But I don't think this char sent over mesh because of the length.
  • Hi again,
    I want the data that I receive on UART (string data) to send it over mesh, I tested with array of bytes as you said and it works, but in my case I want to get any data sent by pc terminal(termite) to send it over mesh, I did a lot of tests and nothing wrong with mesh, now I switch using this function  to get data from UART:
        if (p_event->evt_type == APP_UART_DATA_READY)
            s[Index++] =  cr;
            s[Index] = 0;
            if(cr == '\n')
                printf("RX end : %s\r\n", s);   //show nothing
                send_my_message(s); //fail here
                Index = 0;
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if(p_event->evt_type == APP_UART_FIFO_ERROR)
    So this function works fine when I don't add send_my_message() function as shown in line 11 above in code, but when add it,  it stuck and the function shows nothing
    here is result without send_my_message() function
    and here with send_my_message() function
    send_my_function() is mentioned in my previous comment, please help
    Thank you
  • Can you check what when wrong when you call send_my_message() ? any assertion ?
    Did the application run normally after that or it crashed ?
    How did you setup  __LOG  ? via RTT or UART ?
    If you printing out log via UART you will have a conflict with your printf.
    If you comment out printf do you receive the data on the other node in mesh ?
  • Here's what happen when I call send_my_message(), there is a softdevice assert and a warning:  mesh_softdevice_init.c,  104, sd_ble_enable: app_ram_base should be adjusted to 0x200032C8
    For the setup  __LOG, I'am not sure if you talk about this
    or the setup in sdk_config.h, actually I added the setup_config.h of the uart_example and add some defines from sdk_config.h of client example because I delete it from the project but in both files there is no defines for rtt or uart log enable, there is only nrf_log_enable which is set to 0
    If I comment out printf, I don't receive any data on the other node and still have the same problem
