Peripheral disconnects from central S120 after BLE_GAP_EVT_CONN_PARAM_UPDATE
I have set up a board using device_manager_central to connect with BTLE sensors. I have used a combination of the multilink example and the heart rate collector example along with my own code with the intention of being able to connect to multiple sensors at once.
Currently I can connect to the example heart rate monitor using a dev board but when trying to connect to an actual off the shelf heart rate monitor I keep getting disconnected after BLE_GAP_EVT_CONN_PARAM_UPDATE
With some debug in my code I get the following sequence output to my console:
PARAM_UPDATE_REQUEST
requested min_con = 800
requested max_con = 816
requested slave_lat = 0
requested sup_timeout = 600
ble event = 0x001d
conn_param_update err code = 0
ble event = 0x0012
ble event = 0x0012
[DM]: Notifying application of event 0x12
Disconnect code 8
DM_EVT DISCONNECTION
ble event = 0x0011
the ble event 0x0012 is described as BLE_GAP_EVT_CONN_PARAM_UPDATE which should signify that the paramaters requested have indeed been updated however after the update I get a disconnect code 8 which is BLE_HCI_CONNECTION_TIMEOUT
Is there something I need to handle after the BLE_GAP_EVT_CONN_PARAM_UPDATE event that I'm just not seeing?
