Is there any intention to add the the nRF52810 reference design to the Eagle library on github?
There are five Eagle design blocks already available on github, except for the nRF52810.
github.com/.../nrf5-eagle-reference-design
-thank-you
-thank-you
Eagle reference design for nRF52810 (QFAA, and QCAA) is now added to the git repo.
Hello Øystein,
I tried tenting the center pad ground vias and not sure if I'm misunderstanding how to do this,
but it seems that the Stop setting is checked for vias in the center pad for the design block (not sure if this is by design).
The typical DRC rule for Masks that have a via Limit smaller than 25mil will be covered in soldermask.
To uncheck Stop it seems its not possible in the design block, and have to swap the entire nrf52810 chip itself with new vias with no Stop checked.
Is the Stop checked by design? Tenting would be possible for the design block without the Stop.
thank-you,
Hi, sorry for the late reply.
No, the stop is not checked by design.
Then if Stop is not checked, something else is preventing tenting for the center pad vias.
(same for nrf52832 block)
I have the Limit set for 20mil, and all the other vias are tented (checked in oshpark)
Is there some other setting that I'm missing?
thank-you,
Sorry if my reply was unclear, "stop" is in fact checked. So removing stop in your design should fix it. In most other CAD software you can "explode" the part and modify the primitives directly. I do not know how this works in EAGLE.
But is was not checked on purpose, for some reason EAGLE checked it automatically, I have now removed "stop" from the footprint, but was not able to get the design block to reflect those changes.
