nRF51822 - atomic increment of a variable
Using:
  • GCC 4.8
  • pure-gcc Setup
  • Sdk 5.2.0
  • Softdevice 6.0
I execute some code within interrupt context (softdevice handler) and also in main thread. I need to increment / decrement an integer variable concurrent in both thread context (e.g. for some refcounted objects within my inter-thread communication).
Since we unfortunately have no __sync_add_and_fetch nor std::atomic on the M0 core, I have to synchronize the concurrent access in a different way.
1st approach using CRITICAL_REGION_ENTER/EXIT()
Currently, I synchronize the access using CRITICAL_REGION_ENTER/EXIT(), but it seems a bit brutally.
2nd approach using sd_mutex_…()
Might that be a better solution? What the costs (ram & runtime) for SD mutexes?
3nd approach disabling interrupts
In some places I'd read that it was a bad idea to disable interrupts during ble communication. Also a bad idea for the small time of just a int val = ++(*refcount); ?
Edit 2014-08-28: I'd now made further investigations into the 3 approaches.
CRITICAL_REGION_ENTER();
(*refcount)++;
CRITICAL_REGION_EXIT();
The duration of these instructions is about 25 µs.
sd_mutex
errCode = sd_mutex_acquire(&mutexHandle);
APP_ERROR_CHECK(errCode);
(*refcount)++;
errCode = sd_mutex_release(&mutexHandle);
The duration of these instructions is about 20 µs. But this approach won't work for my problem. sd_mutex_acquire() is not that kind of mutex lock we know from threading concurrency. The call is more like a »try lock«. If the mutex already is locked, then sd_mutex_acquire() returns with NRF_ERROR_SOC_MUTEX_ALREADY_TAKEN instead of passing control to the code which holds the lock (see here).
__disable_irq();
(*refcount)++;
__enable_irq();
The duration of these instructions is about 800 ns.
Finally, I decide to use CRITICAL_REGION_ENTER/EXIT() (even it's much slower than disabling irq) because I don't want to disturb the radio traffic. Since I like to have it in C++, I'd wrote a small RAII class based on the sdk macro code:
class CriticalSection {
public:
    explicit CriticalSection()
        :   intPrio(current_int_priority_get())
        ,   nested(0)
        if (intPrio != APP_IRQ_PRIORITY_HIGH) {
            uint32_t errCode = sd_nvic_critical_region_enter(&nested);
            if (errCode == NRF_ERROR_SOFTDEVICE_NOT_ENABLED)
                __disable_irq();
    ~CriticalSection() {
            __enable_irq();
            uint32_t errCode = sd_nvic_critical_region_exit(nested);
            if (errCode != NRF_ERROR_SOFTDEVICE_NOT_ENABLED)
    int getIntPrio() const { return intPrio; }
private:
    uint8_t intPrio;
    uint8_t nested;
And my code now looks like this:
    CriticalSection cs;
    (*refcount)++;
Edit: Please note that this don't work for nested critical sections when softdevice is disabled (see also this post).
Cheers, Joe
  • When you call sd_nvic_critical_region_enter() it'll disable all your application interrupts but doesn't affect softdevice interrupts. Why do you want to disable all interrupts including softdevice? Softdevice interrupts won't change your variable.
    I think the best way is to disable app interrupts in main on variable write.
  • I'd thought about __disable_irq() because of performance reasons (about 800ns against 25µs of critical region), but I now finally decide for critical region.
  • I dug inside the code of CRITICAL_REGION_ENTER/EXIT and studied how it works. During the ENTER: first it call __disable_irq(), then it disable all the APP IRQs, then call __enable_irq(). and in the EXIT it does the same stuff, of coure re-enabling the APP IRQs.
    So, for a very very small operation like the increment of a variable wouldn't it be better to use directly __disable_irq()/__enable_irq(), instead of having them called twice in the CRITICAL_REGION_ENTER/EXIT?
