Hi!
I use nrf51-pwm-library ( github.com/.../) to control brightness of LED RGB light source and it works ok till I don't want to adjust brightness slowly (dimming function).
When I use
nrf_pwm_set_value(channel->pwmChannel, channel->currentBrightness);
function - no matter using scheduler or simple in for loop
int counter = 0;
int brightnessChangeDelay = 2000;
for (;;)
if(counter++ >= brightnessChangeDelay)
counter = 0;
Led flickers.
I though that the problem is caused by updating compare register to fast, but looking at nrf_pwm.c I see that it's updated via naxt_pwm_val after timer interrupt.
What else can cause the glitches? I think that reason is not in the communication, because when it's dimming very slowly and device is already disconnected for a long time it also happens.
__
it look's like that:
in the middle is the moment, when I update the value... ;/
