BLE Antenna and capacitors
we are using the NRF52840 DK and we would like to use our own antenna. We saw on others posts that we have to connect it to the J1 connector's place.
 We have some doubts :
When we connect a multimeter (beeping mode) on the two sides of capacitors C22 it beeps, do you know why ? A capacitor is not supposed to beep, right ? That happens with a lot of others capacitors and we do not understand why.
Then, if we use the multimeter between the RF signal (left of connector J1) and ground (at the bottom of the connector J1) it also beeps. Is it normal ? should'nt it be isolated ?
Regarding the use of our own antenna, if we remove the J1 connector and directly connect our antenna to the RF signal, the actual antenna (ANT) will be disconnected right ?
Is there anything else we have to take into account in order to use our antenna ?
Thank you.
