All,
We are in product on a product using the nRF52832 and are noticing in manufacturing that we aren't able to make it through the self test part of fab because of shoddy RF communication. We sell many other products with the same chop that do pass so in looking for the differences we have found that routing a coax antenna cable across only certain parts of the chip have an effect. I didn't believe it when first brought to my attention but I have seen (at least small sample size) evidence that it may be an issue. Routing the COAX cable not over the chip seems to fix the issue, I want to know if this fix has a real hardware answer behind it.
An email from my team..
"Attached are the two photos, we seem to be able to duplicate our failure with the "noise" path. The failure of course shows as a CSMA collision avoidance failure. We have measured the noise floor on the clear path and it is about -95 dB; measured on the noise path and it can be up to -80 dB. The CSMA backoff level is set at -85 dB. We also were able to insert a piece of copper tape under to coax cable in the noise path and that "fixed" the problem. Routing the cable more across the center of the chip also seems to fix the problem. It seems to only exist when the cable is in the path shown. Best we can guess is we have some sort of ground or noise coupling going on.
