Reading TMP102 sensor data over i2c.
I'm a beginner on embedded field.
I am having a nrf51822 development kit & Starter Kit and a mbed HRM1017(including nrf51822). I tested mbed source code for advertising TMP102 sensor data. mbed.org/.../ It worked.
But I'd like to implement on nrf51822 development kit (pca10005). but i don't know how to read sensor data over I2C. I found only ds1624 code. I want TMP102 code.
Where should I start from?
Below Code didn't worked.
#define TMP102_ADDRESS (0x90 << 1)
    nrf_gpio_port_dir_set(NRF_GPIO_PORT_SELECT_PORT1, NRF_GPIO_PORT_DIR_OUTPUT);
 if (!twi_master_init())
     nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT1, 0x55);
     while (true)
         // Do nothing.
while(true)
    int8_t temperature;
    int8_t temperature_fraction;
        uint8_t data_buffer[2];
    //if (twi_master_transfer((uint8_t)TMP102_ADDRESS, 0x00, 1, TWI_DONT_ISSUE_STOP))
	    if (twi_master_transfer(TMP102_ADDRESS | TWI_READ_BIT, data_buffer, 2, TWI_ISSUE_STOP))
	    temperature = (int8_t)data_buffer[0];
	    temperature_fraction   = (int8_t)data_buffer[1];
	    nrf_gpio_port_clear(NRF_GPIO_PORT_SELECT_PORT1, 0x7F);
	    nrf_gpio_port_set(NRF_GPIO_PORT_SELECT_PORT1, (uint8_t)temperature);
	    nrf_delay_ms(100);
In twi config file, I set 24pin, 25pin. and I connected 24pin, 25pin, Vext, GND of NRF6310 to SCL, SDA, VCC, GNF of TMP102.
  • Hi Takoshi,
    is wrong (0x90 is already the 8-bit representation of the I2C address, 0x48 would be the equivalent 7-bit representation, shifting 0x90 left by one exceeds 8 bits).
    Try it with
    #define TMP102_ADDRESS 0x90
  • Hi Takoshi,
    Try it with
