BLE_GAP_SEC_STATUS_DHKEY_FAILURE when using size optimization on gcc
after migrating from SDK12.2 to SDK14.2 we encountered a problem with GAP Security.
When setting optimization to -Os, the program fails with BLE_GAP_EVT_AUTH_STATUS returning 0x8B (BLE_GAP_SEC_STATUS_DHKEY_FAILURE).
When using -O2 (or lower) which should be mostly the same as -Os except the size optimizations it works without error.
Since the micro-ecc/nrf52_armgcc folder no longer existed in SDK 14 we used nrf52nf_armgcc instead. We already noticed a difference between those versions.
While we were able to use the same generated ecc-lib on different systems with SDK 12, we now need to build it anew on each system. Maybe there is something else we need to consider after this change.
We are currently using GCC version 5.3.1 20160413
Thanks and best regards,
Niclas
  • Hi Niclas,
    It was necessary to add a softFP target of micro-ecc due to adding nRF52810, which has no hardFP, to the SDK.
    nrf52nf_armgcc is compiled with softFP, with flag -mfloat-abi=soft. If your firmware is running on nRF52832, with HardFP, you should try the nrf52hf_armgcc target.
    Q1: Is this failure behavior consistent, or "just once in a while"?
    Q2: Just to confirm: the peer_manager (and linked modules, like security manager etc) are taken from SDK 14 untouched?
    Håkon
  • Hi Håkon,
    as i recall it, we had some problems with the HardFP.
    A1: Yes it happens every time
    A2: Yes they are untouched
    Niclas
  • Hi Niclas,
    I tried to reproduce this with SDK v14.2 example ble_app_multirole_lesc, but I was unfortunately not able to. Here's my edited Makefile (rest of the example is as-is in v14.2):
    PROJECT_NAME     := ble_app_multirole_lesc_pca10040_s132
    TARGETS          := nrf52832_xxaa
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../../../..
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/nrf52832_xxaa.out: \
      LINKER_SCRIPT  := ble_app_multirole_lesc_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/components/libraries/bsp/bsp.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp_btn_ble.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp_nfc.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_rtt.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_uart.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_default_backends.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_str_formatter.c \
      $(SDK_ROOT)/components/libraries/button/app_button.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
      $(SDK_ROOT)/components/libraries/timer/app_timer.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/crc16/crc16.c \
      $(SDK_ROOT)/components/libraries/fds/fds.c \
      $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
      $(SDK_ROOT)/components/libraries/mem_manager/mem_manager.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \
      $(SDK_ROOT)/components/libraries/experimental_memobj/nrf_memobj.c \
      $(SDK_ROOT)/components/libraries/queue/nrf_queue.c \
      $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/components/libraries/util/sdk_mapped_flags.c \
      $(SDK_ROOT)/components/libraries/sha256/sha256.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/components/drivers_nrf/clock/nrf_drv_clock.c \
      $(SDK_ROOT)/components/drivers_nrf/common/nrf_drv_common.c \
      $(SDK_ROOT)/components/drivers_nrf/gpiote/nrf_drv_gpiote.c \
      $(SDK_ROOT)/components/drivers_nrf/rng/nrf_drv_rng.c \
      $(SDK_ROOT)/components/drivers_nrf/uart/nrf_drv_uart.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_ecdh.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_ecdsa.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_hash.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_init.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_keys.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_mem.c \
      $(SDK_ROOT)/components/libraries/crypto/nrf_crypto_rng.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/components/ble/common/ble_advdata.c \
      $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_params.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_state.c \
      $(SDK_ROOT)/components/ble/ble_db_discovery/ble_db_discovery.c \
      $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
      $(SDK_ROOT)/components/ble/peer_manager/gatt_cache_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/gatts_cache_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/id_manager.c \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_data_storage.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_database.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_id.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/pm_buffer.c \
      $(SDK_ROOT)/components/ble/peer_manager/pm_mutex.c \
      $(SDK_ROOT)/components/ble/peer_manager/security_dispatcher.c \
      $(SDK_ROOT)/components/ble/peer_manager/security_manager.c \
      $(SDK_ROOT)/components/toolchain/gcc/gcc_startup_nrf52.S \
      $(SDK_ROOT)/components/toolchain/system_nrf52.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs/ble_hrs.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c/ble_hrs_c.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_lib_ecdh.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_lib_ecdsa.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_lib_init.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_lib_keys.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc/micro_ecc_lib_shared.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/nrf_crypto_sw/nrf_crypto_sw_hash.c \
      $(SDK_ROOT)/components/libraries/crypto/backend/nrf_crypto_sw/nrf_crypto_sw_rng.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components/drivers_nrf/usbd \
      $(SDK_ROOT)/components/libraries/usbd/class/hid \
      $(SDK_ROOT)/components/libraries/gpiote \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \
      $(SDK_ROOT)/components/libraries/usbd \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs \
      $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias \
      $(SDK_ROOT)/components/libraries/crypto \
      $(SDK_ROOT)/external/micro-ecc/micro-ecc \
      $(SDK_ROOT)/components/libraries/mem_manager \
      $(SDK_ROOT)/components/drivers_nrf/hal \
      $(SDK_ROOT)/external/fprintf \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas \
      $(SDK_ROOT)/components/drivers_nrf/comp \
      $(SDK_ROOT)/components/softdevice/s132/headers/nrf52 \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \
      $(SDK_ROOT)/components/drivers_nrf/power \
      $(SDK_ROOT)/components/libraries/led_softblink \
      $(SDK_ROOT)/components/libraries/bsp \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/libraries/timer \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \
      $(SDK_ROOT)/components/drivers_nrf/swi \
      $(SDK_ROOT)/components/ble/ble_services/ble_gls \
      $(SDK_ROOT)/components/libraries/crypto/backend/nrf_crypto_sw \
      $(SDK_ROOT)/components/libraries/twi \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \
      $(SDK_ROOT)/components/libraries/experimental_log \
      $(SDK_ROOT)/components/drivers_nrf/i2s \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc \
      $(SDK_ROOT)/components/device \
      $(SDK_ROOT)/components/libraries/uart \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs \
      $(SDK_ROOT)/components/ble/ble_dtm \
      $(SDK_ROOT)/components/drivers_nrf/rtc \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/drivers_nrf/wdt \
      $(SDK_ROOT)/components/libraries/experimental_log/src \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/components/libraries/pwm \
      $(SDK_ROOT)/components/libraries/hci \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \
      $(SDK_ROOT)/components/ble/ble_services/ble_hids \
      $(SDK_ROOT)/components/libraries/usbd/config \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt \
      $(SDK_ROOT)/components/libraries/crypto/backend/micro_ecc \
      $(SDK_ROOT)/components/drivers_nrf/gpiote \
      $(SDK_ROOT)/components/libraries/csense \
      $(SDK_ROOT)/components/drivers_nrf/timer \
      $(SDK_ROOT)/components/libraries/fds \
      $(SDK_ROOT)/components/ble/ble_advertising \
      $(SDK_ROOT)/components/libraries/cli \
      $(SDK_ROOT)/components/toolchain \
      $(SDK_ROOT)/components/drivers_nrf/twis_slave \
      $(SDK_ROOT)/components/drivers_nrf/spi_slave \
      $(SDK_ROOT)/components/libraries/experimental_memobj \
      $(SDK_ROOT)/components/ble/common \
      $(SDK_ROOT)/components/drivers_nrf/saadc \
      $(SDK_ROOT)/components/drivers_nrf/rng \
      ../config \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/components/libraries/usbd/class/msc \
      $(SDK_ROOT)/components/libraries/slip \
      $(SDK_ROOT)/components/ble/ble_db_discovery \
      $(SDK_ROOT)/components/drivers_nrf/ppi \
      $(SDK_ROOT)/components/ble/peer_manager \
      $(SDK_ROOT)/components/softdevice/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_cscs \
      $(SDK_ROOT)/components/drivers_nrf/qdec \
      $(SDK_ROOT)/components/drivers_nrf/delay \
      $(SDK_ROOT)/components/drivers_nrf/twi_master \
      $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \
      $(SDK_ROOT)/components/libraries/ecc \
      $(SDK_ROOT)/components/libraries/crc16 \
      $(SDK_ROOT)/components/softdevice/s132/headers \
      $(SDK_ROOT)/components/libraries/button \
      $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \
      $(SDK_ROOT)/components/libraries/usbd/class/audio \
      $(SDK_ROOT)/components/libraries/low_power_pwm \
      $(SDK_ROOT)/components/libraries/twi_mngr \
      $(SDK_ROOT)/components/drivers_nrf/pdm \
      $(SDK_ROOT)/components/ble/ble_services/ble_dfu \
      $(SDK_ROOT)/components/drivers_nrf/common \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/components/drivers_nrf/spi_master \
      $(SDK_ROOT)/components/libraries/hardfault \
      $(SDK_ROOT)/components/drivers_nrf/clock \
      $(SDK_ROOT)/components/libraries/csense_drv \
      $(SDK_ROOT)/components/libraries/svc \
      $(SDK_ROOT)/components/drivers_nrf/lpcomp \
      $(SDK_ROOT)/components/drivers_nrf/uart \
      $(SDK_ROOT)/components/ble/ble_racp \
      $(SDK_ROOT)/components/ble/ble_services/ble_hts \
      $(SDK_ROOT)/components/ble/ble_services/ble_lls \
      $(SDK_ROOT)/components/libraries/sha256 \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr \
      $(SDK_ROOT)/components/toolchain/gcc \
      $(SDK_ROOT)/components/libraries/queue \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \
      $(SDK_ROOT)/components/libraries/crc32 \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/drivers_nrf/pwm \
      $(SDK_ROOT)/components/ble/ble_services/ble_tps \
    # Libraries common to all targets
    LIB_FILES += \
      $(SDK_ROOT)/external/micro-ecc/nrf52nf_armgcc/armgcc/micro_ecc_lib_nrf52.a \
    # Optimization flags
    OPT = -Os -ggdb -DDEBUG
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DBOARD_PCA10040
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52
    CFLAGS += -DNRF52832_XXAA
    CFLAGS += -DNRF52_PAN_74
    CFLAGS += -DNRF_SD_BLE_API_VERSION=5
    CFLAGS += -DS132
    CFLAGS += -DSOFTDEVICE_PRESENT
    CFLAGS += -DSVC_INTERFACE_CALL_AS_NORMAL_FUNCTION
    CFLAGS += -DSWI_DISABLE0
    CFLAGS += -D__HEAP_SIZE=0
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS +=  -Wall -Werror
    CFLAGS += -mfloat-abi=soft
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=soft
    ASMFLAGS += -DBOARD_PCA10040
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52
    ASMFLAGS += -DNRF52832_XXAA
    ASMFLAGS += -DNRF52_PAN_74
    ASMFLAGS += -DNRF_SD_BLE_API_VERSION=5
    ASMFLAGS += -DS132
    ASMFLAGS += -DSOFTDEVICE_PRESENT
    ASMFLAGS += -DSVC_INTERFACE_CALL_AS_NORMAL_FUNCTION
    ASMFLAGS += -DSWI_DISABLE0
    ASMFLAGS += -D__HEAP_SIZE=0
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L $(TEMPLATE_PATH) -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=soft
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: nrf52832_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		nrf52832_xxaa
    	@echo		flash_softdevice
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash flash_softdevice erase
    # Flash the program
    flash: $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex
    	@echo Flashing: $<
    	nrfjprog -f nrf52 --program $< --sectorerase
    	nrfjprog -f nrf52 --reset
    # Flash softdevice
    flash_softdevice:
    	@echo Flashing: s132_nrf52_5.0.0_softdevice.hex
    	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_5.0.0_softdevice.hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
    Note that the above example requires that you press button_1 after pairing (see main.c::num_comp_reply() for more info on this).
    Does the same issue occur if you use HardFP, or is this only present on SoftFP?
    No other assertions, or HardFault occurring, only this event "BLE_GAP_SEC_STATUS_DHKEY_FAILURE"?
    Håkon
