Device Name Change
Hi all ,
I'm using SDK 15.0, working on ble_uart.c
I need to change the DEVICE  NAME of the  frequently.
Can you please tell me how to change the the device name and store it in a buffer.
If you provide a example code, it will be a great help.
Thanks and Regards,
 Venu
  • Hi....atok ..sorry for late , i didn't receive your notification . yes i want to change my device name after bonding  periodically via nrf toolbox ,how to do that ? i tried all the ways and read many threads , i don't know how to Re- initialize the advertising again ... can you share me sample code so that i can , it will be more helpfull
    Thanks&Regards
    pspavi
  • Hi pspavi
    There is sadly no direct solution for the NRF Toolbox's standard firmware to do this.
    A first step is to check out whether you a ready to setup and build your own custom "Nordic UART Service" (NUS) firmware to do this.
    I have written my own multi-service application including multi-protocol support and non-volatile configuration, which I cannot share for confidentiality reasons.
    Yet the code mentioned before is the crucial part to change a device's name. My suggestion for you is to adapt your main.c code to include my logic to control the ble_advertising_init_t related parts with your own defined NUS command.
    Have a look inside \examples\ble_peripheral\ble_app_uart or \examples\ble_peripheral\experimental\ble_app_cli in the SDK to see how to scaffold your own NUS application. It gave me the crucial starting point to do more complex setups.
    Also see Command Line Interface library for how to add a custom command.
    Best regards
    Markus, Technokrat GmbH
  • thank you ,i dono know whether you understood my question, may be my communication problem . I am explaining it again, we are using custom board nrf52832 , i will connect the device using nrf toolbox app ,and then i will give command as for example '1' , when i receive '1' , it should stop advertise and then it should re advertise with the new name which i was given in the condition
    if(command=='1')
    change_name;
    stop_adv;
    start_adv;
    similar to this it should work
    Thanks&Regards
    pspavi
  • Then use
    ble_advertising_restart_without_whitelist(m_advertising);
    after calling my function to update the advertisement data
    bluetooth_update_name("DEVICE 123");
    This should work.
    Best regards
  • sorry  , i didn't get you .can you share me briefly
