Device Name Change
Hi all ,
I'm using SDK 15.0, working on ble_uart.c
I need to change the DEVICE  NAME of the  frequently.
Can you please tell me how to change the the device name and store it in a buffer.
If you provide a example code, it will be a great help.
Thanks and Regards,
 Venu
  • Hi all,
    I solved this issue with the following steps:
    1)You must to call the sd_ble_gap_adv_stop() function.
    2)Then you would change any config data as you want using for example sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    3) And finally, you must to call sd_ble_gap_adv_start() function to initialize the BLE.
    All of this is used in SDK 15.0.
    Thanks
    Abian.
  • hi Abian   could  provide  full  example  of this tree function
    i am suing softdevce 112  on nrf52801 rigago mudule
    sd_ble_gap_adv_stop(missing param)
    SVCALL(SD_BLE_GAP_ADV_STOP, uint32_t, sd_ble_gap_adv_stop(uint8_t adv_handle));
    where in the code   m_adv_data  and adv_param  ?
    sd_ble_gap_adv_start(missing param )
