First Steps BLE MESH
I'm starting with BLE Mesh SDK and have some doubts about their examples.
What's the difference between Light_Switch Client/Server version and Proxy_Client/Server and Provisioning.
I understood that Proxy is the version that can communicate with NRF_MESH.
What is not clear for me is if Proxy version can communicate with regular one.
As I read Client is also Provisioner, why there is a need for Provisioner Only in network.
Once provisioning is made, if keep in flash this info to start a new network in a server I have to reflash the board?
  • The light switch client & server examples communicate via the PB-ADV bearer in the mesh network & will require a provisioner (another nrf52 device) to provision & configure the other devices to join the mesh network.
    The proxy client & server examples can also communicate via the PB-ADV bearer to other mesh nodes, but can also use PB-GATT bearer to act as a proxy node & communicate with a smartphone for example.
    It is not entirely correct that only the proxy can communicate in the mesh network, as both the proxy & non proxy light switch examples can communicate over the mesh network.
    In our newest mesh sdk (v2.1.0), the provisioner & client are on separate devices.
    I do not quite understand what you mean in your last question. Do you want to add a new node to the same network?
