ESB receive ACK from every pipe / or send ACK payload use received pipe
Hi sir,
   we use nRF 52832  with ESB protocol. and we use ACK to send payload to PTX , but we found must use the same pipe which PTX used pipe  to send ACK .
so , I have two questions:
1. how to make PTX receive ACK from 8 pipe ?
2. how to make send ACK use reveived pipe ?
for the 1st question , i have try to modify code like below:
static void start_tx_transaction(){
NRF_RADIO->RXADDRESSES = 1 << mp_current_payload->pipe | BIT_MASK_UINT_8( 8 );
but it is not work.
fot the second question, i have try to modify code like below:
static void on_radio_disabled_rx(void){
case NRF_ESB_PROTOCOL_ESB_DPL:
if (m_tx_fifo.count > 0 /*&&
(m_tx_fifo.p_payload[m_tx_fifo.exit_point]->pipe ==
NRF_RADIO->RXMATCH)*/
it is not work too.
waiting for your help .
thanks !
    I do not recommend to change the library.
    Each time you communicate between a PTX and PRX, you must ensure that the address used is unique if you plan to use ACK or ACK+payload. If several PRX share same address, then there will be collisions from several ACK or ACK+payload, and this will not work reliably.
    If several PRX share the same address from production, then you must find a way to change the address for future communication. For instance pipe0 of PRX can be a shared address, and pipe1 can be a uniqe address. The procedure to exchange address can be
    1. PTX transmit data on pipe0 then enter PRX mode, wait for a packet containing unique pipe1 address (or timeout to try again). (Use noack=true in this case.)
    2. If PRX receive data on pipe0 it can for instance enter PTX mode, have a small random delay and send it's own address as a packet using pipe0 address. (Use noack=true in this case.)
    The PTX have now received the unique pipe1 address, and can now transmit using the unique pipe1 address to use ACK or ACK+payload for future communication.
    The PTX must get the pipe1 address for each PRX it want to communicate with.
    Kenneth
