SPIS blocks BLE application
Hi together,
since quite some time I try to merge my BLE application with the SPIS functionalities from nRF52 SDK 12.3 example with softdevice S132.
My application should receive 200 bytes per second as an SPI slave and forward it to a connected device.
If I just run the SPIS example, everything works fine - all data is properly received.
As soon as I use the function nrf_drv_spis_buffers_set () in my application, the BLE advertising is blocked and nothing happens anymore.
The functions used are called as follows.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
uint32_t err_code;
bool erase_bonds;
// Initialize.
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("====== START BLE_stack ======\r\n");
timers_init();
nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
spis_config.csn_pin = 12;
spis_config.miso_pin = 24;
spis_config.mosi_pin = 23;
spis_config.sck_pin = 25;
spis_config.bit_order = NRF_DRV_SPIS_BIT_ORDER_MSB_FIRST;
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Does anyone have an idea or experience how to fix the problem?
