printf output is not displayed during debug
Dear Support,
 I’m working on uVision V5.25.2.0, using nRF5_SDK_15.0.0_a53641a.
My evaluation board is Rigado BMD-300.
Target: nrf52832_xxaa.
 I tried using the printf function while debugging, but its output is not displayed. I tested it in a few simple example projects (like Nordic\nRF5_SDK_15.0.0_a53641a\examples\peripheral\uart\).
 I did many efforts by searching in the Internet and applying different advices, but nothing helped.
 I need using this function to debug the signal processing algorithm. It means that I would be happy to get the simplest project, without uart and other peripherals.
 Thanks in advance,
 Arie Shlitner
  • After I haven’t found a solution in Google and didn’t receive an answer neither from the ARM nor from the Nordic support, I myself solved the problem, as follows:
    In addition to known configuration, you must configure the TRACECONFIG register in your code:
    		NRF_CLOCK->TRACECONFIG = (CLOCK_TRACECONFIG_TRACEMUX_Parallel << CLOCK_TRACECONFIG_TRACEMUX_Pos) |
    		(CLOCK_TRACECONFIG_TRACEPORTSPEED_32MHz << CLOCK_TRACECONFIG_TRACEPORTSPEED_Pos);
    Slight smileEnjoy!
