printf output is not displayed during debug
Dear Support,
 I’m working on uVision V5.25.2.0, using nRF5_SDK_15.0.0_a53641a.
My evaluation board is Rigado BMD-300.
Target: nrf52832_xxaa.
 I tried using the printf function while debugging, but its output is not displayed. I tested it in a few simple example projects (like Nordic\nRF5_SDK_15.0.0_a53641a\examples\peripheral\uart\).
 I did many efforts by searching in the Internet and applying different advices, but nothing helped.
 I need using this function to debug the signal processing algorithm. It means that I would be happy to get the simplest project, without uart and other peripherals.
 Thanks in advance,
 Arie Shlitner
  • The UART pin mapping in the SDK are mapped to a particular DK as per the project. I am not how the mapping of UART pins are done from your Rigado BMD-300 module onto the custom board. Look into the code of UART initialization in your project and check that the UART pin number matches the UART pin on your board.
  • Thanks,
    I took the uart project as an example. I’m not interested specifically in uart or any other peripherals.
    I just want my message, e.g. printf("Hello world!\r\n"); to be displayed in the Debug (printf) Viewer of the uVision.
  • if you have retarget.c file in your project, you need to remove it, as it is overwriting the functions that printf uses to redirect the logs from standard output to uart.
  • Thanks. I removed it, but this didn't help.
  • Are you running this in simulator mode? if not, printf executing on nrf chip will not show you anything on the Keil console as far as i know.
1 2 3
