Hi all:
Q:When i reboot the board which burn the serial project , how to add the device key to serial board again?
I use PYACI to control the board which burn the serial code
SDK for mesh:v2.0.1
Best regard.
Hi all:
SDK for mesh:v2.0.1
Best regard.
This is something the mesh team might consider implementing in the future. For now, what you can do is enable PERSISTENT_STORAGE in the mesh serial example. You should be able to follow the whole interactive mesh provisioning example & then power cycle the serial board.
Another application engineer & I tested by following all of the steps, including cc.composition_data_get(). We used the serial example & a light switch server to test. Then, we power cycled the serial board & ran the following commands:
python interactive_pyaci.py -d COM1 --no-logfile db = MeshDB("database/example_database.json") cc = ConfigurationClient(db) device.model_add(cc) cc.publish_set(8, 0) cc.composition_data_get()
where 8 is the devkey handle & 0 is the address handle from when you provisioned the first light client (i.e. p.provision(name="Light bulb")).
You may need to update DSM_DEVICE_MAX & DSM_FLASH_PAGE_COUNT, depending on how many devices you want to test with. I would recommend testing with two devices first, as I mentioned above.
Hi all,
Thanks for your answer.
Now I reboot the serial board, then send PYACI CMD as below:
1.db = MeshDB("database/example_database.json")
2.p=provisioner(d[0],db)
3.device.send(cmd.AddrPublicationAdd(db.nodes[0].unicast_address))
4. d0=SimpleOnOffClient()
5. device.model_add(d0)
6. d0.publish_set(0,0)
7. d0.set(1)
When I send the CMD 1~7 as soon as possible, it can't control the Node's LED On/Off immediately, but over Ten or two seconds, it can control the LED On/Off normal.What cause the delay?From reboot the serial board, how long can i re-control the node?
Regard
At what point did you reboot the serial board? Right after cc.composition_data_get()? Or are you provisioning & configuring the board & getting it to blink the LED first & then resetting the serial board?
From the commands that you posted in your last comment, it seems you are skipping some code commands. This is why I am wondering how the exact test procedure was.
Hi
I've done all the PYACI need to do and can send the sc.set() command to control the LED OnOff,after that, I reboot the serial board then the issue coming.
Sorry for the delayed response. Just finished testing: everything works fine if you follow the guide like stated until sc.set(True). I tested with one serial board & one light switch server board. Remember to enable PERSISTENT_STORAGE on both examples. Then, power cycle the serial board & enter the following commands:
python interactive_pyaci.py -d COM1 --no-logfile db = MeshDB("database/example_database.json") cc = ConfigurationClient(db) device.model_add(cc) cc.publish_set(8, 0) cc.composition_data_get() cc.appkey_add(0) cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0, 0x59)) sc = SimpleOnOffClient() device.model_add(sc) sc.publish_set(0, 0) sc.set(True)
Since the provisioning has already been done, you do not need to do this part after you
power cycled the serial board. Everything should work fine then.
