sd_softdevice_disable() only possible at thread level?
My app (using S130v2.0.1 nRF51822 SDK12.3)  triggers app_error_fault_handler (seen on a PIN; since not able to debug due to timing) on sd_softdevice_disable(). A snippet of my code follows (using an available IRQn to trigger sd_softdevice_disable with priority 3):
#define SD_END_IRQn                 ADC_IRQn // NOt used by app
#define SD_END_IRQHandler           ADC_IRQHandler
#define SD_END_IRQPriority          3
void SD_END_IRQHandler(void)
        uint32_t err_code = sd_softdevice_disable();
void nrf_evt_signal_handler(uint32_t evt_id)
    uint32_t err_code;
    switch (evt_id)
        case NRF_EVT_RADIO_SIGNAL_CALLBACK_INVALID_RETURN:
            // No implementation needed
        case NRF_EVT_RADIO_SESSION_IDLE:
            err_code = sd_radio_session_close();
        case NRF_EVT_RADIO_SESSION_CLOSED:
            // The session is closed and all acquired resources are released.
            // Softdevice can be disabled.
            err_code = sd_nvic_SetPendingIRQ(SD_END_IRQn);
        case NRF_EVT_RADIO_BLOCKED:
        case NRF_EVT_RADIO_CANCELED:
            configure_next_event_normal(m_ts_distance, m_ts_length);
            err_code = request_next_event_normal();
Any ideas why am I not able to disable softdevice?
