I am having some trouble using fstorage to write data into flash. I want to store ~20 kB of sampled data before processing it, and I am storing it just below the bootloader (in my case below 0x73000). When writing into this memory region using nrf_fstorage_write, all data written at addresses that are multiples of 0x1000 is corrupted. See below for a minimal working example (note that the softdevice is running, so the example should be tested in the context of ble_app_template). The example writes '0x22222222' to all words between 0x71F00 and 0x72100.
#define BOOTLOADER_START_ADDR 0x00073000 // = NRF_UICR->NRFFW[0]
static void fstorage_evt_handler(nrf_fstorage_evt_t *p_evt) {
if (p_evt->result != NRF_SUCCESS) {
NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
return;
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
.evt_handler = fstorage_evt_handler,
.start_addr = (uint32_t)BOOTLOADER_START_ADDR - 0x4000,
.end_addr = (uint32_t)BOOTLOADER_START_ADDR};
void my_fstorage_init(void) {
ret_code_t ret_code = nrf_fstorage_init(&fstorage, &nrf_fstorage_sd, NULL);
APP_ERROR_CHECK(ret_code);
uint32_t diff = fstorage.end_addr - fstorage.start_addr;
NRF_LOG_DEBUG("my_fstorage_init: end address 0x%08x", fstorage.end_addr);
NRF_LOG_DEBUG("my_fstorage_init: start address 0x%08x", fstorage.start_addr);
NRF_LOG_DEBUG("my_fstorage_init: diff 0x%08x (%d)", diff, diff);
NRF_LOG_FLUSH();
void my_fstorage_test() {
ret_code_t ret_code;
my_fstorage_init();
uint32_t data[0x200];
memset(data, 0x22222222, 0x200 * sizeof(uint32_t));
ret_code = nrf_fstorage_write(
&fstorage,
0x71F00,
data,
0x200,
NULL);
The corrupted data is obvious from an nrfjprog dump of the memory:
$ nrfjprog --memrd 0x00071F00 --n 0x00000200 0x00071F00: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F10: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F20: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F30: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F40: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F50: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F60: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F70: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F80: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071F90: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071FA0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071FB0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071FC0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071FD0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071FE0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00071FF0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072000: 02200002 20020022 22222222 22222222 |.. .".. """"""""| 0x00072010: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072020: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072030: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072040: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072050: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072060: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072070: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072080: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x00072090: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x000720A0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x000720B0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x000720C0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x000720D0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x000720E0: 22222222 22222222 22222222 22222222 |""""""""""""""""| 0x000720F0: 22222222 22222222 22222222 22222222 |""""""""""""""""|
My setup:
- SDK14.2
- s132_nrf52_5.0.0
- DFU bootloader from bootloader_secure_ble
- GCC environment on Linux
I am sure I have simply misunderstood how the flash pages are handled by the memory controller or something, but I appreciate any help in resolving my issue.
Fredrik Flornes Ellertsen
