We are using the 52840 chip SPI interface in slave mode and communicating at about 8MHz are noticing that during periods of innactivity with all systems stopped and sleeping we are seeing 15-20 microamps of current draw. I we disable the SPI port we get 2 microamps of current draw until we enable a SPI port then we see 15-20 microamps of current draw again. The rest of the SPI interface is functioning normally when we are communicating with it but the power draw between communications is way too high for us.
The datasheet on page 532 says that the SPI port should only draw about 1 microamp of current when enabled and innactive.
I see lots of discussion on SPI errata or configuration issues on the older 52832 chips but not a lot on the 52840.
Does the 52840 chip have an issue also that would cause the chip to use more power when the SPI peripheral is enabled?
My first thought is to disable the SPI port and change back to standard I/O when the system chip select is in an innactive state but then reenable the SPI port quickly when I see the chip select line go low.
Is what we are seeing normal or caused by some errata and if so is there a better work around for the peripheral power usage when innactive.
Edit
My SDK is :SDK V15.
We used the Nordic DK PCA10056 to test the consumption and found similar results.
This is the code we are using for SPIS enable
void SPIS_Init(){
nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
spis_config.csn_pin = 26;
spis_config.miso_pin = NRF_GPIO_PIN_MAP(1, 2);
spis_config.mosi_pin = NRF_GPIO_PIN_MAP(1, 1);
spis_config.sck_pin = 8;
spis_xfer_done = true;
APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
This is the code we have done for SPIS disable testng
while(NRF_SPI1->ENABLE != 0)
nrf_drv_spis_uninit(&spis);
nrf_gpio_cfg_default(26);
nrf_gpio_cfg_default(8);
nrf_gpio_cfg_default(NRF_GPIO_PIN_MAP(1, 2));
nrf_gpio_cfg_default(NRF_GPIO_PIN_MAP(1, 1));
