In infocenter we will have to define
| #define | nrf_drv_ppi_channel_assign nrfx_ppi_channel_assign |
| Macro for forwarding the new implementation. |
where nrfx_ppi_channel_assign is a function
| nrfx_err_t nrfx_ppi_channel_assign | ( | nrf_ppi_channel_t | channel, |
| uint32_t | eep, | ||
| uint32_t | tep | ||
Function for assigning task and event endpoints to the PPI channel.
- Parameters
[in] channel PPI channel to be assigned endpoints. [in] eep Event endpoint address. [in] tep Task endpoint address.
- Return values
NRFX_SUCCESS If the channel was successfully assigned. NRFX_ERROR_INVALID_STATE If the channel is not allocated for the user. NRFX_ERROR_INVALID_PARAM If the channel is not user-configurable.
but in SAADC peripheral example it is directly use as
timer_compare_event_addr,
saadc_sample_task_addr);
How these two codes similar?
