Not able to run more than 2 tasks using FREERTOS with Segger Embedded Studio
Hi Everyone , I am using SDK v15.0 for nrf52840 with segger embedded studio.
I tried the example code given for blink freertos. I  am able to run two tasks but as soon as i write third task to blink a 3rd onboard LED. It compiles but it doesn't do anything, No leds blink at all.
here is the code
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup blinky_example_main main.c
 * @ingroup blinky_example_freertos
 * @brief Blinky FreeRTOS Example Application main file.
 * This file contains the source code for a sample application using FreeRTOS to blink LEDs.
#include <stdbool.h>
#include <stdint.h>
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "bsp.h"
#include "nordic_common.h"
#include "nrf_drv_clock.h"
#include "sdk_errors.h"
#include "app_error.h"
#include "semphr.h"
#include "nrf_drv_twi.h"
#if LEDS_NUMBER <= 2
#error "Board is not equipped with enough amount of LEDs"
#define TASK_DELAY        700           /**< Task delay. Delays a LED0 task for 200 ms */
TaskHandle_t  led_toggle_task1_handle;   /**< Reference to LED0 toggling FreeRTOS task. */
TaskHandle_t led_toggle_task2_handle;  /**< Reference to LED1 toggling FreeRTOS task. */
TaskHandle_t led_toggle_task3_handle;
TaskHandle_t led_toggle_task4_handle;
static void led_toggle_task1_function (void * pvParameter)
    UNUSED_PARAMETER(pvParameter);
    while (true)
        bsp_board_led_invert(BSP_BOARD_LED_0);
        /* Delay a task for a given number of ticks */
        vTaskDelay(TASK_DELAY);
        /* Tasks must be implemented to never return... */
 /* @param[in] pvParameter   Pointer that will be used as the parameter for the timer.
static void led_toggle_task2_function (void * pvParameter)
    while (true)
        bsp_board_led_invert(BSP_BOARD_LED_1);
static void led_toggle_task3_function (void * pvParameter)
    while (true)
        bsp_board_led_invert(BSP_BOARD_LED_2);
static void led_toggle_task4_function (void * pvParameter)
    while (true)
        bsp_board_led_invert(BSP_BOARD_LED_3);
    ret_code_t err_code;
    /* Initialize clock driver for better time accuracy in FREERTOS */
    err_code = nrf_drv_clock_init();
    /* Configure LED-pins as outputs */
    /* Create task for LED0 blinking with priority set to 2 */
   UNUSED_VARIABLE(xTaskCreate(led_toggle_task1_function, "LED0", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task1_handle));
   UNUSED_VARIABLE(xTaskCreate(led_toggle_task2_function, "LED1", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task2_handle));
    UNUSED_VARIABLE(xTaskCreate(led_toggle_task3_function, "LED2",  configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task3_handle));
     // UNUSED_VARIABLE(xTaskCreate(led_toggle_task4_function, "LED3", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task4_handle));
    /* Activate deep sleep mode */
   SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    /* Start FreeRTOS scheduler. */
    vTaskStartScheduler();
    while (true)
        /* FreeRTOS should not be here... FreeRTOS goes back to the start of stack
         * in vTaskStartScheduler function. */
Is it a problem of stacksize configuration or something else?
Thanks
Rajat
