include Mesh Serial device into the Light Switch Mesh
Hello, I want to include Mesh Serial Example into the Mesh Light Switch example.
The aim is to allow the serial device to listen to the mesh messages.
What is the best way to do this ? Do i need to write a new Model ?
My idea was just to extend the Client Model by the Serial features but I'm not sure if it will work and before i spend a lot of time on it i better ask.
    Do you want to let the light switch model runs autonomously on the serial node or you want to let the model run on the peer device (e.g PC) and the serial still act a just connectivity chip ?
    If you want to let the model run on the peer device, we already do that in this guide, look for "blinking LEDs"
    But you can add a model in the serial code as well, shouldn't have any problem.
  • I want to run the client model on the serial node or rather I want to integrate the seril communication abilities  into the client model of the mesh  light switch example. For that :
    in mesh_init(void) I added : nrf_mesh_serial_init(NULL);
    in the start() I added : nrf_mesh_serial_enable();
    And I added all necessery files for serial communication from the mesh into the Light Switch Client Model to activate the serial communication, but  if I try to send some messages  from Server to Client the application does not work proper and after some "button messages" it seems that the Client Model application crashes.
    My aim is to build a mesh with several servers and client and one node with the serial communication abilities. All nodes should have all the necessary keys. And in the end i want to receive with this serial node all the mesh messages and send them to the host pc
    the problem is:
    1) i dont know how add the same keys to all devices by the "hand"
    2) i dont know how to receive the mesh messages with the serial node or rather i dont know how to implement the receive funktion in serial node (is it implemented allready ?)
     3) I can not use interactive.py script to send comands to the serial device, I can just receive events from serial device. Because of this unsolved problem : devzone.nordicsemi.com/.../mesh-serial-example-problem-timeout-waiting-for-event
    That's why i tried to use the Light-Switch Example and to activate the Serial Communication by the Client. Because in this example I have one provisioner and all nodes get the keys.
    A serial node should work like a normal node and vice versa. We don't know what kind of issue you have. We need more debug information. We can try to create an example for you but due to reduced staff in the summer, we can't do it right now.
    1. What do you mean by keys ? It's the network key, app key or device key ? What is "by hand" ? You mean like hardcoded in the application , not by a provisioner ?
    2. I guess it's the best to test between 2 serials nodes, one works a provisioner and one as a normal node. But you need to make the PyACI works first.
    3. Bjørn Kvale is on vacation for 1 week. But which hardware did you use ? Was it a nRF52 DK ? Could you verify you can communicate with UART to PC without problem ? (test with UART example in SDK v15)
  • Hey,
    An Example would be great !
    1)I was confused  and wanted to hard code the dev,net,app keys without provisioning but it is not more necessary.
    Now  I can run the serial example on Windows and it works fine till now.  Think the problem is in the Linux Mint 18 and how the OS manages the connection. If your are interested in I can try to give you some more information about it.
    2 and 3) not important anymore
    Now I try to understand the , Interactive mesh provisioning and configuration with PyACI on Windows.
    http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v2.0.1%2Fmd_examples_README.html
    Concerning this I have some questions:
    0) I do not understand the exactly functionality of the serial device in this example.
    Do we use the serial node just to send command and receive events or do you load some models onto the serial device in the process ?
    provisioning:
    Next, we create a Provisioner object: p = Provisioner(device, db)
    1) the Device there is the serial device right ? where do we create the provisioning object ?
    DevkeyAdd: {'devkey_handle': 8}
    2) why is the handle=8 ? what do we have in the previous 7 handles ?
    configuration:
    device.model_add(cc)
    3) I do not understand the magic change, previously the device was the serial device or is it not so ?
    4) How I can turn on the relay mode ?
    5) now i have the server,client and the serial device in the mesh , how can i receive the mesh messages with serial device and send it to the hos pc ?
  • ok, I  build a mesh: Server with Serial feature and Client.  To build the mesh I used additional serial device and provisioned the server and the client with help of Interactive mesh provisioning and configuration python script.
    I modified the Light Switch Server:
     ERROR_CHECK(nrf_mesh_serial_init(NULL));  in the mesh_init(void)
       ERROR_CHECK(nrf_mesh_serial_enable()); in the start(void)
    and in the  on_off_server_set_cb (...) I added
     uint32_t result;
      char data[]="Message Received\n";
      result=nrf_mesh_serial_tx (data, sizeof(data));
    It works almost. I can receive the Message from the Client to the server and send it to the Host-PC but i get Error in the aci_uart.py and access.py
    2018-07-20 08:52:27,063 - INFO - COM11: {event: Application, data: {'data': bytearray(b'Message Received\n\x00')}}
    2018-07-20 08:52:27,070 - ERROR - COM11: Exception in pkt handler <bound method Access.__event_handler of <mesh.access.Access object at 0x038BB910>>
    2018-07-20 08:52:27,096 - ERROR - COM11: traceback: Traceback (most recent call last):
    File "C:\Users\XYZ\nRF\mesh_2.1.1\scripts\interactive_pyaci\aci\aci_uart.py", line 88, in process_packet
    fun(packet)
    File "C:\Users\XYZ\nRF\mesh_2.1.1\scripts\interactive_pyaci\mesh\access.py", line 209, in __event_handler
    assert(element_index < len(self.elements) and element_index >= 0)
    AssertionError
    Any ideas what I'm doing wrong ?
    I think the constellation Server with Serial feature and Client + Serial Device to provide the keys is not the best solution. It must work also with Server, Client and purely Serial device. Because if I look on the log of the purely Serial device, I see that the serial device gets the mesh messages if I push the button on the client site and send message to the server but at the moment i don't know how to receive this messages on the Host-PC that why i use again the "Serial-Feature" by the Server.
    Debug Logs from purely Serial Device by pushing the Button on the Client:
    <t:    9565047>, net_packet.c,  230, Unencrypted data: : 00106EFCBFA313F56D5395D0
    <t:    9565698>, net_packet.c,  230, Unencrypted data: : 00126E5813DD6B10E872BC
    <t:    9580083>, net_packet.c,  230, Unencrypted data: : 00106EDEF1B21FBEFF5E9EA2
    <t:    9580991>, net_packet.c,  230, Unencrypted data: : 00126E3740A10ED65F70BE
    <t:    9598512>, net_packet.c,  230, Unencrypted data: : 00106ECA6E96D67C0170C3B4
    <t:    9599003>, net_packet.c,  230, Unencrypted data: : 00126E4FEAF4A021018537
