Hey all, I am using an NRF52 DK and am trying to combine the 'pwm' and 'ant broadcast' examples. Both examples compile fine on their own, but when I try to combine I am getting these two errors:
Output/ant_broadcast_tx_pca10040_s212 Release/Obj/app_pwm.o: In function `app_pwm_init':
undefined reference to `nrf_drv_ppi_init'
I don't understand what the first one is but the second one seems like it is not finding the library... I made sure PPI is turned on in sdk_config.h and that it is included in the header and makefile... Also don't know if it matters but I am working in Segger Embedded Studio using S212 SoftDevice. I have included everything I seemed to have needed in the header and added all to the makefile; please advise.
* This software is subject to the ANT+ Shared Source License
* www.thisisant.com/swlicenses
* Copyright (c) Dynastream Innovations, Inc. 2014
* All rights reserved.
* Redistribution and use in source and binary forms, with or
* without modification, are permitted provided that the following
* conditions are met:
* 1) Redistributions of source code must retain the above
* copyright notice, this list of conditions and the following
* disclaimer.
* 2) Redistributions in binary form must reproduce the above
* disclaimer in the documentation and/or other materials
* provided with the distribution.
* 3) Neither the name of Dynastream nor the names of its
* contributors may be used to endorse or promote products
* derived from this software without specific prior
* written permission.
* The following actions are prohibited:
* 1) Redistribution of source code containing the ANT+ Network
* Key. The ANT+ Network Key is available to ANT+ Adopters.
* Please refer to http://thisisant.com to become an ANT+
* Adopter and access the key.
* 2) Reverse engineering, decompilation, and/or disassembly of
* software provided in binary form under this license.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
* CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE HEREBY
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES(INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; DAMAGE TO ANY DEVICE, LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
* ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE. SOME STATES DO NOT ALLOW
* THE EXCLUSION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE
* ABOVE LIMITATIONS MAY NOT APPLY TO YOU.
/**@file
* @defgroup nrf_ant_broadcast_tx_example ANT Broadcast TX Example
* @ingroup nrf_ant_broadcast
* @brief Example of basic ANT Broadcast TX.
* Before compiling this example for NRF52, complete the following steps:
* - Download the S212 SoftDevice from <a href="https://www.thisisant.com/developer/components/nrf52832" target="_blank">thisisant.com</a>.
* - Extract the downloaded zip file and copy the S212 SoftDevice headers to <tt>\<InstallFolder\>/components/softdevice/s212/headers</tt>.
* If you are using Keil packs, copy the files into a @c headers folder in your example folder.
* - Make sure that @ref ANT_LICENSE_KEY in @c nrf_sdm.h is uncommented.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "bsp.h"
#include "hardfault.h"
#include "app_error.h"
#include "app_timer.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ant.h"
#include "nrf_pwr_mgmt.h"
#include "ant_interface.h"
#include "ant_parameters.h"
#include "ant_channel_config.h"
#include "nrf_delay.h"
#include "app_pwm.h"
#include "nrfx_ppi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_ANT_OBSERVER_PRIO 1 /**< Application's ANT observer priority. You shouldn't need to modify this value. */
/**@brief Function for setting payload for ANT message and sending it.
void ant_message_send(void)
uint8_t message_payload[ANT_STANDARD_DATA_PAYLOAD_SIZE];
static uint8_t counter = 1u;
memset(message_payload, 0, ANT_STANDARD_DATA_PAYLOAD_SIZE);
// Assign a new value to the broadcast data.
message_payload[ANT_STANDARD_DATA_PAYLOAD_SIZE - 1] = counter;
// Broadcast the data.
ret_code_t err_code = sd_ant_broadcast_message_tx(BROADCAST_CHANNEL_NUMBER,
ANT_STANDARD_DATA_PAYLOAD_SIZE,
message_payload);
counter++;
/**@brief Function for handling a ANT stack event.
* @param[in] p_ant_evt ANT stack event.
* @param[in] p_context Context.
static void ant_evt_handler(ant_evt_t * p_ant_evt, void * p_context)
ret_code_t err_code;
nrf_pwr_mgmt_feed();
if (p_ant_evt->channel == BROADCAST_CHANNEL_NUMBER)
switch (p_ant_evt->event)
case EVENT_TX:
ant_message_send();
err_code = bsp_indication_set(BSP_INDICATE_SENT_OK);
NRF_SDH_ANT_OBSERVER(m_ant_observer, APP_ANT_OBSERVER_PRIO, ant_evt_handler, NULL);
/**@brief Function for the Timer and BSP initialization.
static void utils_setup(void)
err_code = bsp_init(BSP_INIT_LEDS,
NULL);
/**@brief Function for ANT stack initialization.
static void softdevice_setup(void)
ret_code_t err_code = nrf_sdh_enable_request();
ASSERT(nrf_sdh_is_enabled());
err_code = nrf_sdh_ant_enable();
/**@brief Function for setting up the ANT module to be ready for TX broadcast.
static void ant_channel_tx_broadcast_setup(void)
ant_channel_config_t broadcast_channel_config =
.channel_number = BROADCAST_CHANNEL_NUMBER,
.channel_type = CHANNEL_TYPE_MASTER,
.ext_assign = 0x00,
.rf_freq = RF_FREQ,
.transmission_type = CHAN_ID_TRANS_TYPE,
.device_type = CHAN_ID_DEV_TYPE,
.device_number = CHAN_ID_DEV_NUM,
.channel_period = CHAN_PERIOD,
.network_number = ANT_NETWORK_NUM,
ret_code_t err_code = ant_channel_init(&broadcast_channel_config);
// Fill tx buffer for the first frame.
ant_message_send();
// Open channel.
err_code = sd_ant_channel_open(BROADCAST_CHANNEL_NUMBER);
*@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for application main entry. Does not return.
PWM initialzing crap
APP_PWM_INSTANCE(PWM1,2); // Create the instance "PWM1" using TIMER1.
static volatile bool ready_flag; // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id) // PWM callback function
ready_flag = true;
log_init();
utils_setup();
softdevice_setup();
ant_channel_tx_broadcast_setup();
NRF_LOG_INFO("ANT Broadcast TX example started.");
/* 2-channel PWM, 200Hz, output on DK LED pins. */
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(2000L, BSP_LED_2, BSP_LED_3);
/* Switch the polarity of the second channel. */
pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
/* Initialize and enable PWM. */
err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
app_pwm_enable(&PWM1);
uint32_t value;
while (true)
for (uint8_t i = 0; i < 40; ++i)
value = (i < 20) ? (i * 5) : (100 - (i - 20) * 5);
ready_flag = false;
/* Set the duty cycle - keep trying until PWM is ready... */
while (app_pwm_channel_duty_set(&PWM1, 0, value) == NRF_ERROR_BUSY);
/* ... or wait for callback. */
while (!ready_flag);
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, value));
nrf_delay_ms(25);
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
// Main loop.
/** for (;;)
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
Included are my main file and sdk_config.
Vkryvor
