Questions on internal temperature module in nrf52832
I have a number of (probably naive) questions regarding the internal temperature module on the nrf52832.
1) Regarding the FICR values for temperature. Are these programmed on an individual basis in the factory? How do they get programmed?
2) If the FICR values are different than their defaults, will the default values in the TEMP module reflect the programmed values in FICR? Does firmware need to copy the values in FICR to the TEMP module? I am referring to the slope, y-intercept and endpoint temperature values.
3) Does the TEMP module use the values programmed in the y-intercept, slope and endpoint registers or is it up to firmware to use these values?
Hopefully these questions make sense. Thanks!
Will
