Hi:
I using timer0's channel_0, channel_1 to drive a ADC, a handle_function.
unfortunately, I discover my timer with channel_1 didn't work when channel_1' value bigger than channel_0.
How should I do?
//========================================================================= // ADC functions (timer 0, channel_0) //========================================================================= void saadc_sampling_event_init(void) { ret_code_t err_code; err_code = nrf_drv_ppi_init(); APP_ERROR_CHECK(err_code); uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0); uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get(); /* setup ppi channel so that timer compare event is triggering sample task in SAADC */ err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel); APP_ERROR_CHECK(err_code); err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_task_addr); APP_ERROR_CHECK(err_code); } void saadc_sampling_event_enable(void) { ret_code_t err_code = nrf_drv_ppi_channel_enable(m_ppi_channel); APP_ERROR_CHECK(err_code); } void saadc_callback(nrf_drv_saadc_evt_t const * p_event) { if (p_event->type == NRF_DRV_SAADC_EVT_DONE) { ret_code_t err_code; err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); v_usb_i = p_event->data.done.p_buffer[0]; v_usb_f = coe_of_v_usb * (double)v_usb_i; } } void saadc_init(void) { ret_code_t err_code; nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE_G(NRF_SAADC_INPUT_AIN7); err_code = nrf_drv_saadc_init(NULL, saadc_callback); APP_ERROR_CHECK(err_code); nrf_saadc_resolution_set(NRF_SAADC_RESOLUTION_12BIT); err_code = nrf_drv_saadc_channel_init(0, &channel_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); } //========================================================================= // timer handler //========================================================================= void my_timer_handler(nrf_timer_event_t event_type, void* p_context) { if ( event_type == NRF_TIMER_EVENT_COMPARE0 ) { } else if ( event_type == NRF_TIMER_EVENT_COMPARE1 ) { nrf_gpio_pin_toggle(LED0_pin); } } //========================================================================= // init function //========================================================================= const nrf_drv_timer_t MY_TIMER_0 = NRF_DRV_TIMER_INSTANCE(0); void Init() { // saadc_init(); saadc_sampling_event_init(); saadc_sampling_event_enable(); nrf_drv_timer_config_t timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG; nrf_drv_timer_init(&MY_TIMER_0, &timer_cfg, &my_timer_handler); nrf_drv_timer_extended_compare(&MY_TIMER_0, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_ms_to_ticks(&MY_TIMER_0, 50), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true); nrf_drv_timer_extended_compare(&MY_TIMER_0, NRF_TIMER_CC_CHANNEL1, nrf_drv_timer_ms_to_ticks(&MY_TIMER_0, 100), // Channel_1 100ms NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true); nrf_drv_timer_enable(&MY_TIMER_0); }
