Hi everyone,
i have an Characteristic with attr_md.vloc = BLE_GATTS_VLOC_STACK;. Is it possible, when i send a notifcation to use params.p_dataand params.len to send data from a different location?
Thanks in advance, Cheers!
Hi everyone,
What do you mean by different location? Please clarify by editing the question.
When transmitting a notification, you should provide a pointer to where the data is located, and that is not relatead to BLE_GATTS_VLOC_STACK.
When creating a characteristic, setting attr_md.vloc = BLE_GATTS_VLOC_STACK; means that "Attribute Value is located in stack memory, no user memory is required". This sets where the data in a characteristic is stored, and that is independent of the "origin" of the data to transmit in a notification.
In the ble_app_uart example in SDK 6.0.0 in the \Board\pca10001\s110\experimental-folder, notifications are transmitted using sd_ble_gatt_hvx(..) the following way:
uint32_t ble_nus_send_string(ble_nus_t * p_nus, uint8_t * string, uint16_t length)
ble_gatts_hvx_params_t hvx_params;
if (p_nus == NULL)
return NRF_ERROR_NULL;
if ((p_nus->conn_handle == BLE_CONN_HANDLE_INVALID) || (!p_nus->is_notification_enabled))
if (length > BLE_NUS_MAX_DATA_LEN)
return NRF_ERROR_INVALID_PARAM;
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_nus->rx_handles.value_handle;
hvx_params.p_data = string;
hvx_params.p_len = &length;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
return sd_ble_gatts_hvx(p_nus->conn_handle, &hvx_params);
Hey Kristin, thanks for your reply and sorry for the delay. Alright, thus it would be possible to set the location of the memory of the characteristic to 'BLE_GATTS_VLOC_STACK;', thus if the client writes something in the characteristic he writes on the stack. But, if i want to notify the client, i can use a other memory location (just for the notification) and the actual value of the characteristic stays the same?
