GPIOTE polling
I've modified light switch client to read input from GPIO pins . I used int_pin_change as a reference for initializing inputs. The Int_change_pin example uses interrupts for detecting input but I need event polling in my application. When I set the value of GPIOTE_CONFIG_IN_SENSE_TOGGLE to false and download the code to nrf52DK all the LEDs are turned on. My application works with the interrupt mode, so I'm assuming the issue is not related to application. How do I configure GPIOTE_CONFIG_IN_SENSE_TOGGLE to detect input in event mode?
Sunil
  • FormerMember
    +1 FormerMember
    The attached code shows how to use GPIOTE to detect toggle on the input pin and then toggle the output pin.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
    * @defgroup gpiote_example_main main.c
    * @ingroup nrf_gpiote_example
    * @brief GPIOTE Example Application main file.
    * This file contains the source code for a sample application using GPIOTE.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "nrf_gpiote.h"
    #include "nrf_gpio.h"
    #include "boards.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "nrf_drv_gpiote.h"
    #include "app_error.h"
    #ifdef BSP_LED_0
        #define GPIO_OUTPUT_PIN_NUMBER BSP_LED_0  /**< Pin number for output. */
    #ifndef GPIO_OUTPUT_PIN_NUMBER
        #error "Please indicate output pin"
    #define GPIO_INPUT_PIN_NUMBER   BSP_BUTTON_0
    static void button_push_test(void)
    	uint32_t gpiote_event_addr;
    	uint32_t gpiote_task_addr;
    	ret_code_t err_code;
    	nrf_ppi_channel_t ppi_channel;
    	// Configure input
    	nrf_gpio_cfg_input(GPIO_INPUT_PIN_NUMBER, NRF_GPIO_PIN_NOPULL);
    	nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    	in_config.pull = NRF_GPIO_PIN_PULLUP;
    	err_code = nrf_drv_gpiote_in_init(GPIO_INPUT_PIN_NUMBER,&in_config, NULL);
    	gpiote_event_addr = nrf_drv_gpiote_in_event_addr_get(GPIO_INPUT_PIN_NUMBER);
    	// Configure output
    	nrf_gpio_cfg_output(GPIO_OUTPUT_PIN_NUMBER);
    	nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    	err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER, &out_config);
    	gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER);
    	// Set up PPI channel
    	err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
    	err_code = nrf_drv_ppi_channel_assign(ppi_channel, gpiote_event_addr, gpiote_task_addr);
      err_code = nrf_drv_ppi_channel_enable(ppi_channel);
    	// Enable GPIOTE
    	nrf_drv_gpiote_in_event_enable(GPIO_INPUT_PIN_NUMBER,false);
      nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER);
     * @brief Function for application main entry.
    		button_push_test();
        while (true)
            // Do Nothing - GPIO can be toggled without software intervention.
