How to develop a custom circuit with a nRF52810 Transceiver
I want to create a PCB circuit withe the nRF52810 Transceiver. If you do not understand what i have in mind:
http://si.farnell.com/nordic-semiconductor/nrf52810-qcaa-r7/bluetooth-soc-2mbps-2-5ghz-qfn/dp/2842313?st=nrf52
This link shows the transceiver which in turn needs to be on a custom made PCB. It has one job. To read the signal on a oximeter. The circuit for the filters, antenna, power supply from battery is designed.
All i wish to know is how to connect the nRF52810 transceiver to the elements. I know witch GPIO pins to use and how to connect my micro antenna, but i do not know witch pins are needed:
To power the transceiver with out errors.
To enable functions needed to receive data from the sensor and broadcast trough the antenna.
To program the transceiver.
I have bought the transceivers, now i only need to correctly connect the transceiver to everything else.
The datasheet is provided on the store page above for the pinout.
Thank you for the knowledge bestowed in advance.
