nrf52840 serial
If I put too many characters into a serial using IRQ mode, it stops reading input.
I haven't tried polling or DMA yet.
Using
  • nRF5_SDK_15.0.0_a53641a
  • gcc-arm-none-eabi 6.3.1 and I also tried segger
  • nRF52840-DK with a PCA10056 1.0.0
  • examples/peripheral/serial.
I can't get the onboard USB serial to work with flow control enabled(works with it disabled), so I'm doing testing with an FTDI breakout.
The serial example works consistently and correctly if I just type characters on the keyboard, but if I paste a chunk of text larger than 47 characters, the serial port reads between 20 and 40 characters, and then stops reading.
If I connect  a gps unit that emits NMEA sentences, it will read some of them, and then stop reading. ~47 characters every second, and it was getting like 3-10 seconds.
Looking at what it does with gdb (I have not yet followed too closely) it seems that nrf_serial_read function just returns nothing, and everything else keeps working.
It does this with and without the hardware flow control.
I tried increasing the buffer size, but it didn't seem to change the issue.
If I change the timeout parameter on nrf_serial_read to 0 (as documentation says it really should be in IRQ contexts), it actually reads less characters when you paste data.
https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.0.0/group__nrf__serial.html#details
Am I using the example wrong, or is this a bug?
