The following is the guide under this ticket: devzone.nordicsemi.com/.../where-i-can-find-the-example-of-usbd-dfu-for-pc-side
Terje said "you can use nrfjprog with "nrfjprog --readcode backup.hex" for storing the flash contents in a hexfile named "backup.hex". Then you can program it back onto the Dongle at any later time if needed (with "nrfjprog --program backup.hex".)"
However, I met several issue when I use J-LINK to program it. The steps are as follows.
1) use nrfjprog with "nrfjprog --readcode nrfjprog_readback.hex". See the attachment.
2) I used JFlash --> readback -->Entire Chip, to save it as "jflash_readback.hex". See the attachment.
3) issue nrfjprog --eraseall, and the result is ok.
$ nrfjprog --eraseall
Erasing user available code and UICR flash areas.
Applying system reset.
4) use "nrfjprog --program nrfjprog_readback.hex". And the result is, dongle doesn't work. Just like a bricked dongle.
Parsing hex file.
Reading flash area to program to guarantee it is erased.
Checking that the area to write is not protected.
Programming device.
5) use JFlash to open jflash_readback.hex and click Program&verify. And it works!!!!!
That's very strange. May I ask what's the difference? Why can't I use nrfjprog to program?
Jlink version is 6.22g
nrfjprog is 9.7.3
nrfjprog_readback.hexjflash_readback.hex
BY THE WAY, I found that, if I turn on log when issuing nrfjprog, it shows "device nrf52832_XXAA". Is this related to this problem? Thanks.
nrfjprog --eraseall --family NRF52 --log
nrfjprog version 9.7.3
nRF_open_dll
. nRF52_open_dll
. . nRF52_dll_version
nRF_enum_emu_snr
. nRF52_enum_emu_snr
. . nRF52_enum_emu_snr
nRF_enum_emu_snr
nRF_connect_to_emu_with_snr
. nRF52_connect_to_emu_with_snr
. . nRF52_is_connected_to_emu
. . nRF52_connect_to_emu_with_snr
. . . nRF52_connect_to_emu_without_snr
. . . nRF52_connect_to_emu_without_snr: JLink: Firmware: J-Link V9 compiled Jan 11 2018 11:06:30
. . . nRF52_connect_to_emu_without_snr: JLink: Hardware: V9.40
. . . nRF52_connect_to_emu_without_snr: JLink: S/N: xxxxxx
. . . nRF52_connect_to_emu_without_snr: JLink: Feature(s): RDI, GDB, FlashDL, FlashBP, JFlash
. . . nRF52_connect_to_emu_without_snr: JLink: TELNET listener socket opened on port 19021
. . . nRF52_connect_to_emu_without_snr: JLink: WEBSRV Starting webserver
. . . nRF52_connect_to_emu_without_snr: JLink: (0072ms, 0075ms total)
. . . nRF52_connect_to_emu_without_snr: JLink: WEBSRV Webserver running on local port 19081
. . . nRF52_connect_to_emu_without_snr: JLink: returns O.K.
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_GetHWStatus(...)
. . . nRF52_connect_to_emu_without_snr: JLink: returns 0x00
. . . nRF52_connect_to_emu_without_snr: JLink: (0003ms, 0078ms total)
. . . nRF52_connect_to_emu_without_snr: There is no generic nRF52 device in J-Link, so we select NRF52832_xxAA.
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_ExecCommand("Device = NRF52832_xxAA", ...).
. . . nRF52_connect_to_emu_without_snr: JLink: C:\Program Files (x86)\SEGGER\JLink_V622g\JLinkDevices.xml evaluated successfully.
. . . nRF52_connect_to_emu_without_snr: JLink: Device "NRF52832_XXAA" selected.
. . . nRF52_connect_to_emu_without_snr: JLink: (0112ms, 0190ms total)
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_ExecCommand("SetRestartOnClose = 0", ...).
. . . nRF52_connect_to_emu_without_snr: JLink: returns 0x01
. . . nRF52_connect_to_emu_without_snr: JLink: (0000ms, 0190ms total)
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_ExecCommand("DisableFlashDL", ...).
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_ExecCommand("SetDbgPowerDownOnClose = 1", ...).
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
. . . nRF52_connect_to_emu_without_snr: JLink: (0000ms, 0191ms total)
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_TIF_Select(JLINKARM_TIF_SWD)
. . . nRF52_connect_to_emu_without_snr: JLink: (0020ms, 0211ms total)
. . . nRF52_connect_to_emu_without_snr: JLink: JLINK_SetSpeed(2000)
. . . nRF52_connect_to_emu_without_snr: JLink: (0002ms, 0213ms total)
nRF_read_device_version
. nRF52_read_device_version
. . nRF52_is_connected_to_emu: JLink: JLINK_IsOpen()
. . nRF52_is_connected_to_emu: JLink: returns 0x01
. . nRF52_is_connected_to_emu: JLink: (0000ms, 0214ms total)
. . nRF52_is_connected_to_device
. . nRF52_is_connected_to_device: JLink: JLINK_IsConnected()
. . nRF52_is_connected_to_device: JLink: returns FALSE
. . nRF52_is_connected_to_device: JLink: (0000ms, 0214ms total)
. . nRF52_readback_status
. . . nRF52_is_ctrl_ap_available
. . . . nRF52_read_access_port_register
. . . . . nRF52_coresight_configure
. . . . . nRF52_coresight_configure: JLink: JLINK_CORESIGHT_Configure()
. . . . . nRF52_coresight_configure: JLink: returns 0
. . . . . nRF52_coresight_configure: JLink: (0004ms, 0218ms total)
. . . . . nRF52_power_debug_and_system_regions
. . . . . . nRF52_write_debug_port_register
. . . . . . nRF52_write_debug_port_register: JLink: JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
. . . . . . nRF52_write_debug_port_register: JLink: returns 0
. . . . . . nRF52_write_debug_port_register: JLink: (0005ms, 0223ms total)
. . . . . . nRF52_write_debug_port_register: JLink: JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x50000000)
. . . . . . nRF52_write_debug_port_register: JLink: (0005ms, 0228ms total)
. . . . nRF52_read_access_port_register: JLink: JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
. . . . nRF52_read_access_port_register: JLink: returns 0
. . . . nRF52_read_access_port_register: JLink: (0002ms, 0230ms total)
. . . . nRF52_read_access_port_register: JLink: JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
. . . . nRF52_read_access_port_register: JLink: -- Value=0x02880000
. . . . nRF52_read_access_port_register: JLink: (0005ms, 0235ms total)
. . . . nRF52_read_access_port_register: JLink: (0004ms, 0239ms total)
. . . . nRF52_read_access_port_register: JLink: (0005ms, 0244ms total)
. . . . nRF52_read_access_port_register: JLink: (0005ms, 0249ms total)
. . . . nRF52_read_access_port_register: JLink: (0005ms, 0254ms total)
. . . . nRF52_read_access_port_register: JLink: (0003ms, 0257ms total)
. . . . nRF52_read_access_port_register: JLink: (0004ms, 0261ms total)
. . . nRF52_read_access_port_register: JLink: JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
. . . nRF52_read_access_port_register: JLink: (0005ms, 0266ms total)
. . . nRF52_read_access_port_register: JLink: -- Value=0x00000001
. . . nRF52_read_access_port_register: JLink: (0003ms, 0269ms total)
. . . nRF52_read_access_port_register: JLink: (0005ms, 0274ms total)
. . . nRF52_read_access_port_register: JLink: (0005ms, 0279ms total)
. . . nRF52_read_access_port_register: JLink: (0003ms, 0282ms total)
. . . nRF52_read_access_port_register: JLink: (0005ms, 0287ms total)
. . . nRF52_read_access_port_register: JLink: (0004ms, 0291ms total)
. . . nRF52_read_access_port_register: JLink: (0005ms, 0296ms total)
. . nRF52_connect_to_device
. . nRF52_connect_to_device: JLink: JLINK_Connect()
. . nRF52_connect_to_device: JLink: >0x10B TIF>
. . nRF52_connect_to_device: JLink: Found SW-DP with ID 0x2BA01477
. . nRF52_connect_to_device: JLink: >0x0D TIF>
. . nRF52_connect_to_device: JLink: >0x28 TIF>
. . nRF52_connect_to_device: JLink: >0x35 TIF>
. . nRF52_connect_to_device: JLink: Scanning AP map to find all available APs
. . nRF52_connect_to_device: JLink: AP[2]: Stopped AP scan as end of AP map has been reached
. . nRF52_connect_to_device: JLink: AP[0]: AHB-AP (IDR: 0x24770011)
. . nRF52_connect_to_device: JLink: AP[1]: JTAG-AP (IDR: 0x02880000)
. . nRF52_connect_to_device: JLink: Iterating through AP map to find AHB-AP to use
. . nRF52_connect_to_device: JLink: >0x42 TIF>
. . nRF52_connect_to_device: JLink: AP[0]: Core found
. . nRF52_connect_to_device: JLink: AP[0]: AHB-AP ROM base: 0xE00FF000
. . nRF52_connect_to_device: JLink: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
. . nRF52_connect_to_device: JLink: Found Cortex-M4 r0p1, Little endian.
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(4 bytes @ 0xE000EDF0)
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(4 bytes @ 0xE0002000)
. . nRF52_connect_to_device: JLink: FPUnit: 0 code (BP) slots and 0 literal slots
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(4 bytes @ 0xE000EDFC)
. . nRF52_connect_to_device: JLink: -- CPU_WriteMem(4 bytes @ 0xE000EDFC)
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(4 bytes @ 0xE0001000)
. . nRF52_connect_to_device: JLink: -- CPU_WriteMem(4 bytes @ 0xE0001000)
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(4 bytes @ 0xE000ED88)
. . nRF52_connect_to_device: JLink: -- CPU_WriteMem(4 bytes @ 0xE000ED88)
. . nRF52_connect_to_device: JLink: CoreSight components:
. . nRF52_connect_to_device: JLink: ROMTbl[0] @ E00FF000
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF000)
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FFFF0)
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FFFE0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][2]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF010)
. . nRF52_connect_to_device: JLink: ROMTbl[0][6]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF020)
. . nRF52_connect_to_device: JLink: ROMTbl[0][10]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF030)
. . nRF52_connect_to_device: JLink: ROMTbl[0][14]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF040)
. . nRF52_connect_to_device: JLink: ROMTbl[0][18]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF050)
. . nRF52_connect_to_device: JLink: ROMTbl[0][22]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF060)
. . nRF52_connect_to_device: JLink: ROMTbl[0][26]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF070)
. . nRF52_connect_to_device: JLink: ROMTbl[0][30]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF080)
. . nRF52_connect_to_device: JLink: ROMTbl[0][34]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF090)
. . nRF52_connect_to_device: JLink: ROMTbl[0][38]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF0A0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][42]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF0B0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][46]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF0C0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][50]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF0D0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][54]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF0E0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][58]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF0F0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][62]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF100)
. . nRF52_connect_to_device: JLink: ROMTbl[0][66]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF110)
. . nRF52_connect_to_device: JLink: ROMTbl[0][70]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF120)
. . nRF52_connect_to_device: JLink: ROMTbl[0][74]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF130)
. . nRF52_connect_to_device: JLink: ROMTbl[0][78]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF140)
. . nRF52_connect_to_device: JLink: ROMTbl[0][82]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF150)
. . nRF52_connect_to_device: JLink: ROMTbl[0][86]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF160)
. . nRF52_connect_to_device: JLink: ROMTbl[0][90]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF170)
. . nRF52_connect_to_device: JLink: ROMTbl[0][94]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF180)
. . nRF52_connect_to_device: JLink: ROMTbl[0][98]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF190)
. . nRF52_connect_to_device: JLink: ROMTbl[0][102]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF1A0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][106]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF1B0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][110]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF1C0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][114]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF1D0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][118]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF1E0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][122]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF1F0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][126]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF200)
. . nRF52_connect_to_device: JLink: ROMTbl[0][130]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF210)
. . nRF52_connect_to_device: JLink: ROMTbl[0][134]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF220)
. . nRF52_connect_to_device: JLink: ROMTbl[0][138]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF230)
. . nRF52_connect_to_device: JLink: ROMTbl[0][142]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF240)
. . nRF52_connect_to_device: JLink: ROMTbl[0][146]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF250)
. . nRF52_connect_to_device: JLink: ROMTbl[0][150]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF260)
. . nRF52_connect_to_device: JLink: ROMTbl[0][154]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF270)
. . nRF52_connect_to_device: JLink: ROMTbl[0][158]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF280)
. . nRF52_connect_to_device: JLink: ROMTbl[0][162]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF290)
. . nRF52_connect_to_device: JLink: ROMTbl[0][166]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF2A0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][170]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF2B0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][174]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF2C0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][178]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF2D0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][182]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF2E0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][186]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF2F0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][190]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF300)
. . nRF52_connect_to_device: JLink: ROMTbl[0][194]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF310)
. . nRF52_connect_to_device: JLink: ROMTbl[0][198]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF320)
. . nRF52_connect_to_device: JLink: ROMTbl[0][202]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF330)
. . nRF52_connect_to_device: JLink: ROMTbl[0][206]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF340)
. . nRF52_connect_to_device: JLink: ROMTbl[0][210]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF350)
. . nRF52_connect_to_device: JLink: ROMTbl[0][214]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF360)
. . nRF52_connect_to_device: JLink: ROMTbl[0][218]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF370)
. . nRF52_connect_to_device: JLink: ROMTbl[0][222]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF380)
. . nRF52_connect_to_device: JLink: ROMTbl[0][226]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF390)
. . nRF52_connect_to_device: JLink: ROMTbl[0][230]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF3A0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][234]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF3B0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][238]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF3C0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][242]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF3D0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][246]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF3E0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][250]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: -- CPU_ReadMem(16 bytes @ 0xE00FF3F0)
. . nRF52_connect_to_device: JLink: ROMTbl[0][254]: E00FF000, CID: 9E3C1C04, PID: 9E3C1C04 ???
. . nRF52_connect_to_device: JLink: returns 0x00
. . nRF52_connect_to_device: JLink: (0418ms, 0714ms total)
. . . nRF52_read_device_version
. . . . nRF52_read_u32
. . . . nRF52_read_u32: JLink: JLINK_ExecCommand("InvalidateCache", ...).
. . . . nRF52_read_u32: JLink: returns 0x00
. . . . nRF52_read_u32: JLink: (0000ms, 0714ms total)
. . . . nRF52_read_u32: JLink: JLINK_ReadMemU32(0x10000130, 0x0001 Items, ...)
. . . . nRF52_read_u32: JLink: -- CPU_ReadMem(4 bytes @ 0x10000130)
. . . . nRF52_read_u32: JLink: returns 0xFFFFFFFF
. . . . nRF52_read_u32: JLinkARM.dll ReadMemU32 returned error -1.
. . . nRF52_disconnect_from_device
. . . . nRF52_is_connected_to_device
. . . . nRF52_is_connected_to_device: JLink: JLINK_IsConnected()
. . . . nRF52_is_connected_to_device: JLink: returns TRUE
. . . . nRF52_is_connected_to_device: JLink: (0000ms, 0714ms total)
. . . . nRF52_disconnect_from_emu
. . . . . nRF52_is_connected_to_device
. . . . . nRF52_is_connected_to_device: JLink: JLINK_IsConnected()
. . . . . nRF52_is_connected_to_device: JLink: returns TRUE
. . . . . nRF52_is_connected_to_device: JLink: (0001ms, 0715ms total)
. . . . . nRF52_write_u32
. . . . . nRF52_write_u32: JLink: JLINK_WriteU32(0xE000EDFC, 0x00000000)
. . . . . nRF52_write_u32: JLink: -- CPU is running
. . . . . nRF52_write_u32: JLink: -- CPU_WriteMem(4 bytes @ 0xE000EDFC)
. . . . . nRF52_write_u32: JLink: returns 0xFFFFFFFF
. . . . . nRF52_write_u32: JLink: (0000ms, 0715ms total)
. . . . . nRF52_write_u32: JLinkARM.dll WriteU32 returned error -1.
nRF_close_dll
. nRF52_close_dll
. . nRF52_is_connected_to_emu: JLink: (0000ms, 0715ms total)
. . . nRF52_is_connected_to_device: JLink: (0000ms, 0715ms total)
. . . nRF52_write_u32: JLink: (0001ms, 0716ms total)
