I am currently trying to implement SAADC sampling from three channels into the same sample buffer (device is a 3-axis accelerometer, ADXL335). The root objective of my project is to read from three TWI sensors, one analog 3-output sensor (hence the SAADC sampling) and send values from these sensors to a BLE central device using BLE uart. I've been integrating code from the twi_sensor example and SAADC_simpler example into the ble_uart example, and have successfully gotten the TWI interfaces to work. However, the SAADC has been more difficult. Only zeros are present in the buffer after sampling.
Here are the tools of my work:
Laird BL652 DVK kit (bluetooth module for nRF52832)
Keil uVision 5 IDE (ATMEL ATSAM3U is the JTAG (SWD rather) interface, no SWO support)
Nordic SDK 15.0.0, SD S132
I copied all of the SAADC initialization code from the SAADC_simpler example, then I call nrf_drv_saadc_sample() which, according to the Nordic documentation online, should sample all initialized channels.
I've enabled SAADC driver in sdk_config.h to be 14 bit accuracy, oversampling disabled, low power mode disabled, and interrupt priority of 7. Here are the initialization functions I have so far:
#define SAMPLES_IN_BUFFER 3
ret_code_t err_code;
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
NRF_LOG_INFO("%d\r\n", p_event->data.done.p_buffer[0]);
void saadc_init(void)
nrf_saadc_channel_config_t channel_config_x \
= NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(ARDUINO_A1_PIN); // nRF pin4
nrf_saadc_channel_config_t channel_config_y \
= NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(ARDUINO_A2_PIN); // nRF pin28
nrf_saadc_channel_config_t channel_config_z \
= NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(ARDUINO_A3_PIN); // nRF pin 29
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config_x);
err_code = nrf_drv_saadc_channel_init(1, &channel_config_y);
err_code = nrf_drv_saadc_channel_init(2, &channel_config_z);
err_code = nrf_drv_saadc_buffer_convert(adxl_sample, SAMPLES_IN_BUFFER);
Then, I implement these functions in my main function, along with the initialization functions I have for BLE and TWI sensors:
bool erase_bonds;
is_connected = false;
// Initialize BLE
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Initialize IIC
twi_APDS0_init();
twi_APDS1_init();
init_apds(&APDS0_twi, APDS_ADDR);
init_apds(&APDS1_twi, APDS_ADDR);
// Initialize SAADC Sampling
saadc_init();
bool is_busy = nrfx_saadc_is_busy();
// Start execution.
advertising_start();
// Point to the SAADC sample location
uint8_t example[2];
uint32_t interval = &example[1] - &example[0]; // hard arithmetic for memory location step between vector locations
nrf_saadc_value_t *p_adxl_sample = &adxl_sample[0]; // point to the base of the sample
uint16_t adxl_samples_16[3] = {((uint16_t)(*p_adxl_sample)), ((uint16_t)*(p_adxl_sample + interval)), ((uint16_t)*(p_adxl_sample + 2*interval))}; //dereference the sample values and put them into a convenient place
uint8_t adxl_samples_8[6]; // vector for 8 bit wide sample values
uint16_t *p_adxl_samples_16 = &adxl_samples_16[0]; // point to the base of the new sample vector
uint8_t *p_adxl_samples_8[6]; // point to the base of the 8 bit wide sample vector
p_adxl_samples_8[0] = (uint8_t *)p_adxl_samples_16; // write the base address of the 16 bit vector to the base address of the 8 bit vector
for(int i = 1; i < 6; i++) // write the correct addresses of each 8 bit location based on the interval found above
p_adxl_samples_8[i] = p_adxl_samples_8[i-1] + interval;
for(int i = 0; i < 6; i++) // dereference the values in adxl_samples_16 vector to the 8 bit vector
adxl_samples_8[i] = *p_adxl_samples_8[5-i]; // The reverse order is just for convenience when reading them after BLE send
// Enter main loop.
for (;;)
if(!is_connected)
idle_state_handle();
if(is_connected)
if(is_busy)
uint32_t err_code = nrf_drv_saadc_buffer_convert(adxl_sample, SAMPLES_IN_BUFFER);
nrf_delay_ms(1);
err_code = nrf_drv_saadc_sample();
nrf_delay_ms(1);
send_iic_values(&m_nus, &adxl_samples_8[0], p_packet_size);
nrf_delay_ms(2000);
} //if(is_connected)
} //for(;;)
} //main
The complex pointer manipulation of the adxl_sample is necessary because the ble_nus_data_send function can only send byte-sized values of type uint8_t. I've proven that the formula of pointers works by hard-writing values to the sample and sending them, but there are probably ways I could improve my work.
I should also mention that my board configuration is definitely correct. I've probed around the DVK board and found that the voltages into the selected inputs of the nRF52832 are definitely nonzero and reasonable. Also, as mentioned before, I've gotten the TWI to work so I'm familiar with how the pca10040.h file works.
Is there something I'm missing? What about calibration? The nordic documentation made this task seem straightforward but I've had a lot of trouble and I'm running out of ideas. Any help is appreciated.
