Hi
I am developing on Adafruit LE UART Friend (https://www.adafruit.com/product/2479) platform.
Compiler: GCC 7.2.1
IDE: NetBeans
NRF SDK: 12.3, SoftDevice S130
Debugger used SEGGER J-Link Base
This LE UART device uses a MDBT40 module which is suppose to have a 16MHz Crystal for clock inside the module as per my understanding.
Now my problem is when i try to run a code related to softdevise it is not working when the clock sours is crystal. On changing the settings in the config file to internal oscillator it seems to work but I would like to use the crystal instead for low power consumption.
The Code below for clock settings are not working on MTBT40 (works in the NRF51 Dongle PCM10031)
#define NRF_CLOCK_LFCLKSRC {.source = NRF_CLOCK_LF_SRC_XTAL, \
.rc_ctiv = 0, \
.rc_temp_ctiv = 0, \
.xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM}
I also tried using
NRF_GPIO->DIRSET = (1 << 19); // Use LED or other accessible pin if you want to observe the application state
NRF_GPIO->DIRSET = (1 << 18);
NRF_GPIO->OUTCLR = (1 << 19);
NRF_GPIO->OUTCLR = (1 << 18);
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
NRF_GPIO->OUTSET = (1 << 19);
NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos;
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
NRF_GPIO->OUTSET = (1 << 18);
When I added this code it definitely didnt go past the 2nd while loop as the GPIO 18 never went high. I made sure I used this code before the softdevice is enabled as well.
When i try to use the RC oscillator the code is working for MTBT40
#define NRF_CLOCK_LFCLKSRC {.source = NRF_CLOCK_LF_SRC_RC , \
.rc_ctiv = 0, \
Now all this being said the Adafruit UART firmware works fine on this hardware (although I dont know if Adafruit is using the external Chrystal) and as Raytac is a reputed supplier certified by Nordic I am assuming both the hardware I used to test is fine.
Please help me find what I am doing wrong. Any help will be appreciated.
Thank You
Kaushik Ray
