How to handle UART data? (nRF52832)
Hi. I'm using external board with nRF52832 and GPS. (SDK15.0.0)
I used ble_app_uart example and succeed in receive data in my nRF UART v2.0 app.
I got this kind of data every 1sec.
$GPGGA,215235.670,3735.0064,N,12701.6746,E,1,03,50.0,0.0,M,19.6,M,0.0,0000*4F
$GPGSA,A,2,10,08,02,,,,,,,,,,50.0,50.0,20.0*0A
$GPGSV,3,1,10,26,78,314,00,29,71,017,00,24,48,156,00,10,44,079,46*79
$GPGSV,3,2,10,21,39,309,32,08,21,046,36,09,16,187,00,02,14,151,35*73
$GPGSV,3,3,10,06,14,296,00,15,06,319,00*7F
$GPRMC,215235.670,A,3735.0064,N,12701.6746,E,0.000000,,060905,,*12
$GPGGA,215236.670,3735.0066,N,12701.6748,E,1,03,50.0,0.0,M,19.6,M,0.0,0000*40
However I want to receive only $GPRMC related lines with every 2 or 3sec.
I found uart_event_handle() function is related with receving data, but I don't know how to modify it.
Here's the function
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            UNUSED_VARIABLE(app_uart_get(&b[index]));
            index++;
         if (   data_array[4]=='M' && ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)) ) )
           NRF_LOG_HEXDUMP_DEBUG(data_array, index); //No matter
           do
             //if(data_array[3]=='R')
             if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                (err_code != NRF_ERROR_NOT_FOUND) )
           } while (err_code == NRF_ERROR_BUSY);
           index = 0;
        case APP_UART_FIFO_ERROR:
I tried ' if(data_array[4]=='M') ' and it's not working.
Help! Thanks.
ps. I'm not living in English speaking country. So I'm not fluent in writing english. Sorry
    You are on the right track. You should use the uart_event_handle() function.
    Originally it works this way:
    It is called every time the function gets called every time the nRF receives a byte/char on the UART. It stores that character in an array, data_array[], and checks if the array is full, or if the last char was '\n'. If it was, it will send the array on the BLE link.
    I notice that $GPRMC is the only sequence startin with '$', and 'R' is the 4th char.
    You will have to test and verify that this is working yourself, but I may give you some hints to get started.
    Since you only are looking for strings starting with $, you can do something like:
                index++;
                if (data_array[0] != '$')
                    index = 0;
    This way, you will not start to store data until you get a '$'.
    Then, when index reaches 3, you can check for an 'R':
                index++;
                    index = 0;
                if ((index-1 >= 3) && (data_array[3] != 'R'))
                    index = 0;
    If the code passes this point, it will write to the data_array only when it starts with $GPRMC (or actually $**R), and you can continue to collect the data from the UART.
    if you only want to do it every third second, you can either use a timer to set a variable that you also check before collecting data, or you can set a counter to only collect the data every third time you get a message starting with $GPRMC.
    Did this make any sense, or was it only confusing?
    Edvin
  • Wow!!! I understood and it works perfect !!
    Thank you for very detailed explanation and the code!
  • hello edvin ,
     i am kishor new to this nrf52 module  , actually iam   implementing the  code  for  gps master and slave clock , i want to send  total gprmc packet  after receiving the master ble to slave ble ..   i am usng the sample code ble_app_uart(), in that rx buffer  sige having the only one byte  sholu i chage that bugger size, and can u  suggest the  little code
