ANCS example
I have tried the following example:
infocenter.nordicsemi.com/index.jsp
Everything works fine (I can generate a notification via a calendar event and see it via the nRF serial port) except "Testing with nRF Connect". No one service is discovered and hence I have no means to send '00 18 06 02 01 02 03 04' to characteristic 0x120D.
I'm using nRF Connect 1.8.6, SDK15.0 on a nRF52840-Preview-DK and iOS 11.4.1.
In fact, I would like to check if a hacker application installed on an iOS device can fake notifications (as you propose to do with nRF Connect).
I was surprised that pairing information is shared between applications. Moreover, an existing opened BLE connection to a device can be also shared with another application.
I tried to write my own iOS test application. When I open a connection someone close it just after and I have no idea for which reason. The same happens with LightBlue. However, I noticed that a "Forget this device" in the Preferences and an "Erase bonds" on the nRF followed by a connection (either from my test program or LightBlue) don't do that: the connection stay opened.
So I have the following questions:
- Do I use nrf Connect incorrectly? How can I send '00 18 ...' to 0x120D?
- Is it possible to have fake notifications from a hacked appli?
- What can be the reason of the close after open?
Thanks in advance for helping me.
Bernard
    I realized that I was doing something wrong using nRF Connect on an iPad: your example propose to use nRF Connect from the Desktop.
    So I did it on my Mac with an additional nRF board. As explained, I selected "Perform bonding" in the Security parameters (after having loaded ANCS_central.ncs) and did a Connect but got:
    Error: Failed to reply security parameters. (NRF_ERROR_INTERNAL)
    I also tried to select "Enable LE Secure Connection pairing" but it doesn't matter.
    The connection is opened but insecured (lock opened).
    For nRF Connect version:
    • Version 2.2.0 is displayed in the info box
    • v2.4.0 is displayed on the top.
    The interresting part of the log file follows.
    So I have now the following questions:
    • Why do I get an error?
    • Is it possible to have fake notifications from a hacked appli?
    • nRF connect on the iPad (same under Android) doesn't see ANCS as an offered service? Are they filtered to avoid fake notifications?
    Thanks in advance for your help.
    Bernard
    2018-07-24T12:17:09.581Z DEBUG 429 -> [00 8a 01 01 a0 00 20 00 3c 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:7 payload_length:a data_integrity:1 header_checksum:55 err_code:0
    2018-07-24T12:17:09.584Z DEBUG 411/ 0 <- []
    type: ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:09.589Z INFO Scan started
    2018-07-24T12:17:09.589Z DEBUG 412/ 0 <- [01 8a 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:6 payload_length:6 data_integrity:1 header_checksum:9b err_code:0
    2018-07-24T12:17:09.589Z DEBUG 430 -> []
    type: ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:09.701Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:09.700Z connHandle:65535 rssi:87 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:09.703Z DEBUG 413/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a a9 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:6 payload_length:32 data_integrity:1 header_checksum:df err_code:0
    2018-07-24T12:17:09.703Z DEBUG 431 -> []
    type: ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:09.795Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:09.794Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:09.797Z DEBUG 414/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:6 payload_length:36 data_integrity:1 header_checksum:9e err_code:0
    2018-07-24T12:17:09.797Z DEBUG 432 -> []
    type: ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:09.799Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:09.799Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:09.801Z DEBUG 415/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:6 payload_length:17 data_integrity:1 header_checksum:8f err_code:0
    2018-07-24T12:17:09.801Z DEBUG 433 -> []
    type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:09.816Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:09.812Z connHandle:65535 rssi:82 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:09.817Z DEBUG 416/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ae 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:6 payload_length:32 data_integrity:1 header_checksum:dc err_code:0
    2018-07-24T12:17:09.817Z DEBUG 434 -> []
    type: ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:09.820Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:09.818Z connHandle:65535 rssi:82 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:09.821Z DEBUG 417/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ae 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:6 payload_length:28 data_integrity:1 header_checksum:7c err_code:0
    2018-07-24T12:17:09.821Z DEBUG 435 -> []
    type: ACK reliable: no seq#:0 ack#:5 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:10.009Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.008Z connHandle:65535 rssi:87 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.012Z DEBUG 418/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a a9 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:6 payload_length:32 data_integrity:1 header_checksum:da err_code:0
    2018-07-24T12:17:10.012Z DEBUG 436 -> []
    2018-07-24T12:17:10.015Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.014Z connHandle:65535 rssi:42 peerAddr:[address:7D:1C:1D:4C:BE:2C type:randomPrivateResolvable addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] manufacturerSpecificData:76,0,16,2,11,0]
    2018-07-24T12:17:10.017Z DEBUG 419/ 0 <- [02 1d 00 ff ff 04 2c be 4c 1d 1c 7d 01 41 4e 43 53 a6 2a d6 00 0b 01 02 01 06 07 ff 4c 00 10 02 0b 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:6 payload_length:22 data_integrity:1 header_checksum:da err_code:0
    2018-07-24T12:17:10.017Z DEBUG 437 -> []
    type: ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0
    2018-07-24T12:17:10.019Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.019Z connHandle:65535 rssi:41 peerAddr:[address:7D:1C:1D:4C:BE:2C type:randomPrivateResolvable addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:10.020Z DEBUG 420/ 0 <- [02 1d 00 ff ff 04 2c be 4c 1d 1c 7d 01 41 4e 43 53 a6 2a d7 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:6 payload_length:17 data_integrity:1 header_checksum:8a err_code:0
    2018-07-24T12:17:10.020Z DEBUG 438 -> []
    2018-07-24T12:17:10.109Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.108Z connHandle:65535 rssi:83 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.110Z DEBUG 421/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ad 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:10.110Z DEBUG 439 -> []
    2018-07-24T12:17:10.310Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.309Z connHandle:65535 rssi:86 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.312Z DEBUG 422/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a aa 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:6 payload_length:32 data_integrity:1 header_checksum:de err_code:0
    2018-07-24T12:17:10.312Z DEBUG 440 -> []
    2018-07-24T12:17:10.316Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.315Z connHandle:65535 rssi:85 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:10.317Z DEBUG 423/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ab 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:6 payload_length:28 data_integrity:1 header_checksum:7e err_code:0
    2018-07-24T12:17:10.317Z DEBUG 441 -> []
    2018-07-24T12:17:10.396Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.395Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:10.398Z DEBUG 424/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:6 payload_length:36 data_integrity:1 header_checksum:9c err_code:0
    2018-07-24T12:17:10.398Z DEBUG 442 -> []
    2018-07-24T12:17:10.400Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.400Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:10.402Z DEBUG 425/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:6 payload_length:17 data_integrity:1 header_checksum:8d err_code:0
    2018-07-24T12:17:10.402Z DEBUG 443 -> []
    2018-07-24T12:17:10.409Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.408Z connHandle:65535 rssi:81 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.410Z DEBUG 426/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a af 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:10.410Z DEBUG 444 -> []
    2018-07-24T12:17:10.414Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.414Z connHandle:65535 rssi:81 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:10.415Z DEBUG 427/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a af 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:6 payload_length:28 data_integrity:1 header_checksum:7a err_code:0
    2018-07-24T12:17:10.415Z DEBUG 445 -> []
    2018-07-24T12:17:10.609Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.608Z connHandle:65535 rssi:86 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.611Z DEBUG 428/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a aa 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:6 payload_length:32 data_integrity:1 header_checksum:d8 err_code:0
    2018-07-24T12:17:10.611Z DEBUG 446 -> []
    2018-07-24T12:17:10.615Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.614Z connHandle:65535 rssi:85 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:10.616Z DEBUG 429/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ab 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:6 payload_length:28 data_integrity:1 header_checksum:80 err_code:0
    2018-07-24T12:17:10.616Z DEBUG 447 -> []
    2018-07-24T12:17:10.699Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.697Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:10.700Z DEBUG 430/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    2018-07-24T12:17:10.700Z DEBUG 448 -> []
    2018-07-24T12:17:10.702Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.702Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:10.704Z DEBUG 431/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    2018-07-24T12:17:10.704Z DEBUG 449 -> []
    2018-07-24T12:17:10.711Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.710Z connHandle:65535 rssi:84 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.712Z DEBUG 432/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ac 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:10.713Z DEBUG 450 -> []
    2018-07-24T12:17:10.717Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.716Z connHandle:65535 rssi:83 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:10.718Z DEBUG 433/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ad 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    2018-07-24T12:17:10.718Z DEBUG 451 -> []
    2018-07-24T12:17:10.807Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.806Z connHandle:65535 rssi:84 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.808Z DEBUG 434/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ac 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:10.809Z DEBUG 452 -> []
    2018-07-24T12:17:10.814Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.812Z connHandle:65535 rssi:83 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:10.817Z DEBUG 435/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ad 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    2018-07-24T12:17:10.817Z DEBUG 453 -> []
    2018-07-24T12:17:10.903Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:10.901Z connHandle:65535 rssi:85 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:10.904Z DEBUG 436/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ab 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:10.904Z DEBUG 454 -> []
    2018-07-24T12:17:10.909Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:10.908Z connHandle:65535 rssi:86 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:10.912Z DEBUG 437/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a aa 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    2018-07-24T12:17:10.912Z DEBUG 455 -> []
    2018-07-24T12:17:11.100Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.099Z connHandle:65535 rssi:86 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:11.101Z DEBUG 438/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a aa 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:11.101Z DEBUG 456 -> []
    2018-07-24T12:17:11.105Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.105Z connHandle:65535 rssi:44 peerAddr:[address:7D:1C:1D:4C:BE:2C type:randomPrivateResolvable addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] manufacturerSpecificData:76,0,16,2,11,0]
    2018-07-24T12:17:11.107Z DEBUG 439/ 0 <- [02 1d 00 ff ff 04 2c be 4c 1d 1c 7d 01 41 4e 43 53 a6 2a d4 00 0b 01 02 01 06 07 ff 4c 00 10 02 0b 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:6 payload_length:22 data_integrity:1 header_checksum:de err_code:0
    2018-07-24T12:17:11.107Z DEBUG 457 -> []
    2018-07-24T12:17:11.110Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:11.110Z connHandle:65535 rssi:43 peerAddr:[address:7D:1C:1D:4C:BE:2C type:randomPrivateResolvable addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:11.112Z DEBUG 440/ 0 <- [02 1d 00 ff ff 04 2c be 4c 1d 1c 7d 01 41 4e 43 53 a6 2a d5 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:6 payload_length:17 data_integrity:1 header_checksum:8e err_code:0
    2018-07-24T12:17:11.112Z DEBUG 458 -> []
    2018-07-24T12:17:11.205Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.204Z connHandle:65535 rssi:86 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:11.206Z DEBUG 441/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a aa 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:6 payload_length:32 data_integrity:1 header_checksum:db err_code:0
    2018-07-24T12:17:11.206Z DEBUG 459 -> []
    2018-07-24T12:17:11.210Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:11.210Z connHandle:65535 rssi:86 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:11.212Z DEBUG 442/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a aa 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:6 payload_length:28 data_integrity:1 header_checksum:7b err_code:0
    2018-07-24T12:17:11.213Z DEBUG 460 -> []
    2018-07-24T12:17:11.312Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.311Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:11.313Z DEBUG 443/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:6 payload_length:36 data_integrity:1 header_checksum:99 err_code:0
    2018-07-24T12:17:11.314Z DEBUG 461 -> []
    2018-07-24T12:17:11.317Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:11.316Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:11.318Z DEBUG 444/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    2018-07-24T12:17:11.318Z DEBUG 462 -> []
    2018-07-24T12:17:11.402Z DEBUG GAP_EVT_ADV_REPORT/ADV_NONCONN_IND time:2018-07-24T12:17:11.401Z connHandle:65535 rssi:85 peerAddr:[address:12:F4:6D:BA:94:F9 type:randomPrivateNonResolvable addrIdPeer:0] scanRsp:false advType:advNonconnInd gap:[manufacturerSpecificData:6,0,1,9,32,2,200,42,184,139,214,66,27,150,12,135,131,126,63,38,233,119,19,195,242,77,52,103,169]
    2018-07-24T12:17:11.404Z DEBUG 445/ 0 <- [02 1d 00 ff ff 06 f9 94 ba 6d f4 12 01 41 4e 43 53 a6 2a ab 06 1f 01 1e ff 06 00 01 09 20 02 c8 2a b8 8b d6 42 1b 96 0c 87 83 7e 3f 26 e9 77 13 c3 f2 4d 34 67 a9 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:6 payload_length:36 data_integrity:1 header_checksum:9f err_code:0
    2018-07-24T12:17:11.404Z DEBUG 463 -> []
    2018-07-24T12:17:11.409Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.408Z connHandle:65535 rssi:78 peerAddr:[address:48:33:F9:5F:94:8B type:randomPrivateResolvable addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,leOnlyGeneralDiscMode,leBrEdrController,leBrEdrHost] manufacturerSpecificData:76,0,16,5,3,28,193,205,145]
    2018-07-24T12:17:11.413Z DEBUG 446/ 0 <- [02 1d 00 ff ff 04 8b 94 5f f9 33 48 01 41 4e 43 53 a6 2a b2 00 0e 01 02 01 1a 0a ff 4c 00 10 05 03 1c c1 cd 91 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:6 payload_length:25 data_integrity:1 header_checksum:af err_code:0
    2018-07-24T12:17:11.413Z DEBUG 464 -> []
    2018-07-24T12:17:11.413Z DEBUG 447/ 0 <- [02 1d 00 ff ff 04 8b 94 5f f9 33 48 01 41 4e 43 53 a6 2a b2 01 00 01 ]
    2018-07-24T12:17:11.413Z DEBUG 465 -> []
    2018-07-24T12:17:11.417Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:11.413Z connHandle:65535 rssi:78 peerAddr:[address:48:33:F9:5F:94:8B type:randomPrivateResolvable addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:11.597Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.594Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:11.599Z DEBUG 448/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    2018-07-24T12:17:11.599Z DEBUG 466 -> []
    2018-07-24T12:17:11.599Z DEBUG 449/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    2018-07-24T12:17:11.600Z DEBUG 467 -> []
    2018-07-24T12:17:11.600Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:11.599Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:11.898Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.897Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:11.899Z DEBUG 450/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:6 payload_length:36 data_integrity:1 header_checksum:9a err_code:0
    2018-07-24T12:17:11.900Z DEBUG 468 -> []
    2018-07-24T12:17:11.903Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:11.902Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:11.904Z DEBUG 451/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:6 payload_length:17 data_integrity:1 header_checksum:8b err_code:0
    2018-07-24T12:17:11.904Z DEBUG 469 -> []
    2018-07-24T12:17:11.912Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:11.911Z connHandle:65535 rssi:83 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:11.914Z DEBUG 452/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ad 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:11.914Z DEBUG 470 -> []
    2018-07-24T12:17:12.109Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:12.108Z connHandle:65535 rssi:41 peerAddr:[address:7D:1C:1D:4C:BE:2C type:randomPrivateResolvable addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] manufacturerSpecificData:76,0,16,2,11,0]
    2018-07-24T12:17:12.111Z DEBUG 453/ 0 <- [02 1d 00 ff ff 04 2c be 4c 1d 1c 7d 01 41 4e 43 53 a6 2a d7 00 0b 01 02 01 06 07 ff 4c 00 10 02 0b 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:6 payload_length:22 data_integrity:1 header_checksum:e0 err_code:0
    2018-07-24T12:17:12.111Z DEBUG 471 -> []
    2018-07-24T12:17:12.114Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:12.113Z connHandle:65535 rssi:41 peerAddr:[address:7D:1C:1D:4C:BE:2C type:randomPrivateResolvable addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:12.115Z DEBUG 454/ 0 <- [02 1d 00 ff ff 04 2c be 4c 1d 1c 7d 01 41 4e 43 53 a6 2a d7 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:6 payload_length:17 data_integrity:1 header_checksum:90 err_code:0
    2018-07-24T12:17:12.115Z DEBUG 472 -> []
    2018-07-24T12:17:12.204Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:12.202Z connHandle:65535 rssi:50 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leLimitedDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] appearance:0,0 solicitedServiceUuids128Bit:208,0,45,18,30,75,15,164,153,78,206,181,49,244,5,121 completeLocalName:ANCS]
    2018-07-24T12:17:12.205Z DEBUG 455/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a ce 00 1f 01 03 19 00 00 02 01 05 11 15 d0 00 2d 12 1e 4b 0f a4 99 4e ce b5 31 f4 05 79 05 09 41 4e 43 53 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:6 payload_length:36 data_integrity:1 header_checksum:9d err_code:0
    2018-07-24T12:17:12.205Z DEBUG 473 -> []
    2018-07-24T12:17:12.208Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:12.207Z connHandle:65535 rssi:49 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] scanRsp:true
    2018-07-24T12:17:12.211Z DEBUG 456/ 0 <- [02 1d 00 ff ff 02 a4 04 de 82 e3 ea 01 41 4e 43 53 a6 2a cf 01 00 01 ]
    2018-07-24T12:17:12.211Z DEBUG 474 -> []
    2018-07-24T12:17:12.213Z INFO Connecting to device
    2018-07-24T12:17:12.222Z DEBUG GAP_EVT_ADV_REPORT/ADV_IND time:2018-07-24T12:17:12.215Z connHandle:65535 rssi:82 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:false advType:advInd gap:[adTypeFlags:[leGeneralDiscMode,brEdrNotSupported,leOnlyLimitedDiscMode,leOnlyGeneralDiscMode] 128BitServiceUuidComplete:6A4E3E10-667B-11E3-949A-0800200C9A66 manufacturerSpecificData:135,0,8,2]
    2018-07-24T12:17:12.224Z DEBUG 475 -> [00 8c 01 02 a4 04 de 82 e3 ea 01 01 a0 00 50 00 14 00 01 06 00 06 00 00 00 90 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:4 payload_length:1b data_integrity:1 header_checksum:5b err_code:0
    2018-07-24T12:17:12.224Z DEBUG 457/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ae 00 1b 01 02 01 06 11 07 66 9a 0c 20 00 08 9a 94 e3 11 7b 66 10 3e 4e 6a 05 ff 87 00 08 02 ]
    2018-07-24T12:17:12.224Z DEBUG 476 -> []
    2018-07-24T12:17:12.224Z DEBUG 458/ 0 <- []
    2018-07-24T12:17:12.224Z DEBUG 459/ 0 <- [01 8c 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:7 payload_length:6 data_integrity:1 header_checksum:95 err_code:0
    2018-07-24T12:17:12.224Z DEBUG 477 -> []
    2018-07-24T12:17:12.226Z DEBUG 460/ 0 <- [02 1d 00 ff ff 02 b6 70 5c 0d ef c8 01 41 4e 43 53 a6 2a ad 01 11 01 09 09 66 65 6e 69 78 20 33 00 06 16 10 3e 00 12 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:7 payload_length:28 data_integrity:1 header_checksum:72 err_code:0
    2018-07-24T12:17:12.226Z DEBUG 478 -> []
    2018-07-24T12:17:12.227Z DEBUG GAP_EVT_ADV_REPORT time:2018-07-24T12:17:12.226Z connHandle:65535 rssi:83 peerAddr:[address:C8:EF:0D:5C:70:B6 type:randomStatic addrIdPeer:0] scanRsp:true gap:[completeLocalName:fenix 3 serviceData:16,62,0,18,0]
    2018-07-24T12:17:12.449Z DEBUG GAP_EVT_CONNECTED time:2018-07-24T12:17:12.447Z connHandle:0 peerAddr:[address:EA:E3:82:DE:04:A4 type:randomStatic addrIdPeer:0] role:central connParams:[minConnInterval:7_5 maxConnInterval:7_5 slaveLatency:0 connSupTimeout:4000]
    2018-07-24T12:17:12.453Z INFO Connected to device EA:E3:82:DE:04:A4
    2018-07-24T12:17:12.465Z INFO Attribute value changed, handle: 0x0E, value (0x): 00-00
    2018-07-24T12:17:12.469Z INFO Attribute value changed, handle: 0x13, value (0x): 00-00
    2018-07-24T12:17:12.469Z DEBUG 461/ 0 <- [02 10 00 00 00 02 a4 04 de 82 e3 ea 02 06 00 06 00 00 00 90 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:7 payload_length:15 data_integrity:1 header_checksum:a2 err_code:0
    2018-07-24T12:17:12.469Z DEBUG 479 -> []
    2018-07-24T12:17:12.469Z DEBUG 480 -> [00 94 00 00 01 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:0 payload_length:7 data_integrity:1 header_checksum:bb err_code:0
    2018-07-24T12:17:12.469Z DEBUG 462/ 0 <- []
    2018-07-24T12:17:12.469Z DEBUG 463/ 0 <- [01 94 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:0 payload_length:6 data_integrity:1 header_checksum:d2 err_code:0
    2018-07-24T12:17:12.469Z DEBUG 481 -> []
    2018-07-24T12:17:12.487Z DEBUG GATTC_EVT_PRIM_SRVC_DISC_RSP time:2018-07-24T12:17:12.486Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:2 services:[[uuid:[uuid:6144 type:1 typeString:bleUuidTypeBle],handleRange:[startHandle:1 endHandle:9]],[uuid:[uuid:6145 type:1 typeString:bleUuidTypeBle],handleRange:[startHandle:10 endHandle:65535]]]
    2018-07-24T12:17:12.492Z DEBUG 464/ 0 <- [02 30 00 00 00 00 00 00 00 02 00 00 18 01 01 00 09 00 01 18 01 0a 00 ff ff ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:0 payload_length:19 data_integrity:1 header_checksum:a0 err_code:0
    2018-07-24T12:17:12.492Z DEBUG 482 -> []
    2018-07-24T12:17:12.492Z DEBUG 483 -> [00 96 00 00 01 01 00 09 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:2 payload_length:9 data_integrity:1 header_checksum:92 err_code:0
    2018-07-24T12:17:12.498Z DEBUG 465/ 0 <- []
    2018-07-24T12:17:12.498Z DEBUG 466/ 0 <- [01 96 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:1 payload_length:6 data_integrity:1 header_checksum:c8 err_code:0
    2018-07-24T12:17:12.498Z DEBUG 484 -> []
    2018-07-24T12:17:12.511Z DEBUG GATTC_EVT_CHAR_DISC_RSP time:2018-07-24T12:17:12.510Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:3 chars:[[uuid:[uuid:10752 type:1 typeString:bleUuidTypeBle],charProps:[broadcast:false read:true writeWoResp:false write:true notify:false indicate:false authSignedWr:false],charExtProps:0,handleDecl:2,handleValue:3],[uuid:[uuid:10753 type:1 typeString:bleUuidTypeBle],charProps:[broadcast:false read:true writeWoResp:false write:false notify:false indicate:false authSignedWr:false],charExtProps:0,handleDecl:4,handleValue:5],[uuid:[uuid:10756 type:1 typeString:bleUuidTypeBle],charProps:[broadcast:false read:true writeWoResp:false write:false notify:false indicate:false authSignedWr:false],charExtProps:0,handleDecl:6,handleValue:7]]
    2018-07-24T12:17:12.512Z DEBUG 467/ 0 <- [02 32 00 00 00 00 00 00 00 03 00 00 2a 01 0a 00 02 00 03 00 01 2a 01 02 00 04 00 05 00 04 2a 01 02 00 06 00 07 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:1 payload_length:26 data_integrity:1 header_checksum:c5 err_code:0
    2018-07-24T12:17:12.512Z DEBUG 485 -> []
    2018-07-24T12:17:12.512Z DEBUG 486 -> [00 96 00 00 01 07 00 09 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:4 payload_length:9 data_integrity:1 header_checksum:81 err_code:0
    2018-07-24T12:17:12.515Z DEBUG 468/ 0 <- []
    2018-07-24T12:17:12.516Z DEBUG 469/ 0 <- [01 96 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:2 payload_length:6 data_integrity:1 header_checksum:be err_code:0
    2018-07-24T12:17:12.516Z DEBUG 487 -> []
    2018-07-24T12:17:12.532Z DEBUG GATTC_EVT_CHAR_DISC_RSP time:2018-07-24T12:17:12.531Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:1 chars:[[uuid:[uuid:10918 type:1 typeString:bleUuidTypeBle],charProps:[broadcast:false read:true writeWoResp:false write:false notify:false indicate:false authSignedWr:false],charExtProps:0,handleDecl:8,handleValue:9]]
    2018-07-24T12:17:12.532Z DEBUG 470/ 0 <- [02 32 00 00 00 00 00 00 00 01 00 a6 2a 01 02 00 08 00 09 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:2 payload_length:14 data_integrity:1 header_checksum:dc err_code:0
    2018-07-24T12:17:12.532Z DEBUG 488 -> []
    2018-07-24T12:17:12.532Z DEBUG 489 -> [00 9a 00 00 03 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:6 payload_length:8 data_integrity:1 header_checksum:80 err_code:0
    2018-07-24T12:17:12.538Z DEBUG 471/ 0 <- []
    2018-07-24T12:17:12.538Z DEBUG 472/ 0 <- [01 9a 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:3 payload_length:6 data_integrity:1 header_checksum:b4 err_code:0
    2018-07-24T12:17:12.538Z DEBUG 490 -> []
    2018-07-24T12:17:12.553Z DEBUG GATTC_EVT_READ_RSP time:2018-07-24T12:17:12.553Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:3 offset:0 len:4
    2018-07-24T12:17:12.554Z DEBUG 473/ 0 <- [02 36 00 00 00 00 00 00 00 03 00 00 00 04 00 41 4e 43 53 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:3 payload_length:13 data_integrity:1 header_checksum:e2 err_code:0
    2018-07-24T12:17:12.554Z DEBUG 491 -> []
    2018-07-24T12:17:12.554Z DEBUG 492 -> [00 9a 00 00 05 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:0 payload_length:8 data_integrity:1 header_checksum:af err_code:0
    2018-07-24T12:17:12.556Z DEBUG 474/ 0 <- []
    2018-07-24T12:17:12.558Z DEBUG 475/ 0 <- [01 9a 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:4 payload_length:6 data_integrity:1 header_checksum:b2 err_code:0
    2018-07-24T12:17:12.558Z DEBUG 493 -> []
    2018-07-24T12:17:12.569Z DEBUG GATTC_EVT_READ_RSP time:2018-07-24T12:17:12.568Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:5 offset:0 len:2
    2018-07-24T12:17:12.569Z DEBUG 476/ 0 <- [02 36 00 00 00 00 00 00 00 05 00 00 00 02 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:4 payload_length:11 data_integrity:1 header_checksum:0 err_code:0
    2018-07-24T12:17:12.569Z DEBUG 494 -> []
    2018-07-24T12:17:12.569Z DEBUG 495 -> [00 9a 00 00 07 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:2 payload_length:8 data_integrity:1 header_checksum:9e err_code:0
    2018-07-24T12:17:12.571Z DEBUG 477/ 0 <- []
    2018-07-24T12:17:12.573Z DEBUG 478/ 0 <- [01 9a 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:5 payload_length:6 data_integrity:1 header_checksum:a8 err_code:0
    2018-07-24T12:17:12.573Z DEBUG 496 -> []
    2018-07-24T12:17:12.583Z DEBUG GATTC_EVT_READ_RSP time:2018-07-24T12:17:12.583Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:7 offset:0 len:8
    2018-07-24T12:17:12.584Z DEBUG 479/ 0 <- [02 36 00 00 00 00 00 00 00 07 00 00 00 08 00 90 01 20 03 00 00 90 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:5 payload_length:17 data_integrity:1 header_checksum:96 err_code:0
    2018-07-24T12:17:12.584Z DEBUG 497 -> []
    2018-07-24T12:17:12.584Z DEBUG 498 -> [00 9a 00 00 09 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:4 payload_length:8 data_integrity:1 header_checksum:8d err_code:0
    2018-07-24T12:17:12.586Z DEBUG 480/ 0 <- []
    2018-07-24T12:17:12.588Z DEBUG 481/ 0 <- [01 9a 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:6 payload_length:6 data_integrity:1 header_checksum:9e err_code:0
    2018-07-24T12:17:12.588Z DEBUG 499 -> []
    2018-07-24T12:17:12.599Z DEBUG GATTC_EVT_READ_RSP time:2018-07-24T12:17:12.598Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:9 offset:0 len:1
    2018-07-24T12:17:12.605Z DEBUG 482/ 0 <- [02 36 00 00 00 00 00 00 00 09 00 00 00 01 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:6 payload_length:10 data_integrity:1 header_checksum:fc err_code:0
    2018-07-24T12:17:12.605Z DEBUG 500 -> []
    2018-07-24T12:17:12.606Z DEBUG 501 -> [00 97 00 00 01 04 00 09 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:6 payload_length:9 data_integrity:1 header_checksum:6c err_code:0
    2018-07-24T12:17:12.609Z DEBUG 483/ 0 <- []
    2018-07-24T12:17:12.610Z DEBUG 484/ 0 <- [01 97 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:7 payload_length:6 data_integrity:1 header_checksum:94 err_code:0
    2018-07-24T12:17:12.610Z DEBUG 502 -> []
    2018-07-24T12:17:12.623Z DEBUG GATTC_EVT_DESC_DISC_RSP time:2018-07-24T12:17:12.622Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:5 descs:[[handle:4,uuid:[uuid:10243 type:1 typeString:bleUuidTypeBle]],[handle:5,uuid:[uuid:10753 type:1 typeString:bleUuidTypeBle]],[handle:6,uuid:[uuid:10243 type:1 typeString:bleUuidTypeBle]],[handle:7,uuid:[uuid:10756 type:1 typeString:bleUuidTypeBle]],[handle:8,uuid:[uuid:10243 type:1 typeString:bleUuidTypeBle]]]
    2018-07-24T12:17:12.626Z DEBUG 485/ 0 <- [02 33 00 00 00 00 00 00 00 05 00 04 00 03 28 01 05 00 01 2a 01 06 00 03 28 01 07 00 04 2a 01 08 00 03 28 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:7 payload_length:24 data_integrity:1 header_checksum:b1 err_code:0
    2018-07-24T12:17:12.626Z DEBUG 503 -> []
    2018-07-24T12:17:12.626Z DEBUG 504 -> [00 97 00 00 01 06 00 09 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:0 payload_length:9 data_integrity:1 header_checksum:9b err_code:0
    2018-07-24T12:17:12.631Z DEBUG 486/ 0 <- []
    2018-07-24T12:17:12.631Z DEBUG 487/ 0 <- [01 97 00 00 00 00 ]
    2018-07-24T12:17:12.631Z DEBUG 505 -> []
    2018-07-24T12:17:12.645Z DEBUG GATTC_EVT_DESC_DISC_RSP time:2018-07-24T12:17:12.644Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:4 descs:[[handle:6,uuid:[uuid:10243 type:1 typeString:bleUuidTypeBle]],[handle:7,uuid:[uuid:10756 type:1 typeString:bleUuidTypeBle]],[handle:8,uuid:[uuid:10243 type:1 typeString:bleUuidTypeBle]],[handle:9,uuid:[uuid:10918 type:1 typeString:bleUuidTypeBle]]]
    2018-07-24T12:17:12.649Z DEBUG 488/ 0 <- [02 33 00 00 00 00 00 00 00 04 00 06 00 03 28 01 07 00 04 2a 01 08 00 03 28 01 09 00 a6 2a 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:0 payload_length:1f data_integrity:1 header_checksum:40 err_code:0
    2018-07-24T12:17:12.649Z DEBUG 506 -> []
    2018-07-24T12:17:12.649Z DEBUG 507 -> [00 97 00 00 01 08 00 09 00 ]
    2018-07-24T12:17:12.652Z DEBUG 489/ 0 <- []
    2018-07-24T12:17:12.653Z DEBUG 490/ 0 <- [01 97 00 00 00 00 ]
    2018-07-24T12:17:12.653Z DEBUG 508 -> []
    2018-07-24T12:17:12.668Z DEBUG GATTC_EVT_DESC_DISC_RSP time:2018-07-24T12:17:12.666Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:2 descs:[[handle:8,uuid:[uuid:10243 type:1 typeString:bleUuidTypeBle]],[handle:9,uuid:[uuid:10918 type:1 typeString:bleUuidTypeBle]]]
    2018-07-24T12:17:12.673Z DEBUG 491/ 0 <- [02 33 00 00 00 00 00 00 00 02 00 08 00 03 28 01 09 00 a6 2a 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:1 payload_length:15 data_integrity:1 header_checksum:d6 err_code:0
    2018-07-24T12:17:12.673Z DEBUG 509 -> []
    2018-07-24T12:17:12.673Z DEBUG 510 -> [00 97 00 00 01 0a 00 09 00 ]
    2018-07-24T12:17:12.676Z DEBUG 492/ 0 <- []
    2018-07-24T12:17:12.678Z DEBUG 493/ 0 <- [01 97 00 00 00 00 ]
    2018-07-24T12:17:12.678Z DEBUG 511 -> []
    2018-07-24T12:17:12.688Z DEBUG GATTC_EVT_DESC_DISC_RSP time:2018-07-24T12:17:12.687Z connHandle:0 gattStatus:257 gattStatusName:atterrInvalidHandle errorHandle:10 count:0 descs:[]
    2018-07-24T12:17:12.690Z DEBUG 494/ 0 <- [02 33 00 00 00 01 01 0a 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:2 payload_length:b data_integrity:1 header_checksum:6d err_code:0
    2018-07-24T12:17:12.690Z DEBUG 512 -> []
    2018-07-24T12:17:12.690Z DEBUG 513 -> [00 9a 00 00 03 00 00 00 ]
    2018-07-24T12:17:12.693Z DEBUG 495/ 0 <- []
    2018-07-24T12:17:12.695Z DEBUG 496/ 0 <- [01 9a 00 00 00 00 ]
    2018-07-24T12:17:12.695Z DEBUG 514 -> []
    2018-07-24T12:17:12.711Z DEBUG GATTC_EVT_READ_RSP time:2018-07-24T12:17:12.710Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:3 offset:0 len:4
    2018-07-24T12:17:12.711Z INFO Attribute value read, handle: 0x03, value (0x): 41-4E-43-53
    2018-07-24T12:17:12.716Z DEBUG 497/ 0 <- [02 36 00 00 00 00 00 00 00 03 00 00 00 04 00 41 4e 43 53 ]
    2018-07-24T12:17:12.716Z DEBUG 515 -> []
    2018-07-24T12:17:13.947Z DEBUG GAP_EVT_SEC_REQUEST time:2018-07-24T12:17:13.947Z connHandle:0 bond:true mitm:false lesc:false keypress:false
    2018-07-24T12:17:13.948Z DEBUG 498/ 0 <- [02 1e 00 00 00 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:3 payload_length:6 data_integrity:1 header_checksum:ba err_code:0
    2018-07-24T12:17:13.949Z DEBUG 516 -> []
    2018-07-24T12:17:13.949Z DEBUG 517 -> [00 7e 00 00 01 41 07 10 01 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:1 payload_length:a data_integrity:1 header_checksum:87 err_code:0
    2018-07-24T12:17:13.951Z DEBUG 499/ 0 <- []
    2018-07-24T12:17:13.953Z DEBUG 500/ 0 <- [01 7e 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:4 payload_length:6 data_integrity:1 header_checksum:b1 err_code:0
    2018-07-24T12:17:13.953Z DEBUG 518 -> []
    2018-07-24T12:17:13.964Z DEBUG GAP_EVT_SEC_PARAMS_REQUEST time:2018-07-24T12:17:13.962Z connHandle:0 peerParams:[bond:true mitm:false lesc:false keypress:false ioCaps:bleGapIoCapsNone oob:false minKeySize:0 maxKeySize:16 kdistOwn:[enc:true sign:false link:false] kdistPeer:[enc:true sign:false link:false]]
    2018-07-24T12:17:13.965Z DEBUG 501/ 0 <- [02 13 00 00 00 31 00 10 01 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:4 payload_length:a data_integrity:1 header_checksum:70 err_code:0
    2018-07-24T12:17:13.965Z DEBUG 519 -> []
    2018-07-24T12:17:13.965Z DEBUG 520 -> [00 7f 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 99 28 93 42 72 df ae 5a 41 6c 4b 58 e9 3c 09 29 fc af f2 2c 2d 5d 93 12 96 cc 26 cd 63 27 be 8b 3b d5 8d 93 a1 75 f0 34 2b e8 c2 2f 6c 18 b4 75 9f 19 f2 35 d4 a4 f2 2d a3 64 f3 a5 a7 5b 84 1f 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:3 payload_length:113 data_integrity:1 header_checksum:d5 err_code:0
    2018-07-24T12:17:14.216Z DEBUG 521 -> [00 7f 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 99 28 93 42 72 df ae 5a 41 6c 4b 58 e9 3c 09 29 fc af f2 2c 2d 5d 93 12 96 cc 26 cd 63 27 be 8b 3b d5 8d 93 a1 75 f0 34 2b e8 c2 2f 6c 18 b4 75 9f 19 f2 35 d4 a4 f2 2d a3 64 f3 a5 a7 5b 84 1f 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
    2018-07-24T12:17:14.469Z DEBUG 522 -> [00 7f 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 99 28 93 42 72 df ae 5a 41 6c 4b 58 e9 3c 09 29 fc af f2 2c 2d 5d 93 12 96 cc 26 cd 63 27 be 8b 3b d5 8d 93 a1 75 f0 34 2b e8 c2 2f 6c 18 b4 75 9f 19 f2 35 d4 a4 f2 2d a3 64 f3 a5 a7 5b 84 1f 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
    2018-07-24T12:17:14.721Z DEBUG 523 -> [00 7f 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 99 28 93 42 72 df ae 5a 41 6c 4b 58 e9 3c 09 29 fc af f2 2c 2d 5d 93 12 96 cc 26 cd 63 27 be 8b 3b d5 8d 93 a1 75 f0 34 2b e8 c2 2f 6c 18 b4 75 9f 19 f2 35 d4 a4 f2 2d a3 64 f3 a5 a7 5b 84 1f 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
    2018-07-24T12:17:14.972Z DEBUG 524 -> [00 7f 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 99 28 93 42 72 df ae 5a 41 6c 4b 58 e9 3c 09 29 fc af f2 2c 2d 5d 93 12 96 cc 26 cd 63 27 be 8b 3b d5 8d 93 a1 75 f0 34 2b e8 c2 2f 6c 18 b4 75 9f 19 f2 35 d4 a4 f2 2d a3 64 f3 a5 a7 5b 84 1f 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
    2018-07-24T12:17:15.223Z DEBUG 525 -> [00 7f 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 99 28 93 42 72 df ae 5a 41 6c 4b 58 e9 3c 09 29 fc af f2 2c 2d 5d 93 12 96 cc 26 cd 63 27 be 8b 3b d5 8d 93 a1 75 f0 34 2b e8 c2 2f 6c 18 b4 75 9f 19 f2 35 d4 a4 f2 2d a3 64 f3 a5 a7 5b 84 1f 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
    2018-07-24T12:17:15.480Z WARN Error when calling replySecParams: Error: Error occured when replying sec params. Errorcode: NRF_ERROR_INTERNAL (0x3)
    2018-07-24T12:17:15.480Z DEBUG ReplySecParams, secParams: null
    2018-07-24T12:17:15.480Z ERROR Received status with code 4 Unknown value, message: 'Error sending packet to target. Code #13'
    2018-07-24T12:17:17.451Z DEBUG GAP_EVT_CONN_PARAM_UPDATE_REQUEST time:2018-07-24T12:17:17.450Z connHandle:0 connParams:[minConnInterval:500 maxConnInterval:1000 slaveLatency:0 connSupTimeout:4000]
    2018-07-24T12:17:17.451Z DEBUG 502/ 0 <- [02 1f 00 00 00 90 01 20 03 00 00 90 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:4 payload_length:d data_integrity:1 header_checksum:3f err_code:0
    2018-07-24T12:17:17.451Z DEBUG 526 -> []
    2018-07-24T12:17:17.452Z DEBUG 527 -> [00 75 00 00 01 90 01 90 01 00 00 90 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:4 payload_length:d data_integrity:1 header_checksum:3e err_code:0
    2018-07-24T12:17:17.456Z DEBUG 503/ 0 <- []
    2018-07-24T12:17:17.456Z DEBUG 504/ 0 <- [01 75 00 00 00 00 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:5 payload_length:6 data_integrity:1 header_checksum:a6 err_code:0
    2018-07-24T12:17:17.456Z DEBUG 528 -> []
    2018-07-24T12:17:17.503Z DEBUG GAP_EVT_CONN_PARAM_UPDATE time:2018-07-24T12:17:17.502Z connHandle:0 connParams:[minConnInterval:500 maxConnInterval:500 slaveLatency:0 connSupTimeout:4000]
    2018-07-24T12:17:17.503Z INFO Connection parameters updated for device EA:E3:82:DE:04:A4: interval 500ms, timeout 4000ms, latency: 0
    2018-07-24T12:17:17.505Z DEBUG 505/ 0 <- [02 12 00 00 00 90 01 90 01 00 00 90 01 ]
    type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:5 payload_length:d data_integrity:1 header_checksum:35 err_code:0
    2018-07-24T12:17:17.505Z DEBUG 529 -> []
    Have you modified the ANCS example? Can you give me a step by step procedure on how to reproduce?
    On iOS the ANCS service is protected and visible only to the system. No app can discover this service, so it is not possible to fake any notification when bonded to an iPhone. However, if anyone would like to bond your device with an Android or a PC, this service would be visible as any other. You may try it using nRF Connect for Android.
    On Android ANCS is not supported natively. If you want to support Android devices as well, you'd have to implement it on your own in the Android app*. Currently, we don't have any sample Android app with ANCS, but you may check nRF Toolbox where some other, less complicated samples are handled. If you plan to support only iOS, ignore this paragraph, but remember, that users may still connect and bond with an Android device.
    As to the error you got, I think it may be due to the fact that you have bonded your device with an iPad previously and the bond info wasn't cleared. Try re-flashing your app on the DK after erasing the memory.
    * Actually, as ANCS profile defines also ANCS service on the phone, I would recommend using a random service UUID with identical behaviour as ANCS to avoid having the service duplicated. It may happen, that a user already had another app with ANCS support on their Android phone, and your app just adds another instance of ANCS service to phone's database. A remote device would most likely use a first found instance, so your app would never get any events. By having a random service UUID you almost ensure, that your service will be discovered as a first one.
    BR, Aleksander
    To Mttrinh:
    No I haven't modified the ANCS example. But I added in components/ble/ble_advertising.c the following lines:
       // Added to advertize only on channel 37
       p_advertising->adv_params.channel_mask[4] = 0xc0;
    This is done to increase the chance to track the connection opening with my TI sniffer USB dongle.
    I have followed all the steps described in:
    Software Development Kit > nRF5 SDK > nRF5 SDK v15.0.0 > Examples > Bluetooth low energy examples > BLE Peripheral
    To Aleksander:
    Thank you for your relevant information and your advice concerning Android. I was trying nRF Connect with an Android but wasn't able to discover the ANCS service too (similar to iOS).
    Concerning nRF Connect for Desktop, I tried to reflash the applicaton on the board doing "make erase; make flash_softdevice; make flash".
    However I got the same error. Isn't it equivalent to restart with button 2 pressed?
    Then, I get on the console: "<info> app: Erase bonds!". I also used the "Delete bond information" from the setup menu in Connection Map of nRF Connect.
    When I play with an iPad, the ANCS example seems to work well. I'm asked for pairing during the first connection. If I add an event on the Calendar, I get it in the nRF attached console:
    <info> app:
    Notification
    <info> app: Event: Added
    <info> app: Category ID: Schedule
    <info> app: Category Cnt:1
    <info> app: UID: 7
    <info> app: Flags:
    <info> app: Negative Action
    <info> app: App Identifier: com.apple.mobilecal
    <info> app: Title: Test meeting
    <info> app: Subtitle: (N/A)
    <info> app: Message: Today at 14:15
    Bruxelles
    <info> app: Message Size: 24
    <info> app: Date: 20180725T141500
    <info> app: Positive Action Label: (N/A)
    <info> app: Negative Action Label: Clear
    <info> app: Request for com.apple.mobilecal:
    <info> app: Display Name: Calendar
    <info> app: Performing Negative Action.
    <info> app:
    Notification
    <info> app: Event: Removed
    <info> app: Category Cnt:0
    <info> app: UID: 7
    <info> app: Flags:
    But "Testing with nRF Connect" still fails as before even after reflashing.
    I was also surprised to see when the boards is rebooted, iOS automatically disconnect & reconnect. The connection to the peripheral is always active. This could be bad for the peripheral batteries. What do you suggest: change the BLE connection event period to a longer value?
    Thanks for your help.
    Bernard
  • Hi, It may be, that ANCS sample (or the profile) only uses ANCS service on the phone. The peripheral may not have any services, that's why you don't see them. I'm guessing here, but nRF Connect on Android should see ANCS service without problems.
    You may test it by starting advertising with nRF Connect on iOS and connecting to it using nRF Connect on Android. You should see there ANCS service.
    I don't know specs for ANCS. Perhaps it defines the preferred connection interval. I would assume that an ANCS device should always be connected. But may know more.
