Hello, I am a student studying firmware
I want to use SPI and UART in one project at the same time.
The soft program uses KEIL and is the latest version.
Code generation(Arm compiler) is V5.06 update 6. Computer's platform is Windows.
I added the contents of the uart example to the spi example to use spi and uart at the same time.
I set the link to include app_uart.h and added the necessary part in sdk_config.h.
Compilation does not generate an error, but the spi function is not executed in the hardware and the spi function stops working.
APP_ERROR_CHECK (nrf_drv_spi_transfer (& spi, m_tx_buf, m_length, m_rx_buf, m_length) of the spi function is not executed
at the moment of appending APP_UART_FIFO_INIT (& comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_error_handle, APPTERa_IRQ_PRIORITY_LOWEST, err_code).
The pin numbers of spi and uart were confirmed.
How can I use uart and spi in one project?
// spi header file
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// uart header file
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
#define MAX_TEST_DATA_BYTES (15U) /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
void uart_error_handle(app_uart_evt_t * p_event)
if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
else if (p_event->evt_type == APP_UART_FIFO_ERROR)
// for use uart
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
NULL,
NULL,
APP_UART_FLOW_CONTROL_DISABLED,
false,
NRF_UART_BAUDRATE_115200
#else
NRF_UARTE_BAUDRATE_115200
//error part
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APPtera_IRQ_PRIORITY_LOWEST,
err_code);
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
NRF_LOG_INFO("SPI example started.");
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
// <- program stops at this point.
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
bsp_board_leds_on();
//bsp_board_led_invert(BSP_BOARD_LED_0);
nrf_delay_ms(200);
